10-15-09, 08:00 AM
#61 | | Forum Lifer
| Quote:
Originally Posted by NMuzj100 Might as well get a prius.
Who has a kit for the 100 ? | Wagoneer5 runs the Slee 2wd kit on his '07
__________________ "Knowledge without experience is just information"--Mark Twain Copper State Cruisers #003 |
10-15-09, 08:05 AM
#62 | | Forum Lifer
| Quote:
Originally Posted by Trunk Monkey For the OP's trip from Reno to JH, figuring if the conversion gives you a 2mpg gain:
1400 miles / 14mpg = 100 g of fuel * $2.75 = $275
1400 miles / 16mpg = 87.5 g of fuel * $2.75 = $240 or a $35 savings
Kit cost $785 / $35 = ~23 fill ups to offset the cost. | ~23 fill ups or 23 trips?
10-15-09, 08:11 AM
#63 | | Forum Lifer
| Quote:
Originally Posted by LandCruiserPhil Wagoneer5 runs the Slee 2wd kit on his '07 | Not any more he doesn't. Quote:
Originally Posted by LandCruiserPhil ~23 fill ups or 23 trips? | Yeah, that too. |
10-15-09, 11:00 AM
#64 | | Dain Bramaged Member
| Quote:
Originally Posted by LandCruiserPhil ~23 fill ups or 23 trips? | Quote:
Originally Posted by Trunk Monkey ...
Yeah, that too. | 23X1400=32,200Miles or about two or three years of normal driving.
Unless you pay a shop to install the kit, or put a value on your own time.
__________________ Dan Johnson
What the large print giveth, the fine print taketh away. Battle Born Cruisers 1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front. 1984 FJ60, Detroits F&R and a gawd awful spring lift. Rust never sleeps.
10-15-09, 08:23 PM
#65 | | Mall Cruiser
Join Date: Jan 2006 Location: through the river and over the woods.
| Quote:
Kit cost $785 / $35 = ~23 fill ups to offset the cost. | Peace of mind that you can easily get off the trail when your diff explodes? Priceless.
__________________ 2000 Lexus LX470 - No really, it's stock! 2005 Lexus LX470 - seriously, this one is. hidden message |
10-15-09, 08:27 PM
#66 | | Mall Cruiser
| Quote:
Originally Posted by rusty_tlc 23X1400=32,200Miles or about two or three years of normal driving.
Unless you pay a shop to install the kit, or put a value on your own time. | HWY22 could do that amount of driving in less then a half year. If he drives 1400 a weekend, plus whatever else around town-ing that would pay itself off pretty quick, not to mention be fun (BURNOUTSSSSS)
10-16-09, 04:01 PM
#67 | | Forum Lifer
| The availability of the kit from Slee makes the concept more practical.
I wonder what the real world mileage increases work out to. A kit like this doesn't keep all the running gear from turning full-time so I'm not sure it would be a huge advantage. Or maybe there is more to it than I understand.
Joff is the only board member I know with a kit installed. Part Time Kit With Freewheel Hubs - 100 Series Land Cruiser
__________________ 1998 UZJ100 150K 285/75R16 Revo 2s, D-light mod
1999 Toyota Camry - So Boring
10-16-09, 04:04 PM
#68 | | Coming to a mall near you
| Quote:
Originally Posted by LandCruiserPhil Wagoneer5 runs the Slee 2wd kit on his '07 | Quote:
Originally Posted by NMuzj100 The availability of the kit makes the concept more practical.
Joff is the only board member I know with a kit installed. Part Time Kit With Freewheel Hubs - 100 Series Land Cruiser |
not quite. but so far only 2 run the part time kit.
i would think over time it would pay for itself. A small increase in MPG and less were on the cv axles, and boots.
__________________ /// 2000 UZJ100 / OME 866:Bilsteins / ARB Combo Bar 03+ / WK Sliders / 295 BFG / Black:Rims,Grill,Vents,Emblems / 55W HID / Cobra CB / Scanners / ScanGauge II / Rockford Fosgate P2 /// /// 2006 4Runner / BFG AT /// LOL |
10-16-09, 04:19 PM
#69 | | Forum Lifer
| With you 2WD kit what all do you give up? ABS, VSC, TRAC?
10-16-09, 04:19 PM
#70 | | Forum Lifer
| Quote:
Originally Posted by NMuzj100 I wonder what the real world mileage increases work out to. A kit like this doesn't keep all the running gear from turning full-time so I'm not sure it would be a huge advantage. Or maybe there is more to it than I understand. | A friend of mine did what this kit basically does on his 80 for a couple of trips from Salt Lake City to Los Angeles. He saw about a 2mpg increase overall.
The kit does decrease wear and certainly gives a different driving feel. I had the front driveline out of my 80 for a couple weeks and it was a totally different beast. With this kit 4wd relies on the center diff and hubs. If I were putting on the kind of miles the OP was, I would def. consider it. But for more casual use, it'd take awhile to pay for itself. |
10-16-09, 04:25 PM
#71 | | Forum Lifer
| Quote:
Originally Posted by NMuzj100 A kit like this doesn't keep all the running gear from turning full-time so I'm not sure it would be a huge advantage. Or maybe there is more to it than I understand. | There is more to it than I thought. And it does disengage the front running gear. MarK's 4WD adapters has a good FAQ.
