Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 100-Series Cruisers
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
100-Series Cruisers Tech discussions for the 100-series, including the Lexus 470 models -- UZJ100.com
Thread Tools Display Modes
Old 09-22-05, 05:41 PM   #1
hoser
Lifer
hoser's Avatar
Garage
A343F vs. A750F Transmission Gears
I believe these are the gear ratios of both transmission available for U.S. UZJ100's. I got the numbers online.
Not surprising, 1st gear of the 5-speed is lower and the top gear is higher. Reverse is lower as well. The 5-speed looks pretty sweet in terms of gearing.
A343F "4-sp Auto" (Effective Ratio=Gear X Diff gear)
- 1st Gear 2.804 (12.06)
- 2nd Gear 1.531 (6.58)
- 3rd Gear 1.000 (4.3)
- 4th Gear 0.753 (3.24)
- Reverse 2.393 (10.29)
Diff Ratio 4.3
A750F "5-sp Auto" (Effective Ratio)
- 1st Gear 3.520 (14.43)
- 2nd Gear 2.042 (8.372)
- 3rd Gear 1.40 (5.74)
- 4th Gear 1.00 (4.1)
- 5th Gear 0.716 (2.936)
- Reverse Gear 3.244 (13.3)
Diff Ratio 4.1
I have the A343F. What's interesting is if I install 4.88's, my effective 1st gear will be 13.68 versus the A750F/4.1 combination of 14.43
98 LX470
85 BJ70
09 KK SportsRV
hoser is offline   Reply With Quote
Old 09-22-05, 06:24 PM   #2
e9999
You want to do what...?
e9999's Avatar
750 gears rule! I knew it!
and man, is that thing sweet to drive with! You 4 spd dudes will be amazed when you try it out!
and if somebody double checks these numbers, I'll put them in the FAQ!
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).
: '03: 125K
DDs: ex-Accord (seller's remorse), Prius
: souped-up DR650
Sponsor 09-22-05, 06:31 PM
Sponsored Link
advertisement
Old 09-22-05, 06:31 PM   #3
hoser
Lifer
hoser's Avatar
Garage
Can I drive your wife's Cruiser?
98 LX470
85 BJ70
09 KK SportsRV
Old 09-22-05, 07:00 PM   #4
bjowett
Supporting Vendor
bjowett's Avatar
You should try the Touareg Aisin 6 speed automatic w/ 4.15 first gear, 2.66 t-case, and 4.56 gears. Lexus has a 6 speed auto in their cars, probably the same family.
Brian
Modifying the modifications.
Jowett Engineering
jowettengineering.net
Project 200
Project FZJ80
Project IRS Tundra
bjowett is offline   Reply With Quote
Old 09-22-05, 07:48 PM   #5
macneill
Lifer
macneill's Avatar
Uhhh... man that is some complicated terminology, my brain hurts...
1981 FJ60 - 210K, OME, 33" BFG ATs, Surco Safari Roof Rack with custom Rod Racks, MAF header, Flowmaster Super 44 muffler.
2002 UZJ100 - 50K, OME 865, OME T-Bars, Slee Diff Drop, TJM T-15 AL, TJM RB8, TJM Rear Tyre Carrier, Toyo OC ATs, Warn Winch, AO Roof Rack, IPF 900s, PIAA 520s and 510s, Borla CAT back with SLP muffler.
Gotham City Land Cruisers
Yankee Toys
Bay to Blue Ridge Cruisers
macneill is offline   Reply With Quote
Old 09-23-05, 06:47 AM   #6
calamaridog
Lifer
calamaridog's Avatar
So how long is the A750F transmission compared to the A343F? Are they the same size? Is there any way to run the newer transmission instead of the older one? Would the old ECU work with the new transmission or is the transmission controlled separately?
Sorry, this is my first automatic I'm a manual sort of person.
2000 UZJ100 - sold and missed like hell
Any Toyota 4x4 and hopefully soon
calamaridog is offline   Reply With Quote
Old 09-23-05, 07:06 AM   #7
Greg B
Addict
Greg B's Avatar
For you guys running the 5 speed transmission, you could re-gear to 4.30 diff gears. These are definitely available and would take your 1st gear effective ratio to 15.136 vs. 14.43. I don't know if the 5% increase is worth the price of re-gearing, but it is an option. Also, it should be pretty easy to source some used 4.30's at a pretty low price. If you were already going to install ARB's, it might not be that expensive to add 4.30's at the same time. Just a thought.
2001 UZJ100 Land Cruiser
My Featured 100 Thread
Greg B is offline   Reply With Quote
Old 09-23-05, 03:26 PM   #8
Jim_Chow
Addict
Jim_Chow's Avatar
An alternative is to replace the entire front/rear diff w/ the 4.3's rather than sourcing the R&P's, especially if you can find a junk yard w/ a rolled '98-'02 100.
--Jim
Jim_Chow is offline   Reply With Quote
Old 09-23-05, 03:28 PM
Sponsored Link
advertisement
Old 09-23-05, 03:28 PM   #9
hoser
Lifer
hoser's Avatar
Garage
Preferably the 4-pinion front (00-02)
98 LX470
85 BJ70
09 KK SportsRV
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
