Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 100-Series Cruisers
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
100-Series Cruisers Tech discussions for the 100-series, including the Lexus 470 models -- UZJ100.com
Thread Tools Display Modes
Old 07-03-11, 12:01 AM   #1
FullyLitLED
Lifer
FullyLitLED's Avatar
Question about the DRL/hi beam circuit
So on the DRL/hi beam circuit on the 100 series, I heard that when the bulb in that spot is acting as a DRL...it is basically working at half power.
Does that mean that the bulb is operating at 6V rather than 12V when in DRL mode? Or does it have something to do with amperage or some other electrical term? Dumb question but thanks in advance
1998 Desert Bronze Metallic 100 Series LC: It's got some stuff
Too busy with school and work: Temporarily not selling LED kits. Be back in January For now, my free time goes into enjoying the hundy and researching better components
FullyLitLED is offline   Reply With Quote
Old 07-03-11, 08:21 AM   #2
petrotk40
Addict
petrotk40's Avatar
Garage
based on the one elec engr class I took in college, I'm going to say it will still be 12v, just at a lower amperage. I'm sure it's routed through a different circuit with a resistor to cut the amps, but the voltage should still be 12v.
are you wondering if the reduced amps will kick power your ballasts? or just the angel eyes?
2000 LC Champagne Pearl | 285 NTG | OME863 | BIOR HC Rear | Morimoto BiXenon
Green Country Cruisers
TLCA 21434
petrotk40 is online now   Reply With Quote
Sponsor 07-03-11, 08:23 AM
Sponsored Link
advertisement
Old 07-03-11, 08:23 AM   #3
SHAGGY101
SHAGGY101's Avatar
Garage
Exactly
2000 UZJ 100 - White & Graphite - With lots of STUFF
FS: 100 Series Slip on Wheel Spacers!
http://forum.ih8mud.com/sale-parts/6...ml#post8219883
SHAGGY101 is offline   Reply With Quote
Old 07-03-11, 08:27 AM   #4
petrotk40
Addict
petrotk40's Avatar
Garage
hooray! my crazy polish lady prof would be so proud!
TLCA 21434
Old 07-03-11, 08:46 AM   #5
sonk76
sonk76's Avatar
Garage
Hmm...
Given that Voltage = Current * Resistance (V = IR), then he only way that the current could have decreased with the voltage being constant is if the resistance in the system had changed (e.g., by adding an extra resistor into the circuit.) While possible, it is a bit of a waste of energy to be using electricity to just "heat" the resistor instead of using it for light output. And I'm not aware of variable resistance light-bulps.
From my naive perusal of the wiring diagram, I had come to believe that when in DRL mode, the two lights were in effect wired in series, and there by the voltage drop across each light would be 6v in this case (which would of course then reduce the current proportionally)--just as the original poster had suggested.
I could be wrong, but that was my understanding (I was looking at this before to see if I could use the DRL/High-beam signal as an input into a relay that would turn my driving-lights on/off, and but abandoned the approach due to the relative complexity in this wiring.) Happy to be educated otherwise...
06 LX | Armored | Geared | Locked | 35's
sonk76 is offline   Reply With Quote
Old 07-03-11, 09:08 AM   #6
SHAGGY101
SHAGGY101's Avatar
Garage
In my opinion it could be done either way. It just seems more likely (to me) that a consistent 12V source would be kept around the whole vehicle and that the resistance would just be changed (given ohms law), like a dimmer switch. This, however, is based upon not looking at any wiring diagrams so I could be wrong.
LJ, why dont you just get a multi meter and test it?
Old 07-03-11, 09:55 AM   #7
FullyLitLED
Lifer
Its just for the angel eyes! There is currently nothing(in terms of bulbs) plugged into my DRL and hi beam socket so I can plug in anything I want into it...in my case the angel eyes for DRL mode, I have the bixenon wiring spliced into the oem hi beam/drl circuit though
Originally Posted by sonk76 View Post
Hmm...
Its like circuit analysis class all over again lol
I have one, I need to find it though
In another case, I would not mind hooking up my angel eyes to the heated seats or the cig lighter so they can be on whenever the car is on...which method would be better?
Or what 12V source would you guys use?
Old 07-03-11, 08:22 PM   #8
hankinid
The DRL relay puts the high beams in series, so they're effectively seeing 6V.
Steve
'01 LX470...
hankinid is offline   Reply With Quote
Old 07-10-11, 05:26 PM   #9
SHAGGY101
SHAGGY101's Avatar
Garage
False. They are wired in parallel. There is most likely a resistor somewhere in the circuit that could be below the driver side headlight, in the engine compartment electrical box, or to the left of the steering column under the kick panel. I know that FJs have a resistor in front of the battery. This is where I will start.
