Old 02-20-05, 11:13 AM   #1 (permalink)
Jukelemon's Avatar
100 OME lift write up
Here you go. The rear end install was rained out. I will complete that next weekend.
100 Series OME Lift Instructions/Commentary
I did not take any pics due to the fact that I think between the FSM and these instructions, the install is very straight forward. Not easy, but straight forward. I have divided the lift into parts-front and back because I know that there are some that are only interested in lifting the front to match the rear and/or adding T bars only so that a winch/bumper can be installed.
Front
OME T bar and shock installation
Tools needed:
• Large lift (jack)
• 2 jack stands
• Breaker bar
• Penetrating oil
• ¾, 7/8, 12mm, 22mm. 24mm and 30mm socket, ¾ and 7/8 open end. I chose std. for some because my Craftsman set has a 6 point set on the std. sockets i.e. better grip and less likelihood of stripping.
• Large channel locks
• Help would be great but know it can be completed by yourself-I did this alone with both kids playing in the cabin of the 100.
• Copper hammer or regular hammer with drive block
• For first time, 8 hours of install time. I could do it in 4 hours after this lift experience
1. Pre lubricate all bolts involved in the install. This would mean both bolts for each shock, torque arm bolts, anchor arm bolt, rear stabilizer bolts, lateral control rod bolts. I recommend Toyota’s penetrating oil and lubricant or Kroils’s aerosol. I would recommend doing this at least three days straight prior to install. Depending on the climate, this might not be necessary. My 100 came from Cleveland, had more rust than usual and I did the three day route and was very happy I did.
2. Measure ride height by measuring top of rim to bottom of fender lip. This is with vehicle on the ground, suspension loaded. This measurement, + 2 inches is what you will need to reference when the front end install is complete i.e. you will need to adjust the T bars so that ride height has only increased 2 inches OR, according to OME, that you have at least 3 inches of droop/wheel travel. My ride height was 11.5” from top of wheel (not tire) to the center of the bottom fender lip.
3. Block Rear wheels
4. Lift front end of truck by placing lift in the center of the front diff cross member support. You must have a decent jack that has a high lift capacity or you will not be able to work on the front end. I am not a fan of placing a small lift on a block, but I suppose that can be done as well.
5. If you don’t own a pneumatic, you will need to leave the tires on the ground just a bit so you can take off the wheels by hand. If you own a pneumatic, lift the front end so that the suspension is at full droop i.e. wheels off ground.
6. Remove wheels/tires with 24mm socket.
7. Place a jack stand on left and right side frame rails. This will be a temporary position but is necessary for safety while you remove the chassis/engine cover.
8. Remove chassis cover using a 12mm socket and place to the side.
9. Take the jack stands on the frame rails and move them to the far ends of the cross member right behind the front diff cross member. It is the cross member that will be closest to the torque arm. This cannot be seen until after you remove the chassis/engine cover. I typically leave the lift in place and lower it until the jack stands and the lift are carrying the load. Personal preference at this point in terms of your safety.
10. Regardless of side, take the bottom shock mount bolts off using a 3/4 socket and open end. My shocks were factory and they were tight. Breaker bar necessary. I did not worry about trying to break the bolt loose and hold the bolt head with the open end. I broke it loose with the breaker and then used both to take off the bolt.
11. Remove top bolt. It will be necessary to hold the top of the piston (shock) or else the bolt will just spin. This particular bolt was on very very tight. Mine required some flame/lubricant/flame process to break it. Remove shock. Repeat on other side. As a side note, my N133 shocks had different bolt sizes. One was ¾ on the top and one was 7/8. Both shocks read N133 on the piston very clearly. Not sure what is up with that.
12. If you need brakes, now is the time to change out ( :
13. I always check the jack stands prior to getting under the vehicle. I shake the front, hard, to make sure there is 0 chance of support failure.
14. Mark location of the anchor arm by either measuring the end threads or marking the location of the anchor arm in reference to the frame. See 16 for detail commentary.
15. Loosen anchor arm bolt to the point where there is 0 load on the T Bar. If you are not sure, it will be extremely clear when your anchor arm adjusting seat unseats i.e. is loose on the bolt. If it gets to this point, tighten until it is just seated yet there will still be 0 load on the spring.
16. You will need to index the location of the anchor arm at this point. There are many ways to do this. The FSM recommends measuring distances, slee recommends using a grease pen. Since this mark is essentially arbitrary and really not in need of being precise, use what you think is best. Either way, you have to be able to mark the position of the anchor arm at 0 preload. I used the grease pin method. I would NOT recommend any other way. When you reinstall a new T bar, you do not want to be measuring at the same time of trying to hold up the bar. It will make more sense later.
17. Remove the anchor arm bolt completely. Remove the seat and the swivel.
18. Remove the two torque arm bolts by using a 24mm socket. One comes out completely and the other is like a stud even though it is just a bolt.
