Hi Everyone,
I've been dealing with a frustrating problem for the last six months or so. Intermittently, our 1999 UZJ100 (152K miles) drops dead. One instant we're at full power, the next the tach drops to zero. My wife drives it, and it's potentially dangerous - I'd hate to be making a left turn and have it do this. I haven't been able to establish any sort of pattern. Mostly it drives fine, and the problem pops up here and there. The problem has intensified to the point where it can't be driven three times in the past six months:
1) The first time, a buddy and I poked around at this and that, but in the end all we really did was clean some ground cables. The problem went away for a bit.
2) The second time, I brought in into a shop, where it actually died while they had it hooked up to a diagnostics machine. They didn't get much out of that - when they returned it, it did not have the problem for a while, but they said they had just cleaned some fuse box contacts.
3) The third time, I cleaned the mass air flow sensor, checked the snorkle for leaks, cleaned the throttle body, and replaced the air filter. The problem went away for a while, but now it's starting to crop up again.
I tried a different (paid) forum for this...here is my original post, the answer I received, and then my reply:
ORIGNAL POST
99 Toyota Land Cruiser 155k miles Car intermittently drops dead, either while moving or at idle. If moving we usually have to stop it, put it in park, and start it. It usually restarts easily but sometimes it's hard to start. When moving fast (+55 mph) sometimes you can pump the gas pedal and restart it while still moving, without turning the ignition key. We took it to a local shop. It died with the code analyzer on it, but they were not able to determine anything useful from this. They returned it after 'cleaning some relays'. For a few weeks the problem didn't return-and now suddenly it is worse than ever. History: We've lost 3 cylinder coils in the past 2 years - 2 of them were on cylinder 8. The 2nd time we lost one on cylinder 8, it wasn't a new coil-the old coils had been rotated. A few years ago we had intermittent starting problems. We'd park it and when trying to restart it wouldn't start. The engine turned but didn't catch. Cleaning fuse contacts solved the problem.
Optional Information:
Year: 1999
Make: Toyota
Model: Land Cruiser
Engine: V8
Already Tried:
Cleaning fuse box relays, ground cable connections. This seems to make things better for a time, then the problem returns worse than ever.
TECHNICIAN REPLY
You could have a bad mass air flow sensor. Or the snorkel from the mass air flow sensor to the throttle body could be ripped. Both are very common and can cause you vehicle to loose power along with many other drive ability issues. First look for cracks or rips or anywhere air can enter the engine that is not accounted for by the mass air flow sensor. Next comes the Mass Air Flow (MAF) sensor. This is a very important sensor input to the computer. It uses a hot wire sensing element to measure the amount of air entering the engine. The MAF sensor then outputs an analog voltage signal to the PCM proportional to the intake air mass. The PCM calculates the required fuel injector pulse width in order to provide the desired air/fuel ratio. If the sensor is bad than this air/fuel ratio will be off causing severe performance issues. In extreme cases, I have seen these two problems cause a no start condition. This input can also be used in determining transmission Electronic Pressure Control, shift and torque converter clutch scheduling. The check engine light may even pop on if the sensor is bad, the snorkel is ripped or a tube has fallen off. This will result in a lean condition.
MY REPLY
Hi...I'm pretty certain that the MAF or snorkle is not the problem. There has never been a case where the engine has run lean - it just is full power one instant, and then dead the next instant. I was driving it the other day, and watched the tachometer fall from 2500 to zero as it died. We were traveling about 40 mph on a slight downgrade, and it restarted itself while we were still moving, without having to pull over and crank the engine. Between the engine dying and the restart, the check engine and battery lights flashed briefly. This happened again several seconds later, and then it hasn't done it again since then, even though we've driven it another 50 miles or so.
Any ideas? This issue is driving me crazy...
ORIGNAL POST
Year: 1999
Make: Toyota
Model: Land Cruiser
Engine: V8
Already Tried:
TECHNICIAN REPLY
MY REPLY
