Old 08-10-06, 01:30 PM   #1
apeterson's Avatar
TLCA# 16605
2F head
does anyone know if a 2f head will work on a f engine... trying to get an engine running and it will not start... PO said he rebuilt with a 2f head? is that the problem? Has not run in a while (not sure how long) has spark, and compression, and will pop off if you pour gas in the carb, but will not stay running.... Just want to make sure it will work and that is not my problem....
any ideas?
A.P.
My weekend friends love Top Gun... (Gay yes I know)
http://www.youtube.com/watch?v=xHklGtW3rwU
build thread http://forum.ih8mud.com/40-55-series...r-builder.html
apeterson is offline   Reply With Quote
Old 08-10-06, 03:49 PM   #2
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Well if it will run when you pour gas down the carb, but will not keep running, that would tend to make me think about fuel delivery issues....
Old 08-10-06, 11:04 PM   #3
elder statesman
65swb45's Avatar
TLCA# 1086
2F heads can be run on an F engine, provided the F engine rocker oiling system is retained and the manifold studs work with the manifolds. Not a deal breaker.
Just a hunch, but I'd guess that in your scenario, someone inadvertently bumped up the timing too far. I'd start by finding #1 TDC compression stroke and checking your distributor timing.
If popping continues, do a compression test and follow up low readings with a 'wet' test.
Hth
Mark A.
A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[going],84FJ60[gone], 76K5, 73Sub454, 89Sub7.4[gone], 97Sub5.7
TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter
my website:
http://www.marksoffroad.net
65swb45 is offline   Reply With Quote
Old 08-11-06, 10:42 AM   #4
apeterson's Avatar
TLCA# 16605
ok.... timing has been checked (or I think)... I dont know how to do this myself, but I do need to learn, but the guy I am buying it from has checked it... it will not run but will spit and sputter....
Thanks for your replys!
Old 08-12-06, 05:13 PM   #5
Mark W's Avatar
TLCA# 6303
*Some* 2F heads will work on *some* F engines, albeit with lowered compression.
What vintage F shortblock and what vintage 2F head did you combine?
Mark...
Mark W is offline   Reply With Quote
Old 08-13-06, 08:56 PM   #6
apeterson's Avatar
TLCA# 16605
well..... I am not sure.... I have not looked at the engine yet... I am buying it from someone... I know it is a 74 F and have no idea what 2F is on it... what do you mean by some will work and some will not?
Old 08-18-06, 08:26 AM   #7
apeterson's Avatar
TLCA# 16605
so how can I tell if the rocker arms are getting oil... right now I got it running, just having some fuel issues so it will not stay running long enough now to see any oil on the rockers.... what will it look like when I get it running... should oil be spashing up on the rockers and valvles if it is working properly?
Old 08-18-06, 09:29 AM   #8
rjcruiser's Avatar
With the valve cover off and the engine running, you'll get oil to start dripping from the rockers. Also, the fan will start to blow it all over your engine bay and carb, so you'll want to keep a little rag handy to wipe up the mess after you shut things down. I must say, watching the valves dance up and down is a pretty sight. Another thing you'll want to probably do is adjust the valves to the proper specs. I know that when I did that with my engine (sitting for a long time before I got it), it made a big difference.
rjcruiser is offline   Reply With Quote
Old 08-18-06, 11:19 AM   #9
Mark W's Avatar
TLCA# 6303
Pre '68 F engines used siamesed exhaust ports and a deep "bathtub" style combustion chamber. They're pretty much on their own so far as interchanginf anything.
From then until '72 the F engine used a flattop piston and a closed combustion chamber.
'73 and '74 F engines used an open combustion chamber and a very small dome on the piston.
'75-'80 US variant 2Fs used an open chamber and a domed piston.
'81 and later 2Fs used a closed chamber and a flat top piston.
A '73-'74 F head will be a bolt on swap to any of the 2F, producing more compression on the '75-'80 blocks.
