11-02-05, 01:19 PM
#31
There are two filters, one in the tank and one in the engine compartment. If you ever had to drop the tank you might as well replace the filter also.
2000 UZJ100 - OME - sold Currently looking for the right FJ60
TLCA #14734
Calamaridog
11-02-05, 01:41 PM
#32
I'm no petroleum engineer but am an engineer, went to a petrol/mining university, and grew up in an oil family. I still can't believe reports that high-test gets you 1-2 mpg better. It seems very strange. The lower the `octane' level, the more quickly (and potentially thoroughly) the fuel will burn and thus marginally will extract higher energy from lower octane fuel which (if the engine is not knocking) should transform directly into increased mpg on low-test (especially on a constant-rpm highway drive).
Now I do agree that high-test is benenficial during towing, off-roading, low-altitude, hilly terrain, stop & go | city, and hot weather, and since I live in PHX, drive hills and mainly in the city my 100 will mostly see high-test. But on a long highway drive if the engine (ECU) is not having to retard itself on low-test you SHOULD get better mileage on it.
Same reason that high-altitude regions get 85 octane as their `regular' gasoline: you can get away with/need a higher rate-of-burn fuel with less oxygen content in the air (rather any given volume of air for an atmospheric pressure).
I guess I need to do some very serious empirical testing on the 2UZ-FE, but my 80 gets equal mpg on either high- or low-test over my 10 years with her in all sorts of conditions.
Scott (Pskhaat)
UZJ100, FZJ80
11-02-05, 02:45 PM
#33
Don't just look at the combustion dynamics though. Look at how many different ECU maps there are dependent upon what the advance, timing and quality of fuel will allow. If the world was flat I bet your theory on better milieage on low octane would hold true for every vehicle. I think that it depends on the engine too though. My Tacoma could gove a rat's a** if it has premium but my 100 sniffs it out quick. Maybe it's a condition inherent to my 100 and not other 100's but you gotta go with what works and on my 100 it's premium by a longshot. I keep a pretty close eye on the numbers, hell I'm the same knucklehead that keeps track of the cost to maintain my 100 even though it's at around $0.01/mile now. (You can never have too much info right?)
11-02-05, 03:51 PM
#34
[quote=3fj40]I'm no petroleum engineer but am an engineer, went to a petrol/mining university, and grew up in an oil family. I still can't believe reports that high-test gets you 1-2 mpg better. It seems very strange. The lower the `octane' level, the more quickly (and potentially thoroughly) the fuel will burn and thus marginally will extract higher energy from lower octane fuel which (if the engine is not knocking) should transform directly into increased mpg on low-test (especially on a constant-rpm highway drive).[quote]
The amount of fuel one uses has less to do with the chemical energy in the fuel then how the ECU reponds to preset air/Ox flow, and combustion. I belive the toyota V8 is designed for higher octane combustion but "works just fine" as in the ECU can compensate for a more volitale (and all be it higher energy... ie diesel fuel is even higher energy then gasoline) lower octane fuel... all be it with lower mpg
TLCA # 15449
2004 UZJ100 ARB Bull Bar IPF800 Warn XD9000 BFG AT 285/65R18 OME Shocks T-bars w/866 springs Slee diff-drop ARB compressor Optima yellow-top
11-02-05, 04:09 PM
#35
It is common belief here I've read that the newer 2UZ-FE drops this requirements. The only thing (as I've stated in other threads) is that the 2UZ configuration must have been VERY prone to pre-ignition. Keeping the displacement the same, Toyota overbored and destroked the 2UZ. This in my book gives the ring-to-block mating more surface area if you will to possibly control this pre-detonation. I am utterly suprised that the torque/HP ratings to be so equal as this would generally decrease the torque and allow for higher RPMs. However, there must have been significant ECU changes during that time or those pistons in the latter-models could possibly be of more mass?
I wish Toyota would call them the 3UZ configuration then as the changes in my book are significant enough for a new block designation. The 2F for instance had the same bore and stroke through it's generation, the 3F was destroked. Following that no reason to continue to call it the 2UZ.
Anyway, I'm rambling and I'll stop
Scott (Pskhaat)
UZJ100, FZJ80
11-02-05, 06:22 PM
#36
It was the ECU that was changed primarily as I don't believe there was a piston change. Dean (DMX84) I believe explained the ECU changes quite nicely at one point possibly in one of the other premium vs regular threads. The thread topic has been around the block a few times so I can't really point to the exact post it was. It's in one of those other gas threads somewhere!!!
11-02-05, 11:48 PM
#37
So which fuel will produce fewer hydrocarbons in the emissions?
11-03-05, 06:28 AM
#38
That's easy! Would you feed your kids or yourself McDonalds all the time your eat something healthy!
11-03-05, 12:51 PM
#39
The lower octane will give you the lowest hydrocarbons.
