Old 10-25-09, 11:25 PM   #1 (permalink)
Skidoo's Avatar
Garage
Need Transmission advise, have valve body out
As I mention in earlier post I am getting a P0770 code (TC lockup malfunction) It can happen a couple of days apart, but then it did "not" happen on a 10 day 2000 mile trip to southern Utah for off-roading.
Have a number of photos during various stages ofdisassembly at this site.
Picasa Web Albums - H2O - Land Cruiser A/T
(Clicking on photos will get you larger views.)
As mentioned in other post, will write this up when done. Have started to label things in photos I don't find in manuals.
I have tested Lockup Solenoid with compressed air and it tests good. Of course since it is intermittent behavior, expect should replace it anyhow.
Questions:
1. The amount of metal shown in pan, good, bad, ugly?
2. Various screens look pretty clean?
3. Anything I should be looking for in lockup circuit?
4. Am I correct in assuming that Torque Converter lockup failing would create a lot of metal in the pan?
2000 Land Cruiser, 143K miles, manufactured July 2000.
Thanks,
Skidoo
Skidoo is online now   Reply With Quote
Old 10-26-09, 02:52 AM   #2 (permalink)
NMuzj100's Avatar
Looks normal to me.
They looked pretty good.
I have no idea, sorry.
I don't think so. I think it would create excessive heat and burning fluid. Your fluid looks good. (FYI - I'm not an AT expert)
Are the check balls held in with anything or do they just float in their chambers ?
Great pictures!
I attached a few for posterity
1. Labeled Valve body
2. AT w/ valve body removed
3. Upper valve body w/check ball positions.
1998 UZJ100 146K 285/75R16 Revo 2s, D-light mod
1999 Toyota Camry - So Boring
NMuzj100 is offline   Reply With Quote
Old 10-26-09, 04:21 AM   #3 (permalink)
wildsmith's Avatar
Has it ever given you the opposite fault and stayed locked when it shouldn't? I don't think the washer failing in the TC creates much material evidence until it gets really bad but I don't *know* that.
It could also be a wiring fault in the harness to the gearbox. Is there a different code for solenoid failure vs lockup failure?
Jon m0zxj
01 UZJ100 auto - lifted, locked, front bumper, sliders, snorkel, big tyres etc.
93 HDJ80 12v auto - lifted, oem locked, front bumper, sliders, big tyres etc
wildsmith is offline   Reply With Quote
Old 10-26-09, 08:17 AM   #4 (permalink)
Skidoo's Avatar
Garage
The plate that goes between Upper and Lower Valve Bodies keeps balls in place and also provides seats for balls work against. When disassembling Valve Body, Upper Valve is on top to remove bolts. Carefully separate Plate from Lower Valve Body and hold it tight against Upper Valve Body while flipping Upper Valve Body over to keep balls in place, then Plate can be removed.
No, I have never had it fail with lockup on.
There are two codes P0770 and P0773 for Lockup Solenoid, I am just seeing the P0770 code.
P0770 detection is; Lock-up not occuring in lock-up range (50mph) or Lock-up remaining on outside lock-up range. (2 trip detection logic)
P0773 detection is; Solenoid resistance is 8 ohms or less when energized or is 100K ohms or more when not energized.
Old 10-26-09, 08:48 AM   #5 (permalink)
wildsmith's Avatar
I guess it's not a wiring fault then or you'd have a P0773 code as well. When it fails to lock does it keep failing for a while or work as normal right away?
I would change the solenoid but resign myself to the thought the TC may need changing to fix it. I had lock up problems on my 80 a few years ago and went through a similar process
Jon m0zxj
Old 10-27-09, 11:37 AM   #6 (permalink)
Skidoo's Avatar
Garage
Decided to have valve body modified by IPT for improved shifting and pressures while it is out. NMuzj100 suggested a valve body by Wholesale of Australia, but in looking around IPT has a good reputation and costs less. Will know more when it gets back.
Old 11-07-09, 10:47 AM   #7 (permalink)
The failure to work IN THE PROPER SPEED RANGE is indicative of a speed sensor failure. If the solenoid was not working--you would probably get the other error code (presuming you have checked the resistance and it is OK--however, the tolerance range shown is ridiculously wide by the way. I would replace the bugger.It could be a simple bad electrical connection from the speed sensor to the transmission computer. break that connection, inspect it, and then apply 'Stabilant 22' to all th epins and reconnect.
Texasoil is offline   Reply With Quote
Old 11-07-09, 08:33 PM   #8 (permalink)
Skidoo's Avatar
Garage
Thanks, I had not thought of the speed sensor, I will follow up on your suggestions.