A pre '73 F head will swap to the later 2F engines once the rocker arm oiling is addressed. There will be piston/head interference on the early 2Fs
You can install an early 2F head on a late 2F engine. You will loose compression.
You can install any 2F head on the pre-'73 F engines. Again, you will loose compression, especially if you install an early 2F head with the open chamber.
Mark...
Old 08-18-06, 11:23 AM   #10
wesintl's Avatar
TLCA# 4180
Above post should be in the FAQ.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
You should be able to delete your own thread. Communists abound
wesintl is offline   Reply With Quote
Old 08-18-06, 12:13 PM   #11
apeterson's Avatar
TLCA# 16605
Thanks.... am I wrong in thinking I have a f engine with a 2 F head..... an I a Nobb and dont know what I am talking about (very very new to this)
so I got compression and it will start... once I get the fuel thing figured out.... so if it runs am I okay... or should I be worried about something??? I dont want to destroy my engine if there is something I should be doing differently..
My engine block is Blue, does that mean anything or did someone just paint it.
I also have a 4 speed trans. and I though before I got this that every 2f came with a 4 speed and all f came with a 3 speed... am I wrong here to...
sorry so many questions.... I am learning and reading alot.... thanks!!
Old 08-18-06, 12:30 PM   #12
rjcruiser's Avatar
Mark...
I'm not sure about the above....I've got an early F (off a '64) that I bolted up a '73 head to. This allows me to use the later model carb intake (double barrel) and improved exhaust manifold. I've got it running fairly well...don't have compression numbers as I don't have a compression tool. I think I have a little bit of a vacuum leak, but other than that, it idles and drives fine.
Old 08-18-06, 01:13 PM   #13
Mark W's Avatar
TLCA# 6303
Sorry, I was thinking about swapping the bathtub head onto anything else. If you swapp the manifolds and other affected components along with the head, then you can update the earlier Fs with the later F heads. It'll boost your compression some too.
Mark...
Old 08-18-06, 02:07 PM   #14
rjcruiser's Avatar
No apology necessary.....as a rookie, I don't want to come across as knowing more than a lifer
Old 08-18-06, 02:17 PM   #15
apeterson's Avatar
TLCA# 16605
Thanks Mark! hope who ever put my head in did everything they were suppose to do...
Old 08-18-06, 02:29 PM   #16
IDave's Avatar
TLCA# 13705
How does a late F/2F oil it's rockers? There's no oil tube or union like my earlier Fs.
9/70 FJ40 +Rollbar
9/64 FJ45 (L) P-B with restored wiring
4/84 Toy 4x4 Mini PU
"The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton
IDave is offline   Reply With Quote
Old 08-19-06, 01:56 AM   #17
Mark W's Avatar
TLCA# 6303
'74 and on oil the rockers via a passage from the #3 cam bearing, through the top of the block, over to the head bolt by the #5 spark plug via a passage in the head gasket, up around the head bolt into the head, then via a drilled boss to the base of the rocker arm pedestal just ahead of #5 plug and up through the pedestal to the rocker arm assembly.
Mark...
Old 08-19-06, 03:19 AM   #18
IDave's Avatar
TLCA# 13705
Thanks, Mark!
9/70 FJ40 +Rollbar
Old 08-19-06, 08:04 AM   #19
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
Originally Posted by IDave
Thanks, Mark!
Jeeze Dave. that's just what I told you in a more-confusing, less professional, un-technical way.
Ed
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 08-19-06, 09:29 AM   #20
IDave's Avatar
TLCA# 13705
Ed
Thank you, too, Ed!
9/70 FJ40 +Rollbar
Old 08-21-06, 09:50 PM   #21
apeterson's Avatar
TLCA# 16605
ok just a quick update...... got the engine running.... about 5 min at a time... 2 times... so 10 min total.... still no oil in top of engine.... rocker arms seem like they are getting somthing... but not the top of arms and springs.... my dad (not a cruiser guy, but an engine guy) says to keep running it and it will take longer to get the oil up... is he wrong? what is my worse case senario? should I be worried??
