08-17-05, 11:26 AM
need help with my door locks 04 LC
I'm obviously new to this forum...and new to the LC/LX arena. I was reading my manual trying to figure out how to change my door locks so they unlock when I put the shifter in Park.
The manuel says:
Put the parking brake on,
Turn the key to the ON position, put it in P (assuming they mean PARK)
Then to N (assuming they mean neutral)
Hold the back of the door lock on the driver's side (assuming they mean the Door lock switch on the driver's side door)...
All within 10 seconds of turning the key to the ON position.
Well, it doesn' t work. Either I'm drunk or the directions are clear on what they want me to do. Has anyone else had any luck on doing this.
Normally I wouldn't care if the doors stayed locked when I turned off the ignition since I have a new baby in the back I have to remember to unlock all the doors before I get out so I can open the back door. I would rather all the doors unlock when I put it in PARK. Thanks for the help! I'm going to drink another beer and anxiously await a reply!
08-17-05, 12:53 PM
I've heard people with 4runners talk about the programming. They couldn't get it to work at first, but it turned out that their timing was off. You have to do the timing right. And if you want to change a setting once it is reprogrammed, you have to program it back to default first. I would say, give these instructions a few more tries. Just be quick when you are doing it.
99 TLC w/ BF 305s & Kenwood DDX8017
95 Mustang Cobra convertible w/ 3.73 gears, X-pipe, flowmasters, K&N, King Cobra clutch, short shifter and factory hardtop
08-17-05, 12:56 PM
tlcwagons.org
I had problems getting my door locks to re-program. I know it's a different model (03 4Runner) but maybe it will help you figure yours out.
This is from another 4R owner:
I wanted to choose option (B):
All the side doors and back door are automatically unlocked when the automatic transmission selector in moved to the "P" position with the ingnition switch in the "ON" position.
The Manual says:
1.) close all the side doors and back door
2.) Turn the ignition switch to the "ON" position
3.)within 3 seconds after the switch is turned to the "ON" positon; pucsh and hold the rear of the power door lock switch for 5 seconds with the automatic transmission selector in the "P" position.
I did this several times with no success.
Then I read the manual again...
On the same page in a later paragraph it said;
All the side doors and back door automatically lock and unlock when you release the power door lock switch. This indicates the function is set. If all the side doors and back door do not loack and unlock, the time the switch was held may be too long or too short. Perform the procedure over again.
Anyway, I tried it again (being more careful to hold it down for the prescribed 5 seconds) and it worked.
08-22-05, 11:07 AM
Okay, first thanks for the quick help...I got it to work. Maybe I didn't take the directions literally like they are written, but you're supposed to let GO of the door lock after 5 seconds. I was just holding the door lock down, waiting for them to lock then unlock, signaling that the mode took.
Anyway, held the door lock for the count of 5, let go, then they locked and unlocked...ahhhh life is back to being easy again. Thanks for the help guys and errr gals.
11-03-05, 10:03 PM
would this work for an '00
anyone know if this will work for an '00 land cruiser or '00 4 runner? looked thru both manuals and see nothing.... and tried the above instructions and nothing (could just be user error thou).
i assume there are some factory settings that can be changed. my wife's 4 runner beeps when the doors are locked & unlocked, but my cruiser doesnt - its nice to not to have to stare at the lights to see if they flash & the doors lock when walking away from the truck.
11-17-05, 10:01 PM
anyone.... anyone........... bueller? is there someplace i can dig up this info - did a bunch of searches and came up with this thread only.
11-18-05, 06:50 AM
Rookie
Nope, a 2000 doesn't have that level of programability. I don't know about the 4runner.
_______________
2000 Land Cruiser
11-18-05, 04:52 PM
Dito sa bahay kubo ko
Coastal, I'd like to say that it will work on a 2000 Land Cruiser. I just programmed my 05 the same way.
I seriously doubt it will work on a 2000 Runner though. You might want to try www.Yotatech.com. Theres a wealth of knowledge there, mainly 4Runners of every Generation. I'll bet you'd find that answer there!
FYI: I checked out the programming details for a Lexus blah, blah, blah 300 (car) and found that the door programming codes are way different than any Yoter I've ever owned. Maybe it's determined by the model and not the entry system. Any thoughts?
Bueller?
Doug
1971 40
2005 100
2003 4Runner Pick up
Honda TMX 125cc w/ side car
11-18-05, 10:05 PM
Ultra - appretiate the tip, I will check out that web site. There has to be a way to set the alarm to beep or honk when the doors lock on my '00 cruiser.
11-24-07, 04:09 PM
#10 (permalink)
Bumping this back up to the top. Is it possible to completely disable the automatic lock feature? It drives my dad (his 100) absolutely nuts and me too when I drive it.
If not, I guess we'll settle for the mod above, but I'd really like the truck to just leave the doors unlocked when you put it in gear.
Ary
HOKIES UNITED
Mobile Base Camp Trailer Build
Arya Ebrahimi
'94 FZJ80 220k miles, locked, 4.88s, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
'86 Toyota Pickup SAS'ed, welded, 4.88s, 38 TSLs, and lots o' tube
12-14-07, 12:23 AM
#11 (permalink)
Ary
I've got the opposite problem. I'd love it if the doors automatically lock when I put the 100 LC in gear. Perhaps someone disabled this feature on mine. I'd love to reconfigure it!
