Putting together some info for the FAQ.
Here are some links to some helpful sites when it comes to Land Cruiser stereo. This looks like its for the in dash 6 disc. http://carstereohelp.net/wireharness_Toyota5.htm Wire harness to hook up an aftermarket stereo to the factory amp http://www.audiooutfitter.com/store/TA03B.html This is for the single cd player http://carstereohelp.net/wireharness_Toyota4.htm Wire harness to hook up an aftermarket stereo to the factory amp http://www.onlinecarstereo.com/CarAu...roductID=14104 This is looks like it is for the factory amp http://carstereohelp.net/wireharness_Toyota1.htm For a single-din aftermarket deck, you will need a dash pocket to fill in the empty space. Here are a couple that will work. http://www.audiooutfitter.com/store/88-00-8000.html http://www.etronics.com/product.asp?stk_code=ameupk750 I have had good luck buying stereos from www.etonics.com. Cheaper than most. I recommend buying a upper end stereo with lots of equilizer and crossover adjustments. They are worth it. You paid more for a nicer auto. Pay more for the nicer stereo to go in it. The factory amp is underneath the passenger seat. The door speakers are 6 1/2". Maybe someone else can add the speaker depths and any possible subs that will fit in the factory sub location. Also, anyone else with any other helpful links? __________________ 99 TLC w/ BF 305s & Kenwood DDX8017 95 Mustang Cobra convertible w/ 3.73 gears, X-pipe, flowmasters, K&N, King Cobra clutch, short shifter and factory hardtop Last edited by LonghornCruiser; 10-12-05 at 02:19 PM. |
You want to do what...?
anybody cares to add or comment?
(considering this thread for FAQ) __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD and souped up DR650 |
how about some pics? I have more also
__________________ Scott Porterfield 99 LC, River Rock, 148k replaced my 95 Jade Green Metallic LC 209k "Just because you have a library card doesn't make you Yota" |
I will comment having done this recently.
The radio install and amp install is quite easy. The issues come when routing wires i.e. I would not buy a generic wire kit with a 16ft RCA cable. 8 feet would be more than enough. Crutchfield is where I purchased ALL of my stuff minus the Eclipse Radio. They shipped that day and I received it within two days. I did not do the Dynamat thing and my system sounds very good. However, I plan on going back and doing the front and rear doors. It would be VERY easy to do considering that layout of the door-use the plastic dampening sheet as a guide. The LC door is quite thick and the ride is quiet as is but perhaps an improvement can be made. I cannot speak for other systems but my system sounds quite well in my LC: Eclipse 5405 Polk db6500 Polk db650 Infinity Reference 7451 Amp Infinity Basslink Sub I almost went with a Polk Momo amp/speaker set up but I have heard over and over that the db's are just as good (if not better depending on music preference) due to their silk dome tweeter. Juke __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
The 8 ft rca wire is plenty to go to the amp underneath the passenger seat. If you hook up a sub amp in the rear, like I did, you will need the longer wire.
__________________ 99 TLC w/ BF 305s & Kenwood DDX8017 95 Mustang Cobra convertible w/ 3.73 gears, X-pipe, flowmasters, K&N, King Cobra clutch, short shifter and factory hardtop |
Anyone have info on the output from the factory deck/amp???
I will have it all replaced (most likely) at some point, but would like to start w/speakers and don't want to screw-up a good set of aftermarket speakers by running them on the factory deck/amp combo. I had a sales guy (who I suspect is full of it) tell me that running high-end speakers (most likely components for the front) on the stock setup would ruin the speakers. This sounds completely absurd to me as I can't imagine "too little" wattage to the speakers would hurt them...only would not reap the benefits of the new speakers as they are designed to operate at their best with more wattage. Any thoughts? __________________ "I only have one rule! Never bet money you don't have, on a dog race, with an x-girlfriend, who happens to be a stripper..." |
I,ve never heard of speakers getting ruined by lesser wattage. The sales guy is just trying to sell you an amp and rewire. He is full of it. You are correct.
IH8MUD No-Lifer
I'm not siding with the sales guy but it is easier to blow a speaker (rated at 100w) with a 10 watt amp than a 300 watt amp. At least one of the stock speakers is rated at 2 ohms. Using a 4 ohm speaker would reduce the amplifier output even more.
__________________ 98 LX470 85 BJ70 |
I don't understand the logic that it is easier to blow a 100 watt speaker with a 10 watt amp over a 300 watt amp. Can you please explain?