The reason of doing this is that the octane rating of a fuel is it's resistance to burning, so the lower octane fuels are easier to fully combust.
I may be vile and pernicious But you can't look away
I make you think I'm delicious With the stuff that I say
I am the best you can get Have you guessed me yet?
I am the slime oozin' out From your TV set"
I'm The Slime by Frank Zappa, 1973
98 Land Cruiser
01 Beta trials bike
71 GMC Shortwide truck
11-03-05, 04:07 PM
#40
So if the two fuels have the same amount of stored energy and the lower octane gas combusts more completely then shouldn't it be more fuel efficient? ceterus parabus.
?s for the forum. At altitude (ABQ is at about 5000ft) can the engine ever get any performance improvement from the premium fuel or will the limiting factor on performance always be our air density ? Why are octane levels lowered for higher altitudes. ?
1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts
1999 Toyota Camry - So Boring
11-03-05, 04:42 PM
Pskhaat
This message has been deleted by Pskhaat.
Reason: Moved into the thread.
11-03-05, 04:44 PM
#41
My recursive redirect response:
http://forum.ih8mud.com/showthread.p...55620#poststop
Basically, yes theoretically it should be more efficient, but consensus is the contrary. As for your 2nd question if not answered in the above link, O2 mass per any volume of air, dealing with partial gas pressures. Man I hated chemistry.
Scott (Pskhaat)
UZJ100, FZJ80
12-05-05, 11:19 PM
#42
Strangely, I am studying for an Internal Engines Combustion exam at this very moment, so I thought I would throw in my 2 cents. This could all be b.s. for all I know....I have not passed the class yet.
As for emissions, in an gas burning engine, I dont believe unburnt hydrocarbons are the main issue. The main source of pollution is from NOx production which is the result of dissociation from very high peak temperatures. In general, the higher the engine performance, the hotter it runs, if all else is equal. That being said, if running premium gives better performance, it is running hotter.
The ECU will dial back lambda values when you use regular. The lower a lambda (ratio of air-to-fuel) value means less fuel is being injected which results in a slower and cooler burning, therefor lower probability of autoignition. This also corresponds to less NOx and CO formation due to less dissociation.
Well, that probably does not help to much, but I felt it was a good study break.
First post BTW!
12-06-05, 01:00 AM
#43
First post BTW!
Sounds good to me, you get an "A+".
2005 Land Cruiser - Stock SOLD
1965 Belvedere I - 562ci Race Hemi, 668 HP SOLD.. RESOLD, HIGH BID $107K
1991 Jeep Cherokee - RE 5" SuperFlex Suspension RESTORATION IN PROGRESS
12-06-05, 08:29 AM
#44
I, like others here, run 91/92 premium octane fuel. I have experimented with 87 octane only to discover a few less miles per tank and less power. So I run what I have learned best for the truck and also it happens to be what Toyota recommends: 91/92 octane. (coincidence  ?)
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
12-06-05, 09:12 AM
#45
FWIW, I switched back from 89 to 91, been running 91 for over a month now, I have noticed NO improvment in milage and no difference in power............so back to 89 I go.
12-06-05, 09:58 AM
#46
That's contrary to what I would expect I guess. I would guess that a more lean condition in the combustion chamber may lead to higher temperatures?
Scott (Pskhaat)
UZJ100, FZJ80
12-06-05, 10:15 AM
#47
Guys,
I am running 91 again and it makes a difference from a power and gas mileage standpoint on my 99 LC.
Basic readers digest is that the truck does not seem to be trying so hard. With 87 it seemed liked the bad boy was always trying hard.
Just my opnion.
uzj100
12-06-05, 10:17 AM
#48
Me too; same scenario.
2001 UZJ100 Land Cruiser
ARB bar, OME lift (863's, N74L's), Slee diff drop, 295 BFG AT's, Slee step-sliders, Slee rear bumper, Husky liners, Hella 4000's
My Featured 100 Thread
12-06-05, 10:35 AM
#49
I've been running 89 for a year or so.
I'll switch to 91 to see if I can feel a difference.
I drive in the city mostly.
I'm running up to Colorado the 1st week of the new year.
So that will give me 1600 miles , there and back, to test the 91 octane theory.
1999 LC 130K : Alpine Stereo + iPod , 285 Bstone Revos, Upgraded 4-Pin Front Diff
12-06-05, 10:46 AM
#50
Originally Posted by uzj100
Guys,
Just my opnion.
uzj100
That's exactly what I experience too. To me there looks like there is no truly scientific answer. I think it is VERY vehicle and usage dependant and each person should get their own data to decide from. My data is cut and dry and collected for me by me. It simply is more cost effective for me to run on premium.
