Recently on my '01, the Check Engine Light (CEL) came on along with the 'VSC Trac' and 'VSC Off' warning indidators. After driving around a bit and then restarting the engine a few times, all the lights end up going off.
This just started happening several times in the past few weeks and I'm curious if this has ever happened to anyone else and is it anything to really worry about. It appears to be a pretty random event; nothing in particular seems to trigger it. I checked the owner's manual and it says it may indicate an electrical problem in the ActiveTrac system.
Man, just goes to show you; the more complicated the machinery, the more there is to to go wrong with it.
Would you folks take it to the dealership for diagnosis with this particular problem or stick your trusted independent?
Thanks a bunch,
HT
Thanks a bunch,
HT