19. You will need to drive the torque arm rearward onto the T bar. In other words, the torque arm will be like a ring on the T bar when complete. DO NOT use a regular hammer to do this. Use a copper hammer OR protect the torque arm with a steel block. The T arm is hard but a hammer will mar the metal. Pay attention to how much of the T bar splines are showing. This will help you later judge how far to seat the splines of the new T bar in the anchor arm.
20. Drive off the anchor arm from the T bar. Be careful so that the T bar does not fall on you. It is not light.
21. Remove T bar. Drive off torque arm from T bar.
22. I would, at this point, spend some time cleaning up/lubricating the anchor arm bolt, anchor arm splines, torque arm splines, torque arm bolts. The more time you take at this point to clean, the easier the reinstall/adjustments will be on the new T bar.
23. When the parts are clean, spread a thin layer of grease on the anchor arm and in the torque arm splines. Not too much on the anchor arm or else you create a sucking/pressure effect when you join the T bar to the anchor arm.
24. The T bars are labeled in reference to a driver’s position in the vehicle i.e. left OME T bar is marked LH and should go on the driver’s side. RH is for the passenger side. So, Left/Right is in relation to a person in the vehicle looking straight out the window. For each T bar, there is no front/back although they are color coded for some reason. Ignore.
25. Pick out the vehicle side of choice. Apply a thin layer of grease to the splines of the corresponding T bar.
26. You will know if you have done a good job of cleaning the torque arm and anchor arm if you can slide them off and on the new T bar with relative ease. If you cannot, I recommend for you to stop and clean some more.
27. Place torque arm onto an end of the T bar. Slide it all the way so that it is loose like a ring, like before on the T bar. Make sure it is on correctly so that the mating surface is correct for the control arm.
28. Install the T bar so that the anchor arm end is in general location necessary i.e. as if it were in the anchor arm.
29. Here is where you will need to “index” the bar. Install the anchor arm onto the T bar. Place the anchor bar in the position either marked or measured. Hold and slide the torque arm over the splines in such a way that the anchor arm bolts will not compromise your mark i.e. you must align the torque arm with the anchor arm so that when you bolt down the anchor arm, the marked/measured position will be on. It is a bit hairy and takes some first, second, third tries due to the fact that the anchor arm adjusting bolt is not on so you must guesstimate the location of the anchor arm without the bolt being there. It will make sense when you are in there. Remember, do not stress about exact line up. BUT you do not want to miss your mark by having the arm above where it should be. In other words, you do not want to loose any distance between the anchor arm and the anchor sleeve. My bolt’s end had a lot of thread showing at the OE setting AND the new T bars have a lot more spring to them so, I was not too worried about not having enough bolt/adjustment room for the ride height if I indexed them lower than the OE mark. The above is what is instructed by OME/FSM. My install was a bit different and the directions above essentially placed me in a position to have to go back and completely reindex the bars because I did not have enough adjustment to gain the 2 inches. So, for my install, I ended up indexing the anchor arms about 2 inches LOWER than the original OE setting. This allowed me to not only get the 2 inches but also have enough room to adjust for aging T bars. Your choice and I am not sure if each 100 will be different. The redo was not that bad so if you go with OME instructions and it does not work out, not to worry.
30. At this point, reference how much of the splines were showing at the torque arm. Adjust (move the T bar into the anchor arm) so that the same amount is showing on the new T bar. This ensures that the correct spline depth has been achieved. You are thanking yourself now for the cleaning time after seeing the T bar slide nice and easy depending upon where you want it to go.
31. Install anchor arm adjusting bolt and tighten to the point where your seat has just tightened i.e. 0 preload but seated. Check your mark to make sure you are still good. Tighten adjuster until you reach your preload mark/measurement taken prior to beginning.
32. Repeat for other side.
33. Install tires. Remove jacks. Lower front end. Raise front end. Lower again. Measure ride height. Depending, adjust anchor arm bolt accordingly so that +2 inches has been achieved. DO NOT DO THIS WITH THE TIRES ON THE GROUND. THEY MUST BE OFF THE GROUND TO ADJUST THE RIDE HEIGHT. I hit right at 13.5" of ride height. Sweet. OME recommends driving but since we are going to do the back, I waited. A final adjustment is made after everything is completed and a test drive has been completed. Reinstall engine cover. Get/do an alignment. Adjust headlights at this point UNLESS you are doing the rear as well. You will do the light adjustment after the rear is finished.
34. Grab a beer, have a smoke. The most complicated is over.
Juke
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 02-20-05, 11:21 AM   #2 (permalink)
jjbodean1970's Avatar
TLCA# 14836
sounds like we have a winner to be added to the FAQ!
thanks juke for a great write up!
Originally Posted by Atticus View Post
War Eagle!
No regrets, thats my motto. That and everybody wang chung tonight.
The smoker you drink, the player you get.
2005 Toyota Sequoia Limited (mine) 2006 Toyota Sienna Limited AWD (hers)
jjbodean1970 is offline   Reply With Quote
Old 02-20-05, 11:30 AM   #3 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
need to get it aligned right away after the front t-car install.
nice write up
John
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 02-20-05, 12:11 PM   #4 (permalink)
calamaridog's Avatar
Thanks for taking the time to write down the instuctions.
