100 vs 200 Wheel Bolt Pattern
Contemplating the new LC and have a set of spare wheels from the 100 series. Both are 5 bolt pattern but Im not sure about the mm. Does anyone know if the 2007 LC wheels will fit the 2008 LC ?
Thanks |
...pig searching...
I almost thought this was gonna be the first 100 vs 200 thread!
![]() If they are 5x150 they'll fit. Not much help, i know. |
As the great american said, Same sh!t different day.
__________________ 2007 FJ Cruiser 2002 4Runner Sport Edition 1998 4Runner SR5 5spd |
#4 | |
Oh God, please no! Anyone know about the offset? __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) |
First thing to check would be the diameter: 16" definitely won't fit because of the larger rotors. I know it comes with 18" but I wonder if they have clearanced the 18" wheels for the larger rotors or if the 18" hundy wheels will fit?
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#6 | |
Here in the middle east, the new LC is only being offered with 17" wheels from the factory so I would imagine that the brakes wouldnt be that big or that big of an issue. The wheels I have are 5x150. Just wanted to know if the new LX is same bolt pattern? |
IH8MUD No-Lifer
AFAIK, same bolt pattern.
__________________ 98 LX470 85 BJ70 |
Still looking for 10mm hubcentric spacers to clear the large large brakes on the 200 series.
Anyone make these to custom order? |
You can not make a hub centric spacer for the front unless they are going to be at least 2" or more. There is not enough space to have he lip needed.
#10 |
hello to all! I just fitted the 18" of the 100 to the 200 and needed a 5mm spacer. the caliper hit the inside spoke of the wheel. everything was fine after the spacer were installed. although the offset was the same i think it was the design of the wheel that caused.
__________________ 2000 Toyota Landcruiser 100 1HD-T 147HP@0.82 Bar |
#11 |
I was just thinking of the opposite thing. Wanted to put wheels from 200 to my 100. Presumably they have less backspacing...
#12 | |
The 200 series have 60 mm offset, the same as the 100 series. The 20" wheels are 8,5" wide, the 18" wheels 8" wide. Backspacing of the 18" 200 wheels should bes the same as on the 100 series, a little bit different with the 20" wheels because they are wider. Bjørn Erik |
Loans | Mortgage Calculator | Loans | Loans | Consolidation |