125 watt amp, I would understand, but 300 seems excessively too much. I mean, i understand that a smaller wattage amp will put more "garbage" into the speaker because it is trying to operate beyond its means, but I would think that a 100 watt speaker would be able to handle that. May not sound good, but it doesn't seem like it would create enough disturbance to hurt the speaker. My guess is that the Cruiser factory amp pushes around 20-35 watts per channel which should be fine for 95% of 6 1/2 inch speakers. Although, a more powerful , but not too powerful, amp will give you better sound. __________________ 99 TLC w/ BF 305s & Kenwood DDX8017 95 Mustang Cobra convertible w/ 3.73 gears, X-pipe, flowmasters, K&N, King Cobra clutch, short shifter and factory hardtop Last edited by LonghornCruiser; 07-07-05 at 10:58 AM. |
#10 |
Actually, and I know this becasue I build guitar amplifiers for professional music, a 10 watt power source i.e. amp/tubes/whatever will not "blow" or ruin a speaker faster than an overpowered power supply. Speakers are rated at an RMS and a Max. Both are figures that are not exact i.e. each speaker company has its own formula and this goes across the board from guitar amp speakers to car audio to XXXX. Anyway, I own and have played amps that are in the 10w power supply range running into 25 and 35 watt speakers for over 50 years-as in the speaker has lasted that long in its original condition. As a matter of fact, many guitarists are looking for that exact sound that is caused from underpowering an amp. You lose clarity across the board when this happens but you do not ruin a speaker. A speaker is ruined by 1-time or demagnetization or 2-massive amounts of power and coil tear/component failure. These folks that are telling us that the factory amp will ruin component speakers are on crack. The 100 already has component speakers and they are crossed over at the tweeter i.e. the tweeter has a capacitor on the + that serves as a high pass filter.
More power = more clarity particular in the lower Hz. That is really all we need to be aware of and considerate of when buying. I have no doubt that my Polk db's would have run off of the stock amp-they are rated at 10-100 RMS at a 92db sensitivity (very efficient). __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#11 | ||
IH8MUD No-Lifer
I have no problem changing JUST the speakers and keeping stock amplifier in place. But I can sorta understand why somebody would make the comment about damaging a speaker with an underpowered amp. But in order to blow the new, high-end speakers, the operator would need to overdrive the amp into clipping. With road noise and the windows down, it can make detecting clipping a bit harder. I will admit there are several schools of thought on this subject matter. None have really been proven. I just cut this from another forum that better explains it: Quote:
http://www.electrosound.com/Speaker_Facts/v6no2.htm __________________ 98 LX470 85 BJ70 Last edited by hoser; 07-07-05 at 03:36 PM. |
#12 | |
IH8MUD No-Lifer
Instrument speakers generally have wider but shorter voice coil windings. At the limit, the coil starts to leave the linear part of the magnetic field and the stiff suspension is what keeps the speaker in control. The cone excursion is limited much more smoothly at its extremes than a hi-fi speaker. In short, they can take more "abuse," at the expense of accuracy. But, yes, I realize it is a whole 'nuther beast that I know little about.
#13 |
I used the Scosche TA03B, which is a 2000+ Toyota Amplifier Interface (harness) with my 2000 LC. It seemed to work fine so far with my Kenwood EZ700SR single din unit.
__________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#14 |
Need $ for Mods
It seems like some links are not outdated - thought I would add that I am looking at the Crutchfield site and it seems like they can deal now - from the past, I used to think that site was outdated.
I think I am going to go with a single DIN Alpine and Crutchfield includes the other din slot tray and the cable with the order. Free shipping too! I was chatting with them and they told me its all I need. My only confusion was the amp cable going to the passenger seat? I am hoping this is for a bypass and not using the factory amp. I did this on my 4runner and had no problems. __________________ 2000 LC - 'The Black Pearl' 120K. 285/75/16BFG's DIY'r: Timing/serp/H20pump,Black Pearl emblems, Trim. Pioneer 1-din. 2001 Fleetwood-Coleman tent trailer. Daily Commuters: Trek Madone 5.2 / Scott Comp Racing MTB LIVESTRONG |
#15 |
I just received an Alpine 9883 from Crutchfield today and will be installing tomorrow. What issues did you have? Was the factory amp ok? Did you replace the speakers as well? Thanks alot.
