100-Series Cruisers Tech discussions for the 100-series, including the Lexus 470 models -- UZJ100.com
Old 06-05-09, 12:12 PM   #1 (permalink)
whistling/blowing sound from a 4.2 turbo 100!
Hello every1..
My dads cruiser makes a pretty loud whistling sound under acceleration.
More when the turbo starts to spool.
And i feel like (might me improvising) that it's losing power and getting very low mpg (as if it would need oxygen)..
Only things ive checked is exhaust pipe (fixed 2 holes and nothing changed)
And the piping from the turbo -intercooler- the pipe that conects to the manifold so i only checked the plastic and rubber hoses nothing thats made from cast!
Any ideas before i start ripping apart and checking the turbo?
Also, anyone know how theese work?
ToyoDIY.com
ToyoDIY.com
Sorry if this text is confusing, wrote in one minute before leaving work
Thanks, Klaufi.
Klaufi is offline   Reply With Quote
Old 06-05-09, 12:37 PM   #2 (permalink)
anthonycds's Avatar
sounds like a boost leak perhaps? I'd check the turbo intake/outlet pipes, as well as any hoses attached to the manifold, like EGR, boost sensor, and anything that may measure vacuum. Good luck!
'01 UZJ100 Black|285 Nitto TGs|LEDs|HIDs|
'02 Camaro Z28, Black, 25K miles, *FOR SALE*
anthonycds is offline   Reply With Quote
Old 06-05-09, 12:58 PM   #3 (permalink)
Comfortably Numb
cruiser100's Avatar
Turbo's always make a "whislting" sound, some just more than others.
Questions:
- Has the sound gotten louder lately?
- Has there been any recent work under the hood?
- Any exhaust work lately?
Try this: block the vehicle (tires) and set the p-brake so the vehicle won't move. Start the engine, put the trans in "N". Have someone gently rev the engine up while you listen under the hood to try to pinpoint the sound. The turbo gets VERY hot, so don't touch it until it cools off and please don't toss water on it while its hot... yes, i've seen it done, not pretty.
If it is coming from the turbo itself, you'll want to check gaskets and bolts on the downpipe, intake and exhaust manifold connection. A lot of intakes have just a pipe and a clamp, make sure the clamp is tight and the intake pipe doesn't have a hole in it.
Also, remove the intake pipe and turn the impeller with your hand; it should spin freely. Also look for oil deposits while you have the pipe off.
If the impeller doesn't spin freely, you may have a bearing issue.
If you see oil, the oil seal may be leaking; it'll need to be replaced.
If it's not the turbo, come back and post where the noise is coming from and I'll try to give you some pointers.
2005 UZJ100
OME T-Bars, OME 2" 'Heavy' Lift Kit, Slee Diff Drop, ARB Combo Bumper, Warn XD9000, Slee Rear Bumper w/Tire Carrier, Slee Sliders
I know the voices aren't real, but sometimes they have good ideas...
cruiser100 is offline   Reply With Quote
Old 06-05-09, 01:38 PM   #4 (permalink)
Cruiser100 i know that all turbos make a sound, but this sounds lika the boost is leaking, just thinking if u new of any common places to look at.. No echaust work or under the hood work, except bulbs changtes ^^
Old 06-05-09, 02:36 PM   #5 (permalink)
MC92MR2's Avatar
check for a exhaust manifold leak, I had a warped exhaust manifold on my 92 MR2 turbo and it made a whistling sound under acceleration due to exhaust escaping between the manifold and the engine. good luck.
MC92MR2 is offline   Reply With Quote
Old 06-05-09, 02:38 PM   #6 (permalink)
hks3sgte's Avatar
x2...
Looking for an FJ55.
hks3sgte is offline   Reply With Quote
Old 06-05-09, 03:13 PM   #7 (permalink)
Comfortably Numb
cruiser100's Avatar
Check what I mentioned in my previous response. If you find nothing let us know.
The basics are some of the items you already mentioned (hoses, clamps, etc.). It's rare to see an intercooler leak but I've seen one or two.
First find out where the noise is coming from...
2005 UZJ100