2000 UZJ100 - sold and missed like hell
Any Toyota 4x4 and hopefully soon
calamaridog is offline   Reply With Quote
Old 02-20-05, 02:10 PM   #5 (permalink)
You want to do what...?
e9999's Avatar
excellent, straight to the FAQ!
We need more of this kinda good detailed writeups!
Anybody who has done this, please add comments as needed!
Juke:
in step 5 what do you mean by pneumatic?
and I guess you call the jack a lift?
great job!
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 02-20-05, 03:52 PM   #6 (permalink)
Jukelemon's Avatar
Thanks guys. Pimp: I did forget the alignment AND the headlight adjustment. I will not do this until the rear is finished so I left it out. But it should be there in case someone is just doing the front.
E: Yeah, I call the jack a lift. In 5, I mean an air wrench/air tool. I can edit that if you guys think it is necessary.
1992 4x4 PU
Old 02-23-05, 09:17 AM   #7 (permalink)
hank14's Avatar
TLCA# 17839
Did you install or do you plan on installing the diff drop kit?
Scott
Granbury, TX
1987 Beige FJ60.
One clean cruiser.
hank14 is offline   Reply With Quote
Old 02-23-05, 09:46 AM   #8 (permalink)
Jukelemon's Avatar
Hank:
No I did not. I wanted to be able to see the effects on my vehicle. Not to discount any other's experience but there are so few lifted 100's that I thought another guinea pig would be good. I am going to monitor the CV's on a weekly basis.
1992 4x4 PU
Old 02-23-05, 06:15 PM   #9 (permalink)
SINCITY100's Avatar
Oh sure, you write this great tutorial a week AFTER I installed mine !!
I had to figure it out on my own, and let me tell you, it wasnt exactly "easy" !!
Well, all said and done, what an incredible improvement ! I hope you are as happy as I am with this set-up !!
SINCITY100 is offline   Reply With Quote
Old 02-23-05, 06:31 PM   #10 (permalink)
Jukelemon's Avatar
Nobody said "easy". I am happy.
Juke
1992 4x4 PU
Old 08-24-05, 07:06 PM   #11 (permalink)
Supporting Vendor
cruiseroutfit's Avatar
TLCA# 10662
Just checking in on the install... did you end up adding the diff drop?
Kurt Williams
Cruiser Outfitters - YOUR LC PARTS SOURCE!
OME - ARB - AA - Safari - Helton - Engel
ExpeditionUtah - A lifelong project of exploring Utah
U4WDA
TLCA
Wasatch Cruisers
Mountain Yoats
Red Rock 4 Wheelers
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 08-24-05, 10:40 PM   #12 (permalink)
spressomon's Avatar
I did the install with the diff drop kit a couple months ago...thanks to Juke's right up it went fine other than the tight rusted upper rear shock mount nuts which required extra, extra PB and a cheater bar to break 'me loose (and I had to take it to a shop to have the t-bars flamed/wrestled off ...This 100 spent it's life on the East Coast other than the past 8-months here in the high plains desert ).
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery with custom home brew battery tray, home brew sliders & Slee belly and skid plates, 9.5XP/Masterpull, Solstice LEDs, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, LT285/75R18 GY MT/R Kevlar, KK in tow... HAMified
ROTM: http://forum.ih8mud.com/100-series-c...pressomon.html
Old 08-25-05, 08:22 AM   #13 (permalink)
TLCA# 15376
I just ordered an OME lift and diff drop kit from Slee. I'll write up how to do the rear and the diff drop kit and add it to this thread. It will probably be 3 weeks before I have it done. I won't get it till next week and I'll be on vacation the week after that.
2001 UZJ100 Land Cruiser
ARB bar, OME lift (863's, N74L's), Slee diff drop, 295 BFG AT's, Slee step-sliders, Slee rear bumper, Husky liners, Hella 4000's
My Featured 100 Thread
Greg B is offline   Reply With Quote
Old 08-25-05, 10:50 AM   #14 (permalink)
spressomon's Avatar
FYI: The instructions from Slee for the diff drop kit are good...and of all the suspension components installed it was the easiest to install. For your rear shock removal be sure to have a pipe/chain wrench and/or large locking pliers of sometype that can grip the shock body. I also had to remove the crow-foot/open end of my Craftsman ratcheting box wrench so that I could get a cheater bar attached to allow enough torque to remove the stubborn shock mount nuts.
One other thing I can't overemphasize: PB all bolts/nuts repeatedly for several days in advance of your actual work day....especially if the vehicle is/was from East Coast (or East Coast type environments).
Old 08-25-05, 11:18 AM   #15 (permalink)
TLCA# 15376
Spresso,
Thanks for the tips. On the shocks turning, I've had the best luck with this in the past using a rubber strap wrench, plus it doesn't mar the paint on the shock.
