Old 06-23-06, 09:00 PM   #1 (permalink)
Rookie
Headlight Mod
I just acquired the 98 LC a couple of weeks ago and checked out the lighting. Not bad but could definitely use some improvement. I noticed it uses a 9006 bulb for the low beam. I remembered modifying the low beam light (9006) on my 96 Camry and it is the same bulb as the LC. It made a huge difference on the Camry so I thought it should do the same for the LC. I swapped the 9006 in the LC with the modded 9005 out of my Camry. Everything fit perfect on the harness and headlight socket. Took the LC for a test drive later that night and man what a difference with the 9005 bulbs. I recommend this mod to anyone that wants better nighttime lighting. I have never had anyone flash their highbeams at me in the Camry or the LC after doing this mod so it would be safe to say it does not bother oncoming drivers. Below is a cut paste from the Toyota Nation forum and how to modify the bulb to fit the harness and headlight socket. Let me know if you try it and how it turns out. I would be surprised if you don't like it!!
Hands down, Sylvania Silverstar 65W 9005's are the best, the brightest, the
longest lasting (I've had mine in for two years now) and the whitest.
Why I'm using a 9005 bulb: 9005 bulbs are 65W and are not capped at the end, 9006 bulbs are 55W and have a cap at the end. The light increase is from the increase in lumens from the 9005 bulb. A 9005 bulb has 70% more lumens than the 9006 (1700 lumens vs 1000 lumens). HID has
3200 lumens. You have to slightly modify the 9005 bulb to fit the 9006 socket.
Supplies
*File or chisel tools, Sharp knife, blade, soldering iron or Dremel like tool.
*2 x 9005 bulbs.
*Protective glasses and gloves (you don't want to lose a finger or an eye). :P
Procedure
1. Remove 3mm of plastic from the left of the center of top tab when the
socket is pointing down until you have 5-6mm of plastic left.
2. Remove the two guides inside the socket. Install 1 new O'ring from the
old 9006 bulb on the new modified 9005 bulb to ensure a tight fit.
3. Install the bulbs in your car and have your light adjusted if not
already.
pics from - www.BMWE34.net
FYI -
It is also possible to modify the harness on the car... but I don't recommend
it. I've seen way too many afm harnesses melt or worse melt the fuse box. On the Gen3 (1992-1996) Toyota Camry both the high beam and low beam harnesses are designed to carry a max load of 65wats safely
Robert Gulley
98 LC
94 ImpalaSS
89 Suburban 4x4
Rob's New Toy is offline   Reply With Quote
Old 06-24-06, 06:48 AM   #2 (permalink)
mot
I ruin surprises.
mot's Avatar
Rob,
A lot of the forum members (100/80) have had good success with HIR bulbs, either from John Deere or IPF. I think the JH ones are made by Toshiba, either in Japan or China. You can acquire an upgrade harness from Slee Off Road and again most, if not all, the members who have purchased them seem to like them.
I've also heard good things about the Silverstars, too though.
And thanks for the pics!
Mot
mot is offline   Reply With Quote
Old 06-24-06, 08:29 AM   #3 (permalink)
spressomon's Avatar
RNT: Great post and great pics: Thanks. I did this to my '99 using the John Deere lamps and it made a significant difference in the useful light.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery with custom home brew battery tray, home brew sliders & Slee belly and skid plates, 9.5XP/Masterpull, Solstice LEDs, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, LT285/75R18 GY MT/R Kevlar, KK in tow... HAMified
ROTM: http://forum.ih8mud.com/100-series-c...pressomon.html
Old 09-04-06, 04:00 PM   #4 (permalink)
ColoradoCarlisle's Avatar
TLCA# 16764
Will this work in the fog lights as well they are 9006 also
2000 LC
www.sharetrails.org - Blue Ribbon
www.usaall.com - Utah
http://www.cohvco.org/ - Colorado
ColoradoCarlisle is offline   Reply With Quote
Old 09-04-06, 04:54 PM   #5 (permalink)
drsales's Avatar
I will also change out to JD bulbs. Did this on the 80 and will do the same with the 100. Never thought about the Slee but it also did help on the 80.
95 FZJ 80, Locked, 226k+, Original Stocked & HG, George's Map and Dome, PHH, Mobile 1, Slee Wire Harness, J.Deere Lights, 100 Series Pads, upgraded Stereo w/ XM and lots of Dynamat. Lost to the boys.
2000 100 series with 160k. Mobile 1 oil, diffs, trans and transfer. JD low beams. Upgraded stereo & speakers, Dynamat doors.
drsales is offline   Reply With Quote
Old 09-07-06, 05:53 PM   #6 (permalink)
TLCA# 16764
I just did this mod and Im very pleased with the light. I bought two 9005's for 8.00 ea. It was very easy and the fit with the two o rings is very tight. If it didnt work I was only out 16.00 and would have then bought the John Deer's. I would recommend this mod to anyone who likes to see at night!!!
