Old 07-20-06, 01:44 AM   #1 (permalink)
Land Bruiser's Avatar
Frame flex or body mounts?
I recently got my 1967 FJ40 out of paint and back wheeling after a couple years of B.S.. Anyhow, my issue is that I have noticed that the hood is sliding back and forth quite a bit while flexing. I can look out the side window at the hood and see the front sliding back and forth side to side as I twist the suspension down trails. It dosnt take much, and the hood hooks have bashed up the paint pretty good on both sides from hitting the upper fender/apron, as well as the hood has ground down the hood bumpers completely from sliding back and forth on them so much... I can just imagine the force being put on things when I am really flexed. I have inspected the frame and found no signs of cracks or anything. The hinges are tight. I suspect this isnt normal, is it? Niether of my 55's ever did this. Should I be looking somewhere else? Have the rivets on the cross members of the frame loosened up too much over the years, or am I just missing something? Any ideas are greatly appreciated... thanks
1996 FJZ80, unlocked, 80k, stock
1972 FJ55 "iron pig" mostly stock..
1969 FJ55 SOA, 35" BFG's, Chevy292, TH400
1967 FJ40 built 327, SOA, 35" BFG's, saginaw p/s, disk brakes with FJ60 axles, new paint, money pit...
Land Bruiser is offline   Reply With Quote
Old 07-20-06, 08:35 AM   #2 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
Garage
Frame flex....
Mine has done that same thing for many years....even with 33's...long before 42's and Dana axles.
Old 07-20-06, 10:45 AM   #3 (permalink)
projektdotnet's Avatar
mine doesn't do this too bad really actually. odd
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 07-20-06, 12:14 PM   #4 (permalink)
Has anyone ever done anything to the frame to try and fix this? It dosnt seem right...
Old 07-20-06, 12:28 PM   #5 (permalink)
Poser's Avatar
Garage
Are the bolts attaching the fender to the body tub and frame tight?
Have you verified that the tub mount under your and the passenger feet is not seperating the spot welds that hold it together?
Shit man, it is a 40 year old truck with a hot riveted frame that has had god knows what done to it in the time before you purchased it..
Look for cracks from the body tub mounts forward on the frame...around the engine mounts up front and rear, where the frame is boxed up front....
If you want it to end/be limited, install a frame mounted cage, and tie it into a hoop protecting the engine area/radiator.
This occurs every time that I go out with the truck....no big deal. Paint is going to get removed, glass will break, shit happens.
Old 07-20-06, 12:34 PM   #6 (permalink)
In the garage
John Smith's Avatar
Mine does the same thing when flexed up. The first time I noticed it I freaked out also. Now I find it somewhat amusing, especially since I don't have body or paint to really worry about.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 07-20-06, 04:02 PM   #7 (permalink)
honk's Avatar
I think most of the movement of hood to apron/bib is a result of sheet metal flexing.
Do you still have the steel struts from the radiator frame to the cowl and/or to the frame? All of the sheet metal bolts installed and tight?
If so I'd get some delrin and make a set of bigger stronger hood spacers to replace the rubber on top the aprons and bib and enjoy. Watch someone else's 40 series for that movement. I'd swear that the cowl flexes some and I know that the whole bib and fender assembly rocks back and forth. Sometimes it looks the bib and the cowl move in opposition to the other.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 07-20-06, 04:55 PM   #8 (permalink)
numtel's Avatar
I just unhook my hood when its wheeling time. One of my hooks is bent pretty good but it still works.
numtel is offline   Reply With Quote
Old 07-20-06, 05:01 PM   #9 (permalink)
if i ever get mine back together ill chime in and let you know.
thewatergoblin is offline   Reply With Quote
Old 07-20-06, 06:07 PM   #10 (permalink)
bustanutley's Avatar
Some people weld the two C's of the frame together to stiffen it, as well as box the rest of the frame. I haven't done this, but my 6 point tied to frame cage has stiffened the rear of my truck a grip. I think that when I add an engine cage it will be pretty stiff through out.
FJ-40 on FO-DEEs
just a lil guy
bustanutley is offline   Reply With Quote
