Closed Thread
LinkBack (4) Thread Tools Display Modes
Old 01-05-05, 12:49 PM   #1
You want to do what...?
e9999's Avatar
e9999 is an unknown quantity at this point
100 series LC/LX FAQ
Please PM or post about good threads worth putting into FAQ - thx - E
Photo threads
Thread 1
Buying a 100
Newbie guide to the 100, models, and inspection of a used vehicle (by Slee Off Road)
(Warning: be *very* careful about the type (Master or not) of keys you get with a used truck. You must have a Master or you have a potentially serious and very expensive issue on your hands. Do a search here for more info.)
100 vs 80
Differences in safety features between 100 and 80 models
Build-up stories
An illustrated example of a 100 makeover with step by step pics!
A nice buildup story for illustration...
TSBs (Technical Service Bulletins)
TSBs for the LC100
TSBs for the LX470
Maintenance
Toyota Informationa Services (all manuals etc)
Toyota maintenance schedules
ATF fluids
Timing belt replacement (Note excellent pics reference in post 24)
More on Timing belt and starter replacement, great pics and tips
Basic PM after purchase
Front diff oil change
Rear Diff oil change
Premium vs regular gas (and fuel filter)
Oil analysis with M1
Driveshaft lubing schematic
Flushing brake fluid out
Replacing / Adding the cabin air filters in the LX/LC
A bit on engine oil change basics
AHC suspension fluid replacement
Replacement of serpentine belt / tensioner
A bit on coolants
Oil filters and oil
Lubing the Driveshafts: too much grease?
Steering
Power steering pump rebuild
Drivetrain
Front wheel bearing replacement
Front rotor removal and replacement (check link to pics)
Replacing CV boot straps
Electrical
Starter contacts replacement procedure
How to add a trailer brake controller to a 100
Key replacement and programming
Master key identification
Door locks programming
Adding power outlets for accessories
Armor
Slee rear bumper with tire carrier
4x4 Labs 100 bumpers
03+ ARB bull bar on 02- LX470 (for info only, not endorsed by site)
Mods
Slee front diff drop
OME front lift
How difficult is it to do a lift with OME?
Pros and cons of OME lift
Headlights upgrade
Pin 7 mod or how to disable the automatic Center Diff Locking in Low
Disconnecting DRLs (Daylight Running Lights)
AHC suspension sensor adjustment for lift
How to disable the ABS
Raising the spare tire
Adding Aux lights using the factory fog light wires
Making the DVD play and entering destinations (?) while underway - using wiring (for info only, not endorsed by the site)
How to override the DVD / GPS disconnect while underway: using menus (for info only, not endorsed by the site)
Door speakers swap
Chopped ARB Bull Bar for better attack angle
Air system
Installation of Tru-speed calibrator for speedometer
Fuel
Interior
How to remove center console
Some stereo info
Leather seat cleaning and maintenance (Leatherique)
Exterior
Windshield replacement
Roof rack removal
Paint color charts
Tires and wheels
Tire size calculator
Speedo correction
Suspension
IFS cracking problems - or not...
Removal of rear springs and shocks
Symptoms
Pulsating brakes
Ticking sound in engine bay
Problems
Trailer wiring recall
Odometer light out
Rattle noise: cat shields
No brakes!
CV boots leaking after lift
Safety belts not retracting properly
Leaky CVs
Broken wheel lug - how to replace
Front end vibrations at speed
Code PO505 / Throttle body dirty
Throttle Position Sensor / Accelerator Pedal Position Sensor problems (low power etc)
Fuel smell inside the cabin
Continuous alarm/buzzing/fax sound from the dash
LC vs LX
Comparison LC and LX
Accessories
Floor mats
Adding little receptacle ("change pocket") next to shifter
'97: 86K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 97K, the better half's...
DD
e9999 is offline
Closed Thread
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/30754-100-series-lc-lx-faq.html
Posted By For Type Date
trailer wiring for 100 series - WC Forums This thread Refback 05-09-08 06:39 PM
Uncategorized « Randomness This thread Refback 04-11-08 05:41 AM
Toyota Landcruiser Owners Club (UK) :: View topic - Big wheels and trim kits This thread Refback 01-27-08 11:12 AM
Buy LX450 or 470 - Club Lexus Forums This thread Refback 01-03-08 01:23 PM
Mortgage Calculator | Credit Cards | Free mobile phone's stuffs | Refinance | Credit Cards