Another interesting difference is what "premium" and "regular" are. Pimp describes seeing no difference between 89 and 91. Neither of those are regular or premium at alot of stations in SC. Both of those are midgrade depending on the station. When I buy regular I get 87 octane. When I buy premium I get 93 octane. It is a far greater spread than 89 and 91. This is yet another reason why I think these results are turning out to be very situational and theories and physics in broad strokes aren't gonna give a answer that works for all of us.
12-06-05, 10:53 AM
#51
I've switched back and forth between 87 and 91 octane and have concluded there is a difference in power (it is not just psycological). I have not experimented with 89 yet. I need all the power I can get when running 35's.
98 LX470
85 BJ70
12-06-05, 12:57 PM
#52
Maybe the elevation I live and use my LC has something to do with the fact I can definitely feel the difference between the 87 and 91 octane.
12-06-05, 01:25 PM
#53
The 2UZ-FE V8 engine has 9.5:1 compression ratio which is the main reason Toyota recomends 91 octance. You see if they did not they would have to state the HP under regular octane 87 and that would be lower. If you run 87 the knock sensor will detect premature combustion (if it occurs... lower altitudes and hot weather make it worse). It then will send a signal to the ignition computer to set the ignition (ie the spark) early in the compression cycle so that the the compression expolosion won't happen. instead a normal ignition (use the spark plug) happens.
Knocking or (compression ignition or the diesel effect) only happens when there is a large amount of fuel present... typically when your press down hard on the gas... So what will happen is that in acceleration modes the fuel will not be as efficently burned if the ECU detects knocking and retards the ingition as described. Then end result is lower power and lower gas mileage.
Now this ONLY occurs if you engine is experiencing knocking. And I am not sure how long the computer takes to reset. But I can imagine if one is taking a LONG trip in the desert when its +100F in a fully loaded truck up and down hills knocking would occur on 87 and the ECU will retard the timing, and you would experience lower gas mileage.
This is exactly what I have seen. I have driven between AZ and CA in the summer and noticed about a 1MPG difference on average using 87 vs 91 (actually 92 in CA).
Power wise I think it would be really hard to tell. Cause the loss of pwer would only be at teh very top end... so unless your flooring and the conditions are right (ie hot weather .... etc) would you notice the power difference.
IMHO it does not matter much if one uses 91 or 87 ... gas is GAS there is good gas and bad gas (ie dirty, its got water etc...) but the octane ratign does not deterime that... bad gas is usually the result of poor puming system at the gas station which would allow contaimiants or water to collect or justa bad batch from the refiner... its awalys best to buy gas from a HIGH volume place (that's why I like COSTCO gas, not to mention they usualy have the best price in town) so that you get lots of turn over in the tanks in the ground.
I typically get 91(92) in the summer and in the winter I will alternate 87-91(92) every other fill up or go with 87 for two in a row sometimes... depending on my mood.
TLCA # 15449
12-06-05, 01:45 PM
#54
From what I understood that was EXACTLY how they got mid grade GAS. The pumping systems mix regular and premuim. I don't think stations get delivered 3 kinds of gas... just 2.... anyone know for sure
TLCA # 15449
12-06-05, 02:26 PM
#55
No, I don't but I can find out. I am pretty sure it is a mixture thing as well though.
Scott (Pskhaat)
UZJ100, FZJ80
12-06-05, 02:39 PM
#56
Rzpapp, Very well put. The ECU will remember your octane count (Knocking). It will always pull timing quickly (to avoid damage) and be slow to advance it back. If you disconnect the battery it will erase all its memory on this setting therefore setting it back to the factory fuel maps & timing.
On my car I had a custom chip made that will re-set the “octane” count every time the car is started. This helps eliminate problems with the bad gas scenario, plus on the car I run a large turbo and need all the advancement I can get.
98 Land Cruiser
01 Beta trials bike
12-06-05, 04:50 PM
#57
In college I worked at what is called a tank farm where gas is piped into a city for distribution then stored in tanks, then picked up by the trucks and delivered to stations. There are definitely 3 grades of gas, each stored in a different tank and each put into a different compartment on the tanker trucks - If I remember correctly a big tanker carries 11k gallons and has 3 compartments - one about 5.5k, one about 2.5k and a 3rd about 3k (I could be off here, but you get the idea). Each city/region is different, but at the time I was working, different companies used different refineries in differrent parts of the state (but several used the same and their pipelines). So in some cities / regions Chevron and Exxon gas is the exact same stuff made in the same refinery and shipped in the same pipeline until it gets into their trucks for distribution where it gets each companes differrent additives (including detergent & octane boost etc etc). The different grades of gas are all sent thru the same pipeline (including diesel if i remember correctly) but you are talking about such a large volume that grades and types of fuel mixing is not an issue at all.
I use 87 octane in my 100 and will continue to until i hear pings or knocks. Fr | |
