Cv-boots
After installing the OME t-bars I started to notice some some milky looking grease coming from my cv boots.The truck only has 62000 miles.What is the life expectancy of the boots?Do you think the t-bars had something to do with it? Maybe angles changing?Any suggestions?
it has only been about a week. Do you think the rubber has just become weak? I was hoping to not have to install the slee kit.What would you do?
If the CV boots are actually split there's only one thing you can do: Change them before damage is done to the CV joint, which will make it more expensive.
It is possible that during the t-bar installation process they move them to a greater angle and cause them to split. Age more than miles is what makes rubber harder and drier and thus easier to split, it could've been careless handling during installation of t-bars. Talk to your mechanic about it and see if at least he gives you a break in the labor price to change them. __________________ mtycruiser 98 UZJ100 |
#5 | |
what would I do, I have a Slee Drop kit on its way(as soon as its ready)
But a week shoudn't have been nearly long enough..............but maybe it was. How far did yuo crank the bars up? Quote:
My mechanic is working with me.The dealorship wanted 668$ and my guy is doing it for 120$ a side. We only cranked the bars up enough to level it out.I had installed a ARB bull bar and a 9000 WARN. The t-bars did the trick and it rides so nice! We also put a set of goodyear mt's(285/7516s)which worked out quite well.I will check into the drop kit from slee. thanks for all of your help.
Just checked out the drop kit from slee.It looks like it will do the trick.
I been running the front cranked 2" with no drop kit for about 12K miles with no problem. I have cranked front torsion bar on various Toyota truck, Isuzu and Mitsubishi truck with no problem. What probably happened is Toyota stuffed too much grease into the boot and when lifted and wheel fully turned left or right it forces the grease out from the boot due to the reduced volume inside the rubber boot.
I have not heard yet somebody wear the front CV joint prematurely in Australia and they have been lifting LC since 98 with no diff lowering kit. Does it look normal? Of course not and you only seen that normally on cars with torn CV boot. It makes me nervous the first time I saw that but I been watching for cracked or torn boot and so far so good. Would it increase wear? Definitely. But how much? Probably not much to make a concern. Of course I am still going to get Slee differential drop braket. |
#10 | |
true and I also forgot I drove my 87 4runner for 4 years with Rancho T-bars cranked up.....with no issue.............now I feel better
![]() Quote:
#11 |
You want to do what...?
if they are torn, could be from stretching during Tbar installation?
E __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
#12 |
I don't see how CV boots could be damaged when installing the torsion bars. On a lift, the suspension is drooped out maximum and that is all that happens when you install the new torsion bars. If they split from being overextended to this position, then the rubber was already damaged or old (which is unlikely for the age of these trucks).
If yours started leaking within a week of changing the suspension, they were probably on their way out in any case. It might be a clamp that is letting some grease out. You can buy a boot reseal kit. Requires removing the side shafts, disassebly, clean, regrease and install new boots. |
#13 |
PS, the grease inside the CV's look like smooth peanut butter. Both in color and consistancy.
Do you by any chance do a lot of water crossings? |
#14 |
In my opinion, ANY lifted front end on the 100 should also receive a diff-drop kit (like Slee's). It ONLY helps and doesn't hinder. Keeping those angles as close to stock as possible is very important for the life of the boots and joints. It also saves them while off-roading because they operate at better angles with the diff drop.
My 100 has been lifted for over 65K hard miles. Mostly at 2.75-inches above stock. During all of that time there was some added seepage from the boots due to the angle. The angle also effects the clamps effectiveness to stop the seepage. At 80K miles I got lucky. My dealer put new boots on under extended warranty despite me really not needing them. (They must have been slow that week?) Bottom line: Don't hold off. Lower your diff now. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/az-arizona-land-cruiser-association/150735-100-series-modification-differences-evaluations-john-shotts.html Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#15 |
seaping boots
I put my tbars on about a 2 weeks ago. I too got some grease leaking out of the clamped area. I squeazed the clamp a little tighter and wiped everything off. not leaking anymore. Not much at all came out, just some light splatter. I think it is probably because the joints are allowed to spend more time at higher operating angle and forcing some grease out. Diff drop should help a bit too. My ride hieght is approximately 2.653124" above stock. Perhaps I should lower it 0.010" to 0.015".
