- Joined
- Feb 10, 2002
- Threads
- 547
- Messages
- 44,667
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
After I leveled out my stock suspension with a torsion bar tweak, I found that any load, even the smallest really squatted the ass of my 100 to an unacceptable level. Of course, that is one of the reasons for the factory stinkbug stance....to take a load and not squat so badly.
I had two choices, Air Bags or OME rear lift springs.
I chose the air bags over the heavier duty springs because I did not want more lift or to go back to the daily stinkbug look.
Doing an Air Lift install is dead simple. This is a job and the results for the money are outstanding.
I bought the kit for $85 shipped here:
1991-2006 Toyota Land Cruiser - "Air Lift 1000" Air Helper Springs [REAR] - 60728 | $85.16
Install is a snap. I jacked up the entire rear of the truck until the tires were right about to clear the ground and placed jackstands under the rear class 3 hitch bar.
Next, I jacked up one side of the axle near the tire and pulled the tire, then the bottom shock bolt and finally the sway bar nut/bolt.
Next, Let the axle down completely and pull out spring from the bottom.
Remove and toss the rear bumpstop with 12mm and long extension. Bolt is in the center of the bumpstop.
Now, get a 3/4 step-bit (huge help) and drill out bottom spring perch to 3/4" Make sure the hole is nice and smooth. Some people line the hole to keep from Chafing if you flex your truck out a lot. I have run these before in an 80 and I did not have problems with chafing so I did not line the hole.
Stuff the air bags in the springs from the top and attach the air hose. Feed hose through hole in perch then reinstall the spring.
Rebolt the shock and sway bar and put the tire back on.
Repeat on other side.
