Old 10-25-09, 08:36 PM   #1 (permalink)
Timing Belt Job question
Do the idler pulleys typically need replacement during one of these jobs? The FSM says that if "leakage is found, replace pulley"....for those of you that have done the timing belt job, did you find leakage and/or replace the pulley...or do they last 300K and this is just FSM fodder?
I am trying to line up all the parts for the job before I tear into it.
Thanks...greg
apalt is offline   Reply With Quote
Old 10-26-09, 11:47 AM   #2 (permalink)
scottm's Avatar
Talk to cDan, he's only seen a bazillion of these. He'll tell you what you have to have, and suggest other things that you ought to have, and tell you how likely it is you'll need them. Good prices, and the right parts, from a knowleagable Mudder.
'03 UZJ100: wife's ride; '97 FZJ80: Traded in; '97 FZJ80 40th: Totalled; Heep: Trail Rated; '06 Specialized Epic Comp Disk: Daily Driver; B-767: company vehicle
"if thou would have peace, be thou then prepared for war".
"Except for ending Slavery, Fascism, Nazism and Communism, WAR has never solved anything." - Ronald Reagan
scottm is offline   Reply With Quote
Old 10-26-09, 02:17 PM   #3 (permalink)
Trunk Monkey's Avatar
TLCA# 11251
I didn't replace the pulleys when we did my timing belt. But, I see them offered in most of the "kits" on Ebay.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 10-26-09, 02:25 PM   #4 (permalink)
LSUfj's Avatar
I didnt have to replace any of them. The belt looked almost new at 125k miles also. It may depend on your environment. I havent found any kind of rusty or difficult to remove bolt on my 100, so that might be somewhat of an indicator.
75 FJ40, 33x10.5s, restoration in progress
01 UZJ100 OME 866, helton HX, custom storage drawers, BFG 285/16s
LSUfj is offline   Reply With Quote
Old 10-26-09, 08:12 PM   #5 (permalink)
LandCruiserPhil's Avatar
I replaced both pulleys and replaced one of the bearing. Service was done at 125K write up available with search.
"Knowledge without experience is just information"--Mark Twain
Copper State Cruisers #003
LandCruiserPhil is offline   Reply With Quote
Old 10-29-09, 07:49 AM   #6 (permalink)
Walton's Avatar
My pulleys were fine at 110,000. My belt looked new also.
Toyota Land Cruiser...It's the only way I roll.
1998 UZJ100...1967 FJ40...1964 FJ45 SWB
Walton is online now   Reply With Quote
Old 11-05-09, 04:14 PM   #7 (permalink)
BMWSTOY's Avatar
My pulleys were good, you should check them while your in there.
If possible, plan for some down time so you can order what you need. If not possible, I would plan on the pulleys, but would do the water pump, serp belt. Don't forget the "Black Diamond" nuts - do not re-use
2000 LC - 'The Black Pearl' 130K. 285/75/16BFG's
DIY'r: Timing/serp/H20pump,Black Pearl. Needed: Money for lift - it needs shocks! In tow: Fleetwood Tacoma
Daily Commuters: Trek Madone 5.2 / Scott Comp Racing MTB
LIVESTRONG
BMWSTOY is offline   Reply With Quote
Old 11-05-09, 10:28 PM   #8 (permalink)
Topoguide's Avatar
The question is how risk averse are you? The engine is an interference design, so very simply what that means is that if the belt breaks you are going to do a lot of damage to your rather expensive motor.
Does it matter why the belt broke? Old age vs a pulley stopping? Or maybe the water pump leaking all over the belt and pulley causing damage leading to early belt failure? Nope, and nope.
Could you be OK in not changing them? Sure... you could be OK in not changing your belt, but how much risk are you willing to take? If it was a non-interference motor I'd say go for it, if the belt breaks the motor just stops... problem is it IS an interference motor.
And yes I did personally know someone that had a pulley go out.
Not all who wander are lost.
2003 UZJ100 - Bone Stock for now (but it gets the whole fam there)
2007 Specialized Rock Hopper Pro Disc in Mango - The Captain Armadillo tires, Shimano clipless pedals, XT low-normal rear derailleur, XT chain
Topoguide is online now   Reply With Quote
Old 11-05-09, 10:30 PM   #9 (permalink)
I did mine at 100k. The old idlers seemed ok but I replaced them anyway. Glad I did, got rid of an annoying knock at start up that I could never pin down. The dealer said the tensioners usually go 200-300k before replacing, just check for signs of leaking, replace if the old one isn't dry. Definitely replace the water pump. My old one was weeping from the back side but couldn't tell until I had it out.
donco
'00 LC-100, 120k miles
donco is offline   Reply With Quote
Old 11-06-09, 05:08 PM   #10 (permalink)
What the heck is a "black diamond" nut?
Also, the water pump gasket came with a new bolt in the bag. Anyone know why?
Old 11-06-09, 05:15 PM   #11 (permalink)
Mall Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
in the FSM there are things such as gaskets, bolts, nuts, washers...all marked with a Black Diamond. That symbol means DO NOT REUSE.
2000 Lexus LX470 - There's a mod list growing
2005 Specialized FSR XC - Needs new home
2008 Scott Gambler FR10
- Nut up or shut up
1loudLX is offline   Reply With Quote
Old 11-07-09, 05:52 AM   #12 (permalink)
Good to know! Thanks.
Old 11-07-09, 09:45 AM   #13 (permalink)
mine came w/ a bolt too.. ended up not needing it...
http://forum.ih8mud.com/100-series-c...-question.html
98 LX470
TMILL is offline   Reply With Quote
