Off the top of my head... they are removable, and the rocker covers from a Land Cruiser will be required to cover the space.
correct. Fit LC rocker panels and mud flaps. Under all the Lexus bling its the exact same rig.
It's the section of the body below the doors. Normally, they are steel, and completely part of the body structure. In the case of the 200 series, there is a rocker panel, but it is hidden under a plastic cover that appears to be the rocker panel.
This picture shows it, sans plastic cover.
Yes. Retail is over $350 each cover, 75860-60040-XX and 75850-60040-XX should be the part numbers, but that should be double checked. The XX suffix needs to be filled in with the proper 2 digit letter number code for the correct color.