Reference these threads:
http://forum.ih8mud.com/100-series-c...estion-lc.html
http://forum.ih8mud.com/fj-cruiser/9...y-options.html
Old 07-10-11, 10:10 PM   #10
1loudLX
Lifer
1loudLX's Avatar
be really easy for you guys to figure it out if you had the EWD
LJ, if you're going to wire the CCFLs to turn off when the low beams are on, you can take a signal wire from the low beam harness and use that to trigger a relay. When the relay circuit is open, you can make that feed power from your seat heat you did to the CCFLs and when the headlights turn on and trigger the relay you added, they'll disable the CCFLs.
If you want to be able to pull up the ebrake and keep the CCFLs off when you turn the ignition on like factory, then you're going to have to do some serious wiring which IMO isnt worth it. You could also put a switch from the seat heat lead to the relay which would turn the CCFLs off completely unless you closed the switch. There are a dozen or more ways to do it but those are some. I was actually looking at the DRL system in my EWD yesterday and there are definitely ways to do what you want just need to spend the time to do it.
2000 Lexus LX470 - Stealth mode: Engaged
2005 Lexus LX470 - ExPo White/'mud Black
2005 Lexus LS430
hidden message
1loudLX is offline   Reply With Quote
Old 07-10-11, 10:16 PM   #11
1loudLX
Lifer
1loudLX's Avatar
oh and the resistor is next to the airbox on the PS fender. At least on the LXs, there was a campaign to dim the DRLs more as they were too bright from factory. Some of you may find another resistor with two wires going back into the DRL relay #3 with a harness that connects to the original wiring and the relay box.
2005 Lexus LS430
hidden message
Old 07-10-11, 10:19 PM   #12
OregonLC
Brown Thunder Roles
OregonLC's Avatar
Garage
Is there any reason why you couldn't just come off where the ECM powers the DRL relay? Just a simple splice into that line to give signal to whatever else you desire, right?
2000 UZJ100 | DT Headers | 295/70R18 NTG | Tundra 18" | OME T-Bars | 866 Springs | Slee Diff-Drop | Ironman Front | BIOR Rear | MetalTech Sliders | MetalTech Rear Links | Radflo 2.5" ET Remote | TC UCA
OregonLC is online now   Reply With Quote
Old 07-10-11, 11:05 PM   #13
FullyLitLED
Lifer
this is brilliant! Lol I need to figure out how to use relays but I will give this a try later on this week! Thanks loud!
Old 07-10-11, 11:13 PM   #14
SHAGGY101
SHAGGY101's Avatar
Garage
Would you happen to know where this wiring harness is or which wires are what? How did you come by the EWD anyway?
Old 07-10-11, 11:14 PM   #15
1loudLX
Lifer
1loudLX's Avatar
you can, that's a +12v signal as well. trying to keep it simple for LJ since he already knows where the wires i was talking about are.
2005 Lexus LS430
hidden message
Old 07-10-11, 11:17 PM   #16
1loudLX
Lifer
1loudLX's Avatar
there's a newer model one floating around the interweb but I've got all the paper manuals and the ewd for a 2000 LC. I'll go figure out which wire comes off the main DRL ECU and which it is going into the DRL relay #3 that's by the airbox
2005 Lexus LS430
hidden message
Old 07-10-11, 11:38 PM   #17
1loudLX
Lifer
1loudLX's Avatar
there is a Red w/ Yellow stripe wire that comes out of the DRL Main relay that triggers the dimmer relay which then sends power from the battery to the HEAD(LH-UPR) fuse to the LH highbeam then to the RH one and then into the DRL Relay #3 which then goes to ground. Looks like the lights are indeed in series for the DRL. Once there is signal from the combination switch to trigger the HEAD relay, the low beams both get power and there is a signal wire from the HEAD(RH-LWR) that goes to the DRL Relay #3 that triggers both relays inside there and disables the DRLs.
yeah, it's confusing.
edit: there's also a signal that goes from the combi switch to the main DRL relay that tells the system to turn off the dimmer relay. Once you put the combi switch to the high position, it'll reactivate the highbeams at full brightness because of that signal wire from the low beam to the DRL#3 relay I mentioned before
2005 Lexus LS430
hidden message
Old 07-11-11, 12:05 AM   #18
SHAGGY101
SHAGGY101's Avatar
Garage
Wow, and I thought getting my head unit wired up without the factory amp was confusing! Thanks for the info. I was under the lights were in parallel because the voltage read 12V in DRL mode...adding to the confusion...
Old 07-11-11, 12:11 AM   #19
1loudLX
Lifer
1loudLX's Avatar
I could be wrong, but that's how it reads and looks.
2005 Lexus LS430
hidden message
Old 07-11-11, 01:59 PM
Sponsored Link
advertisement
Old 07-11-11, 01:59 PM   #20
SHAGGY101
SHAGGY101's Avatar
Garage
Thanks for the help Loud, PM sent!
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