2000 LC
Old 09-08-06, 12:14 PM   #7 (permalink)
Just Bought the Silverstars
They keep them behind the counter at VIP. ABout $10 apiece there- not the cheapest plaec, the closest though. Must be a hot item. I will install them tonight. Although I just thought I should have bought a second set for the high beams...and maybe the fogs as mentioned earlier. Best lights I have seen were on an older BMW, maybe they were Euro spec but they lit the road like a giant spot light, just unbelievable. I am not a fan of HID, had them on another vehicle, the light is whiter but they didnt seem brighter to me. Not sure why.
ericttz is offline   Reply With Quote
Old 09-08-06, 12:31 PM   #8 (permalink)
uzj100's Avatar
I like this solution. The JD bulbs are 28 each. It seems I can purchase six 9005s for $60. WIll the 9005s work for the high beams and the fogs also?
Thanks,
uzj100
00 - UZJ100 - Step Sliders, Diff Drop, 865s, FRB's, BAK - 285/75 R 16
03 - UZJ120L
uzj100 is offline   Reply With Quote
Old 09-08-06, 04:52 PM   #9 (permalink)
TLCA# 16764
Thanks,
uzj100
To me they would however the only problem Im having with my LC is the fog lights. The mounting system looks the same and the plug is the same. When I figure out why my fog lights dont work I will do this in them as well!
2000 LC
Old 09-08-06, 11:13 PM   #10 (permalink)
URBAN STRIKE's Avatar
Ebay Headlights!
HAS ANYONE TRY THESE HEADLIGHTS YET?
http://cgi.ebay.com/ebaymotors/98-TO...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/98-05...QQcmdZViewItem
1998 100 SERIES, DURANGOS LT315-75-R16'S,SOME TYPE OF BODY LIFT,FRONT SHOCKS RANCHO RS9000X, REARS RS5000, WILDERNESS ROOF RACK,OPTIMA YELLOWTOP BATTERY,CUSTOM HEADERS,DUAL FLOWMASTERS,FREE FLOW CATS,CROSS DRILL / SLOTED ROTORS AND XTRAS.......STILL NEED MORE MODS TO COME 2B1ASK1
URBAN STRIKE is offline   Reply With Quote
Old 09-09-06, 05:25 AM   #11 (permalink)
mot
I ruin surprises.
mot's Avatar
I've dealt with the first set (sold to an individual) but the fit'n finish is rather poor. Some of the holes to tighten upon installation do not line up properly.
I think the light is also not very good (at least on the low beam projector part).
Unless I'm planning on doing a projector xenon/HID grafting like hoser did I would not bother getting them. Not sure about the second pair though. Wondering if the low beams are for LHD or RHD (Didn't see the description too closely).
They're not too shabby-looking, are they?
Mot
Old 09-09-06, 11:21 AM   #12 (permalink)
Rookie
I was looking at that second pair as well and thought about combining with these...
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
I'd hate to drop the coin on it if it's junk though.
BTW, 1st post. Just bought a 2000 LC with 106k.
XAAMOTTOMAAX is offline   Reply With Quote
Old 09-10-06, 09:17 AM   #13 (permalink)
DMX84's Avatar
So what’s the best bulb John Deer or Silverstar? Is the added O ring on the Silverstar necessary for a good fit or is it just to make it seal better?
Are the JD’s any different as how they mount (do they need the modification).
It sounds like the lumens are similar between the two. I seem to recall some talk about the JD bulbs being made by another company (and not as good?). So what should I look for or stay away from when making this decision on the JD bulbs?
If both bulbs are equal, than the Silverstars are going to be easier (& cheaper) to get.
Thanks,
DMX
I may be vile and pernicious But you can't look away
I make you think I'm delicious With the stuff that I say
I am the best you can get Have you guessed me yet?
I am the slime oozin' out From your TV set"
I'm The Slime by Frank Zappa, 1973
98 Land Cruiser
01 Beta trials bike
71 GMC Shortwide truck
DMX84 is offline   Reply With Quote
Old 09-10-06, 10:17 AM   #14 (permalink)
hoser's Avatar
FYI, the Silverstar bulbs they sell at the local Pep Boys/ Kragens labeled Sylvania Osram Silverstar is not the same as the European Osram Silverstar +50. The former is no brighter, just whiter but at the expense of longevity. The later is supposedly a great bulb but is not commonly found here. Need to order them overseas.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 09-10-06, 10:59 AM   #15 (permalink)
DMX84's Avatar
So you would lean towards the John Deer’s then?