They say the ABS is unaffected.
1999 Toyota Camry - So Boring |
10-16-09, 04:26 PM
#72 | | Site Addict
| But full-time 4WD has a safety factor all its own, as well as the point landcruiserphil makes about the electronic traction systems. Personally, not worth giving up any of that.
My $0.02,
__________________ Derek Lee `81 G-Wagen (460.333), `04 Land Cruiser (UZJ100)...plus some other junk... |
10-16-09, 05:07 PM
#73 | | Mall Cruiser
| Quote:
Originally Posted by LandCruiserPhil With you 2WD kit what all do you give up? ABS, VSC, TRAC? |
NOTHING.
It makes your hubs be able to disconnect and makes your t-case have a part time option. Nothing else is affected. Its really quite simple, everyone's looking too much into this. ABS isnt affected, thus VSC and TRAC also arent, since neither actually throttle in more power to control the vehicle, only cuts it or adds brakes.
10-16-09, 08:25 PM
#74 | | Dain Bramaged Member
| Quote:
Originally Posted by 1loudLX Peace of mind that you can easily get off the trail when your diff explodes? Priceless. | It only takes about twenty minutes to drop the front drive line and pull the wheel drive flanges.
10-16-09, 10:25 PM
#75 | | Forum Lifer
| Quote:
Originally Posted by 1loudLX Nothing else is affected. Its really quite simple, everyone's looking too much into this. ABS isnt affected, thus VSC and TRAC also arent, since neither actually throttle in more power to control the vehicle, only cuts it or adds brakes. | From what I understand ... (correct me if I'm wrong).
What you gain ...
- 5-10% fuel economy gain
- Better steering response
- Better acceleration
- Decreased wear on front drive-train
What you give up-
- 4WD in High Gear (thx trunk)
- The ability to shift to 4WD without getting out of the truck
- Cost of kit and installation
ABS unaffected in IFS applications.
VSC is not disabled but may not be as effective with the change in vehicle dynamics ?
TRAC is not disabled but also won't be doing anything in the front since there will be no wheel-spin when disconnected.
Reason: correction
10-17-09, 12:48 PM
#76 | | Forum Lifer
| 4wd in high gear is unaffected, lock hubs and lock center diff. |
10-17-09, 09:00 PM
#77 | | Dain Bramaged Member
| Quote:
Originally Posted by NMuzj100 From what I understand ... (correct me if I'm wrong).
What you gain ...
What you give up-
- 4WD in High Gear - The ability to shift to 4WD without getting out of the truck
TRAC is not disabled but also won't be doing anything in the front since there will be no wheel-spin when disconnected. | Those of us with old school Cruiser that have to get out to shift to 4WD usually lock the hubs in advance. Like in the driveway if there is snow on the road or when we air down at the trail head.  No big deal there.
10-18-09, 05:56 AM
#78 | | 250+ Club
Join Date: Mar 2006 Location: Melbourne, Victoria, Australia
| i never did say thanks for providing this LC100 forum. So i do now. Thanks.
i love this sort of discussion/debate!!
and the questions around my question about going metric...yes....i have to say...i love a fucking good pint. In fact i love many many pints of beer....i have a couple of English friends....and not that that matters, it just means instead of our "normal" servings of beer - in Victoria it's called a "pot"....NSW and co (see below) call that measure a "middie", and NSW, QLD , and SA have something called a "schooner"....all smaller than a pint (cant remember about WA).
Victoria has a couple of measures even smaller.
The only place i know in Melbourne that has them is the Elms Family Hotel in Spring Street.
Their used to be a 7oz glass called "a glass" of beer. And way way way back...5oz.....called a Pony (NFI why)
you can still get a glass of beer in SOME pubs.....but a Pony? no. The only place i know is the Elms.
4wd relevance? i drove my 4wd there. And met some 4wd friends there. And no. We drank pints :-)
peter
__________________ 2005 LC100 4.7L V8 5 Speed manual (nice beast!!!) |
10-18-09, 10:31 AM
#79 | | You want to do what...?
| maybe it's time to start the "Great MUD premium gas test".
Coupla people doing predictable drives want to do a well-controlled test and help put this matter to rest?
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!  : '03: 125K
DDs: Accord, Prius  : souped-up DR650 |
10-19-09, 01:07 AM
#80 | | Forum Lifer
| Quote:
Originally Posted by e9999 Coupla people doing predictable drives want to do a well-controlled test and help put this matter to rest? | Good luck with that!
After that maybe we'll have Schotts and a couple of other guys take a couple of 100s and a couple of 80s out on some pretty standard trails and come back to us with the answer to the "80 vs. 100" question once and for all.
| Thread Tools | | | | Display Modes | Linear Mode |