__________________ LCFlyer 93 FZJ80 Green, 258k, completely stock. 00 FZJ100 Silver, 160k, wife's daily driver 03 Honda S2000, Black, fun daily driver |
#16 |
Does anyone know the wattage of the stock amp?
#17 |
Just found lable on my Nakamichi amp (99LX470):
Max. Power: 40Wx4; 100Wx1. Load impedance: 4 Ohm. __________________ 1999 LX470, 130k 2000 4Runner, 140k |
#18 | |
http://forum.ih8mud.com/100-series-cruisers/170647-kenwood-ddx-6019-99lx470.html __________________ 1999 LX470, 130k 2000 4Runner, 140k |
#19 |
Juke - where did you mount your Infiniti amp? I put one of these in my 500SEC and it ROCKS. Does it fit under the pass seat?
Last year I replaced the stock h/u with a CarPC... so sorry! wanted to integrate a whole bunch of other components (XM, I-Pod, IC-7000 Ham rig, b/u cam, GPS, DVD, USB Radio, etc), spent a month just working the schematic. and another 3 weekends installing the cables and components. It took my ego an entire year to come to terms with my mistake, but I finally gave up - the experiment failed miserably: tiny font on a washed-out LCD touchscreen, incessent Windows boot time delay (vs battery drain in standby), *no* 4-ch sound for anything read off the drive! It sucked (small consolation I could get WiFi on the road). A few months ago I gave up & yanked the PC and went with an Avic-Z2. What a difference - I can actually read the screen during the day, and it interfaced easily with all the peripherals. the OEM speaker/amp wiring hookups were trivial (Scotche connector there). Only problem now is the factory sound is weak, it's time to upgrade those components. soooo - looking for decent speakers and an amp FWIW, I didn't want to invest in Dynamat as there are less expensive paths: head down to your local Big Box Home Improvement center. there you'll find 12"w x 50' lg x 1/16" thk rolls of adhesive-backed asphaltic roofing seal for about 1/4 the cost. my son & I plastered his car with this stuff and avoided needing much larger amps. |
#20 | |
There are probably plenty of good alternatives to overpriced dynamat though. __________________ 1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts 1999 Toyota Camry - So Boring |
#21 | |
, but then again these rolls didn't have any such odor even when we were buying them. after 2 years or occasional use (it's stored in one of those "enclosed canopy" structures but sees >100-deg summers) the only odor is from the new carpet kit
__________________ 00 100 315 Toyo O/C MTs, 3" OME hvy, Slee rear bumper/sliders/bat tray/d-drop. AVIC-Z2. IC-7000 Tech+ KE6HRR 01 4Runner (wifes'... can't mess with it) 98 RAV4 (for the kids: dad, I *need* a new stereo) 84 500SEC (donut runs only) ex -40 ('73 chevota) |
#22 |
I would research all the options of sound dampining b/f I put anything into a 100 series. Its not my 62 or a 40 that you sre tryign to quite down. Roofing asphalt will smell bad if it gets hot enough, much better things at a reasonable cost out there.
__________________ '93 FZJ 32K miles 850/863's, Baja 540c, Lightforce 240, and 40L Norcold waiting. '89 FJ62 - 4" Alcan, 33" BFG MT's, 4.88's, Lockright (rear), 4runner calipers, & 3' firestick. Cruise in the garage. FOR SALE! '97 4Runner SR5 - 4x4, leather, '06 4runner rims, 265/70/17 Toyo AT, TJM T-15, 3 baby seats. (Wife's DD) '83 FJ60 - DooDoo Brown in and out FOR SALE! '63 Biscayne Wagon - Kandy Green and Tweed. Family Wagon 3rd row in the garage. Erskine College Upstate Cruisers |
#23 |
I've only used dynamat extreme in mine. I was able to get a great deal off of ebay.
__________________ 04 LX470 |
#24 |
Keeping it Weird
Has anyone put in a 6 disc version into a 1998-1999 LC with the single disc player? I am upgrading my headunit and was going to see if my buddy could use this in his 1999.
__________________ David Gonzalez ------------------- "Penny" Bronze 2000 100-series 33" BFG A/T's, storage drawers, OME Heavy Lift Austin, TX david.gonzalez@gmail.com Lone Star Land Cruisers Last edited by davegonz; 08-20-08 at 07:17 AM. |
#26 |
Need $ for Mods
Example of Single Din replacement
Pioneer 4000 - inexpensive choice, but I can plug in my MP3 player in the glove box with th |