Old 08-21-06, 10:31 PM   #22
Rocky_LC's Avatar
TLCA# 14977
I would worry. 5 Min of running with no oil dripping out of the rocker arm sounds like a problem to me. The oil pump should pressurize the top end in less than 15 seconds.
I wouldn't run it anymore until I figured out that it WASN'T bad....
No easy suggestions:
Pull the dizzy and pump the oil up with an electric drill? - That's hard - and possibly risky if you don't put it together right. and if nothing comes out, you still have to pull the head...
Pull the head, and ensure all oil passages are clear? That's hard.
Can you remove the rocker assy, and see if oil is feeding into the tube? I'll bet that's hard too, and then you have to run the engine more...
Maybe someone else has a good (easy) suggestion.....
Rocky
74 FJ-40 - A work in progress....
Rocky_LC is offline   Reply With Quote
Old 08-22-06, 12:28 AM   #23
Mark W's Avatar
TLCA# 6303
I've never seen a 2F that will show oil flow at the rockers on initial start up within 15 seconds. But 5 minutes is longer by far than it should take.
Popping the distributor out and spinning the oil pump with a drill is easy. But it's a crap shoot as to whether that will oil the rockers anyway (the camshaft needs to be spinning for thre oil to pass through it.
I'l dump some oil over the rocker assembly to keep from damaging anything, and run it for a while.... Assuming that:
You made sure that the headgasket got installed correctly. If it's put in backward/upside down the oiling passage is blocked.
You're sure that the distributir is seated in the pump and that you have oil pressure.
Mark...
Old 08-22-06, 07:32 AM   #24
apeterson's Avatar
TLCA# 16605
I am not sure the head gasket got put in correctly.... I assume the only way to ckeck that is by pulling it all out...
where is the oil pump and how do I make sure I have pressure....
Old 08-22-06, 11:24 AM   #25
Mark W's Avatar
TLCA# 6303
There is about 1/4 - 1/2 inch of head gasket that sticks out at the back of the head when it is installed correctly. AFAIK, all aftermarket head gaskets are this way to, but maybe not (this would help explain how people manage to put them on backward in the forst place).
The oil pump is... in the pan. If you are asking because of the comments about spinning it with a drill... You pull the distributor anddrive it through there. The bottom of the distributor shaft fits into the oil pump and that is what spins the pump. If the distributor is not completely seated on the bolck it will not ingage the pump and the pump will not turn, resulting in no oil to the engine.
For oil pressure... check the gauge.
While it doesn't tell you anything about the pressure, you can easily check for oil flow itself byloosening the oil flter. If it's ful of oil and starts leaking a mess all over the side of the engine... You're getting oil from the pump.
Mark...
Old 08-22-06, 09:41 PM   #26
apeterson's Avatar
TLCA# 16605
let engine run again today for 15 min... I put oil on the rockers so that everything was lubed up... no extra oil is comming to the surface... the oil pressure gauge goes to about 3/4 to the top of the gauge... so I assume it is reading correctly... pulled off the oil filter and yes there is oil there... so I know it is getting around...
going to check in the morning to make sure that all head gasket is sticking out the back... I will post in the moring what I find out..
Old 08-22-06, 09:52 PM   #27
TLCA# 15178
I wouldn't worry to much. It's not good, but it won't damage the head (short term).. I had a '74 F motor that I rebuilt (first motor I ever rebuilt). We'll the head gasket appears to fit two ways, but to the trained eye one will block the oiling to the head. I drove 600 miles on the motor out to Death Valley and back before I realized my mistake of blocking the oiling passage to the head.
I would definetly fix your problem ASAP.
FJ-55 Weatherstripping
www.pvcruisers.com
FOR SALE:
'81 HJ-47 Troopy LHD '07 Vortec Motor, 4L60E Trans, New Steel Body, PPG Paint, Rebuilt from the Ground Up
'79 HJ-45 Troopy RHD
PVCruiser is offline   Reply With Quote