Anyone have any ideas?
Dwon
http://www.OregonPhotoSafaris.com
2001 UZJ100 (07-29-2007)
Toyo Open Country MT 285.75R16 (09-01-2007)
ARB Bull Bar (09-13-07)
ARB Roof Rack (09-13-07)
IPF Lights (09-13-07)
OME Firm Valve Shocks (09-14-07)
OME Springs / Tbars & Slee Drop Diff (09-14-07)
Warn 12K winch
05-11-09, 11:51 PM
#12 (permalink)
Yes I am posting to an old thread, but it is in the FAQ and I have found/compiled information about programming the door locks not already posted in the FAQ. Hope others find it useful.
You can select the following modes of the automatic locking and unlocking functions. The initial mode is mode 1.
Mode 1—Automatic locking operation linked to shift lever position
All doors are automatically locked when the shift lever is moved out of “P” position after the ignition switch is turned to the “ON” position and all the doors are closed.
Mode 2—Automatic locking operation linked to vehicle speed
All doors are automatically locked when the vehicle speed goes above about 20 km/h (12 mph).
Mode 3—Automatic unlocking operation linked to the ignition switch All doors are automatically unlocked when the driver’s door is opened within 10 seconds after the ignition switch is turned to the “ACC” or “LOCK” position, or the key is removed.
Mode 4—Automatic unlocking operation linked to shift lever position All doors are automatically unlocked when the selector lever is moved to “P” position after the ignition switch is
turned to “ON” position.
SETTING FUNCTIONS
Do all of this within 10 seconds of inserting the key. Make sure to hold for exactly 5 seconds.
You can set the following functions by yourself. To set the mode 1 (the automatic locking operation linked to shift lever position):
1. Set the parking brake, close all doors and turn the ignition switch to the “ON” position.
2. Shift the selector lever into the “P” position.
3. Press the driver’s side power door lock switch on the front side for about 5 seconds, within 10 seconds after the ignition switch is turned to the “ON” position.
4. The doors will be locked and unlocked to indicate that the function is set. To cancel the function, do the above operation again.
To set the mode 2 (the automatic locking operation linked to vehicle speed):
2. Shift the selector lever from the “P” into the “N” position.
To set the mode 3 (the automatic unlocking operation linked to the ignition switch):
2. Shift the selector lever into the “P” into the “N” position.
3. Press the driver’s side power door lock switch on the rear side for about 5 seconds, within 10 seconds after the ignition switch is turned to the “ON” position.
To set the mode 4 (the automatic un-locking operation linked to shift lever position):
Not all who wander are lost.
2003 UZJ100 - Bone Stock for now (but it gets the whole fam there)
2007 Specialized Rock Hopper Pro Disc in Mango - The Captain Armadillo tires, Shimano clipless pedals, XT low-normal rear derailleur, XT chain
05-12-09, 05:13 PM
#13 (permalink)
OK well i Tried a few times..Well more then that..Just wont work..I think the codes are for the newer LC's. Which doesnt make sense since I had an 80 series with a factory alarm and it did work. OK so does anyone else have a 98 or 99 and are able to set the doors to unlock automatically?
Sold my 80 to Nemo. New ride update. White 99 UZJ100. Rear Locker. No Mods yet.  Ok tires but is this really a Mod? XM/DVD Player. No signal no problem.
05-12-09, 05:23 PM
#14 (permalink)
I'm going to try it tonight on my '99 LC. The alarms on the 80s were dealer or port installed, they weren't OEM. Most were a Viper 3000.
05-12-09, 05:32 PM
#15 (permalink)
My 80's alarm FOB had the toyota symbol on it..Well the hat looking logo thing. Is it still a viper?
05-12-09, 06:34 PM
#16 (permalink)
Perhaps I should have put an extra note in my post about making sure that you hold the switch for EXACTLY 5 seconds (or maybe just take out the part that says about 5 seconds). Anyway, in the first part of the instructions I posted it indicated exactly 5 seconds... and my experience is it has to be exact. I changed mine then went to change it back and couldn't, turns out that exactly is the key word (I did get it to program again with an exact 5 second count).
Good luck. I hope it does work for pre 2003 trucks.
05-12-09, 08:25 PM
#17 (permalink)
No workee on a '99. Poop, I would have loved that.
05-12-09, 10:46 PM
#18 (permalink)
So I think I found the answer to a few questions here. There was one very helpful thread on YotaTech, and some others around... plus my memory was jolted about the 2000 Tacoma I owned.
The alarm system that was very likely installed on the 80 series in question with the Toyota key FOB would have been the VIP RS3000. This had the functionality to lock when the ignition was turned to on and unluck when turned off. This is exactly what my Tacoma did (took some getting used to), and it had the VIP system installed from the factory/dealer (probably RS3000 don't remember for sure). This would have also had the Piezo chirper.
The biggest question I have not been able to find the answer to is what year was the auto lock feature endowed to the Land Cruiser. Was it all 100's? Doesn't sound like it in this thread. I am pretty sure my 2000 LC auto locked. Did 98 & 99 just miss out, or am I rembering wrong with my 2000? Maybe it started with the other updates for 2003. Or maybe when they started adding Nav?
