Navigation Override
I found on this on another forum and thought I share the info here. I read that it applies to 04-06 Nav systems, but I can only confirm that it worked on my 04.
Anyhow, this fix/override allows a destination to be entered while in motion. This great for having your passenger enter the destination while on the go. The only downside is that system defaults back to normal mode once you cycle the ignition. You can enable this at anytime while on the go. As always be safe. Steps: 1. Press Menu button. 2. On the screen that appears, there is a volume button--press it. 3. On this screen, there are no buttons at the top left corner and bottom left corner, but press in this order; Top, bottom, top and bottom (Upper left and lower left) . 4. A new screen will appear with multiple buttons. Press and hold the one titled "override"--it will change colors and BEEP. 5. Push the "Back" button to exit and you're good to go. You will notice notice other functions in this hidden menu, but I have not messed with them. __________________ 04 LX470 AHC 2" lift - 315 BF TKOs -Slee Diff Drop- ARB Compressor - ARB Fridge - 75 WXST CB/FireStik KW4-B Antenna - Husky Liners - DVD/Phone Hack 02 X-Cab 4WD Tacoma King Coilover 3" Lift - 33 BF TKOs - TRD SC/Gauge - Diff Drop - 75WXSTCB/FireStik K4W4-B Antenna - Husky Liners. |
anyone try this on an 03??? where did you hear about this?
__________________ 2003 LC, DVD bypass, Dunlop SJ5 winter tires, Husky Liners, 113,000 miles Looking to get lifted this spring. 1998 LC, sold at 90,000 miles |
You want to do what...?
ooooo, I gotta try that on the 03 too...
__________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD and souped up DR650 |
ill be trying it on my 03 in ten minutes
"top and bottom" meant *simultaneously* I imagine?
i didnt get it to work doing top, bottom, top, bottom on my 03
#7 | |
Sorry, no one at a time. Hit the top left then the bottom left, top left again and then bottom left again. CTapia __________________ 04 LX470 AHC 2" lift - 315 BF TKOs -Slee Diff Drop- ARB Compressor - ARB Fridge - 75 WXST CB/FireStik KW4-B Antenna - Husky Liners - DVD/Phone Hack 02 X-Cab 4WD Tacoma King Coilover 3" Lift - 33 BF TKOs - TRD SC/Gauge - Diff Drop - 75WXSTCB/FireStik K4W4-B Antenna - Husky Liners. |
#8 | |
Did you make sure you were pressing the upper left then lower left corners? __________________ 04 LX470 AHC 2" lift - 315 BF TKOs -Slee Diff Drop- ARB Compressor - ARB Fridge - 75 WXST CB/FireStik KW4-B Antenna - Husky Liners - DVD/Phone Hack 02 X-Cab 4WD Tacoma King Coilover 3" Lift - 33 BF TKOs - TRD SC/Gauge - Diff Drop - 75WXSTCB/FireStik K4W4-B Antenna - Husky Liners. |
left would be drivers side correct?
#10 | |
The topic came up on a thread here: http://us.lexusownersclub.com/forums...6&t=24807&st=0 Scroll towards the bottom. I went ahead an edited my last post asking if he knew how to enable this on an 03. __________________ 04 LX470 AHC 2" lift - 315 BF TKOs -Slee Diff Drop- ARB Compressor - ARB Fridge - 75 WXST CB/FireStik KW4-B Antenna - Husky Liners - DVD/Phone Hack 02 X-Cab 4WD Tacoma King Coilover 3" Lift - 33 BF TKOs - TRD SC/Gauge - Diff Drop - 75WXSTCB/FireStik K4W4-B Antenna - Husky Liners. |
#11 |
thanks. i hope it does work. would be great for the passanger to update info while on a road trip.
#12 | |
#13 |
I tried it out on my 1994 LC and it worked fine. You have to hold done the "override" button for a few seconds to make it work. Another cool button is the "gps" button. It shows the real time GPS coordinates. This cool for offroading (were the nav maps don't have nay info) and you can see you position compared to off-road maps.
__________________ TLCA # 15449 2004 UZJ100 ARB Bull Bar IPF800 Warn XD9000 BFG AT 285/65R18 OME Shocks T-bars w/866 springs Slee diff-drop ARB compressor Optima yellow-top |
#14 |
Did you ever find out if it will work in the 03s
#15 |
It works on my '03. I use it all the time.
#16 |
I can't get it to work on my '03
#17 |
i cant get it to work on my 03 either.
#18 |
I think it's different for us with the '03s. Go to menu, instead of volume, press the DVD button (on screen) in the top right hand corner. This will show you a version screen. Then you proceed with the top left, bottom left, top left, bottom left, & bottom right (with a full fingerprint). When the blue screen comes up, press override until it lights up (about 3 seconds). Then hit back and your done. Give it a try and let me know.
#19 |
wow, i got it to work with the new instructions, thanks so much.
#20 |
Hey, thanks so much. The new instructions did it.
#21 |
Works on 06
__________________ John 06 Land Cruiser - off-roader, blizzard buster, hunting rig, general "when the going gets tough" vehicle 07 Porsche Cayman S - track car 06 Audi A8L - family car that's great on the track too |
#22 |
Tried it on my '03...it works! Now what do all those other options on the blue screen do?
__________________ '03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's. '86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars. '01 Prelude SH: stock '00 Honda CRV: stock |
#23 |
2001 LX470 NAV Override
I found how to override the 2001 NAV based on Steph23's instructions - though it is a bit different than the 03: 1. Press MENU then select SYSTEM OPTION 2. Perform the 5 point hidden button routine: Top Left, Bottom Left, TL, BL, BR. 3. The Debug Diag screen displays with blue buttons 4. Press OVERRIDE DRIVE button (it turns from blue to green) 5. Press BACK (upper right) 6. Override is effective until ignition is turned off. __________________ 01 LX470, Golden Pearl (white)/ ivory 01 LC, jade green/ ivory (sold - mistake) 03 4Runner, Ltd, V8, 4WD (sold) Last edited by LXPearl; 10-16-06 at 05:33 PM. |
#24 |
#25 |
The same sequence that worked for LXPearl worked on my '02! In addition to allowing destination input on the move, the override allows you to play DVDs while driving.
__________________ Jake '99 Dodge Ram 2500 CTD... real trucks don't have spark plugs 2002 UZJ 100 with nav, pin 7 mod, 285/75-16 Revos... more to come '55 Willy's CJ5 'xx VW Sandrail |
#26 |
I wonder what is different on my '02. I did it and the destination input override worked but I still can't see DVDs in motion. Am I supposed to load the DVD in the same player as CDs...or is there somewhere else?
I'm going on a 3K mile vacation on Wednesday and this would be very helpful
__________________ '95 Defender 90 ST | '92 Range Rover | '95 Range Rover | '00 Range Rover 4.6 HSE | '74 Toyota FJ40 |
#27 |
that is terrific info!
in the FAQ it goes...! __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD and souped up DR650 |
#28 |
I did not get my DVD to work either - though I tried only once. I still had to raise the parking brake in order to get the DVD to play while stopped.
__________________ 01 LX470, Golden Pearl (white)/ ivory 01 LC, jade green/ ivory (sold - mistake) 03 4Runner, Ltd, V8, 4WD (sold) |
#29 |
You've got to ground the brake wire & snip the VSS to get DVD in motion.
#30 | |
![]() Sounds like it might be easier to just have a DVD player installed. __________________ '95 Defender 90 ST | '92 Range Rover | '95 Range Rover | '00 Range Rover 4.6 HSE | '74 Toyota FJ40 |
