Originally Posted by chaka 1. Any thoughts? should I not fix what ain't broken?
That is a good general rule, with the exception of when the part you are fixing is a piece of a larger assembly and the whole system is shot.
A single OEM or FelPro gasket should be fine.
Check the manifolds for warping and have them machined if they are out of spec.
You can remove the manifold with the carb still on it, but you are more likely to ding it if you are not careful.
Chase the threads on the studs and nuts to clean them up. Larger ones may be marginally better, but you risk breaking them off removing them or when torquing them down upon installation. If that misfortune happens to you, just weld a nut on to the remains and it will come out with a wrench.