(Maybe I should start a poll on who like what brand.)
I want something that fits tight and wont give problems later. I don’t mind doing mods to the lamp, I’m just a little unclear why the second O-ring was used. I read somewhere that one bulb was slightly smaller and don’t know it this is the case for the Silverstar unit.
DMX
98 Land Cruiser
01 Beta trials bike
Old 09-10-06, 11:15 AM   #16 (permalink)
hoser's Avatar
Yes, between the John Deer HIR's and the Kragen bought Silverstars, I'd definitely go with the John Deers.
98 LX470
85 BJ70
Old 09-11-06, 06:28 AM   #17 (permalink)
I put some Silverstars in my girlfriends Corolla, they lasted 3 months and burnt out. It was very disappointing, and given the price, not worth the money. Maybe it was just bad luck but both went within days of each other.
90 VX Ltd, HDJ81 RHD, 1HD-T 4.2l turbodiesel, auto, BFG 285-75-16 AT's, 3" lift, 15mm spacers all round, OME heavy / medium springs, triple locked, JDM tube frt bumper, 3" mandrel bent exhaust, aeroturbine muffler, Safari Snorkel. SOLD - to backroads backpacker...
Martin White is offline   Reply With Quote
Old 09-11-06, 07:52 AM   #18 (permalink)
Everyone forgets there is a lighting faq that applies to 100's as well as 80's that will answer 90% of the above questions.
http://forum.ih8mud.com/80-series-tech/11932-faq-80-100-series-headlamp-auxilary-lights.html
You know your life is screwed up when you are getting divorced, fighting over custody, watching all of your money getting pissed away, being treated by her and her family as the anti-christ, and yet, finding your life has drastically improved.
cary is offline   Reply With Quote
Old 09-11-06, 04:16 PM   #19 (permalink)
You can get Philips and Osram bulbs from powerbulbs.com in the UK. They ship worldwide. I got the Philips +50 and like it better than the US Silverstar. Simple lighting options are less with the LX470 because I have H1 bulbs instead of 9006.
01 LX470, Golden Pearl (white)/ ivory
01 LC, jade green/ ivory (sold - mistake)
03 4Runner, Ltd, V8, 4WD (sold)
LXPearl is offline   Reply With Quote
Old 09-11-06, 05:08 PM   #20 (permalink)
mot
I ruin surprises.
mot's Avatar
Everyone forgets that you're a lighting fag and that applies here as well.
Mot
Old 09-11-06, 05:37 PM   #21 (permalink)
Mot
Be careful, I'm a lighting fag with an oil fetish, so I can be dangerous.
Old 09-11-06, 05:44 PM   #22 (permalink)
You don't have to go that far or spend that much.
http://www.rallylights.com/hella/H1.asp
Keep in mind that since you have H1 lamps, you are already starting with 1500 lumens instead of 1000 lumens stock, so you have a good start. The +50 gets you close to 1800 lumens, so you aren't missing anything.
Before anyone gets the bright idea of using 100 or 130 watt H1 lamps DON'T. If you do, don't come crying when the wiring and/or plastic headlamp housings melt down.
Old 09-15-06, 09:43 PM   #23 (permalink)
Remove the insert in the bulb socket
FYI I installed the silverstars- they are ok, brighter and whiter- may not last that long so I will get the HIR's. Anyhow on my 2001 in the bulb socket is a little brown adapter piece. If you pull it out with needle nose pliers you can stick the 9005's right in without filing the two ridges inside. I believe the two bulb sockets-for high and low- are both the same except for the added insert on the lows. So just remove it and skip filing the inside, which is a PIA because its a little tight. I can take a pic of the insert if anyone wants but its pretty simple to see if you pull your bulb out.
Have fun.
Eric
Old 09-16-06, 03:26 AM   #24 (permalink)
drsales's Avatar
Just installed the JD's in my 2000. Cost $9 each. I have had them in my 95 for one year with no failures. Started with the Silverstars and had a failure in 3 months. So you know where I stand.
Old 09-16-06, 09:46 AM   #25 (permalink)
hoser's Avatar
From the 80 section:
Originally Posted by Ivan80
Interesting Links to HIR information. The first one shows those who are curious how and where trim the bulbs. The second 2 are tested measurements in increased light output between HIRs and stock. The last link is lengthy but interesting in that it shows that 'silverstar' high beams actually put out less light than stock bulbs.
You may have to cut and paste the first two as they won't copy over as full links.
http://shnu.us/HIR%20Trimming%20Stock.htm
http://shnu.us/Bulb%20test%20and%20pix.htm
http://www.bmwcca.org/members/AM/Tem...e_Be_E36_Light
98 LX470
85 BJ70