__________________ 99 uzj100 with 4.88's, 305's, etc, 96 w/ most stuff (now in GA), 93 w/ most stuff (sold), 81 fj60, 1990 4runner, |
#16 | |
__________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#17 |
Christo,
Did you install the drop bracket on the Lexus? And, as a 'kinda-related' question, did you have the Lexus' front wheels re-aligned on the 'lifted' setting? __________________ Ryan Loehr 95 FZJ80 99 LX470 ARB Bull-Bar, Slee Sliders, OME Suspension, DC Front Drive-Shaft, etc. for sale!!! |
#18 |
After pulling the boots off we found no cracks or splits.It was only leaking around the clamps on both sides. We would have tried to re-band the boots but like I said there was alot of milky grease. I figured that with all of the water I have gone through that a re-packing of the grease would not be such a bad idea.Upgraded boots to so hopefully they will last quite some time.But a drop kit is still in oder.I live in the ACE BASIN in South Carolina and we have alot of dirt roads around here and alot of swamps.The ACE BASIN consist of 375000 acres of Protected land.It is very beautiful land but very hard on cars. Thanks you guys for all of your help.
#19 | |
#20 |
If your ever this way come and visit.
#22 | |
I've got a thread on here somewhere about when I got my boots replaced. I ran on them leaking for quite some time and the CV's checked out fine when I finally had the boots replaced. I believe I ran on the leaky boots for most of the winter. You know how wet the winter was here last season so they were exposed to the elements alot but still held up OK. Tad __________________ Tad A. 99 LX470 - Slee Sliders & 34" Swampers | 04 Taco DubCab 4x4 TRD | 82 Porsche 911 Upstate Cruisers T-Shirts and Gear Here |
#23 |
Same problem as my 100s. after the installation of the T bars. i noticed that the grease were coming out between the boot and axle. i am afraid that the grease might ran out inside the boot what i did was cut off the axle band and used the zip tie. after that it didnt come out anymore. i really need the drop kit christo.
in the couple of months i will change the axle band and clean up the boot and change new grease. by the way, can i use the CV-2 GREASE FROM REDLINE for the axle ? thank you for your help
#24 | |
As SOON as I installed my OME kit (front lift 2 1/4")..the boots started seeping..and as SOON as I installed the slee diff drop (1 week later) the boots STOPPED seeping...I steam cleaned the mess off the fender liners and A-arms, and 5,000 miles later , and might I mention VERY hard miles..no indication of a leak on the boots...BTW...@ 85,000 miles my original boots are still in perfect condition..this is with 120+ degree summers and well below freezing winters w/hard use + numerous stream crossings and flash flood waters...maybe I am lucky..... __________________ 2000 UZJ100 OME 2" HD lift + "L" shocks, 305/70/16 Toyo MT`s , Slee diff drop, ARB front Bull-bar,Slee rear w/carrier, Custom exhaust, AO roof rack and drawer system, Various custom dents and scratches.... |
#25 |
Brad, Your Situation Is Same As Mine. The Problem Was The Axle Band Went Loose. Due To The Cranking Too Much Of The Torsion Bar. Crank It Down And Put The Diff Drop Kit. In The Meantime Cut The Axle Band A Use A Zip Tie Before Your Grease Dry Up.
#26 |
Amsoil makes a good water resistent syn grease that is supposed to be great for wheel bearings, etc: It's just labeled their "Water resistent syn/lithium grease...blue in color.
#27 |
Zip tie? Has anyone had good luck with a zip tie on the CV boots? Seems unlikely to me, maybe if it were an emergency or something.
I would recommend going to a suspension shop or a driveline place that works on CV joints and have them put a new one on. IMO a zip tie won’t work. Dean __________________ I may be vile and pernicious But you can't look away I make you think I'm delicious With the stuff that I say I am the best you can get Have you guessed me yet? I am the slime oozin' out From your TV set" I'm The Slime by Frank Zappa, 1973 98 Land Cruiser 01 Beta trials bike 71 GMC Shortwide truck |
#28 |
dmx84, the zip tie works for me. i am just waiting for my axle band to be available in the dealer. you dont have to worry about it.
#29 | |
#30 |
FWIW, my inner CV boots started leaking at somewhere around 60k +.
Apparently the band clamps were barely tight enough from the factory to prevent leakage, and eventually allowed slight leakage to start occurring. I replaced with the same type stainless steel clamps. (Had to buy a $20 special clamp-tightening tool made just for those special clamps.) The nylon tie should also work, but nylon may be affected by environment, may become brittle over time if exposed to outdoors conditions. (As in, a vehicle underbody area.) So, your boot leakage may be unrelated to any lift kits etc. - may just be a Toyota factory issue. |
