Old 11-28-04, 11:59 AM   #1
Vibration noise in '99
In my '99 Cruiser I've had a high frequency, harmonic vibration noise coming from the engine area. It sounds like two thin metal plates vibrating against each other. It's worse when I first start it up and accelerate lightly. It doesn't occur under no load (unless on first start up in the morning) or under a steady load. It is not related to engine speed. And, since it typically only occurs while underway, I can't get a look at it while it's happening.
A friend had told me that it was the heat shield plates over the catalytic converter, but it's definitely not coming from that area (the sound is much more forward, in the engine, even front of engine area). Any other ideas?
Bruce J is offline   Reply With Quote
Old 11-28-04, 12:02 PM   #2
Sorry, duplication
Sorry, I accidentally posted this again. Thought it didn't "stick" the first time because I couldn't find it.
Old 11-30-04, 06:48 AM   #3
sleeoffroad's Avatar
It is the shields on the catalytic converter. They break close to the mounting bolts and then rattle like that. Big hose clamp around them will do the trick.
I know you say it is not from there, but have you actuall inspected them?
Christo Slee
www.sleeoffroad.com
sleeoffroad is offline   Reply With Quote
Old 12-01-04, 02:36 AM   #4
80and100cruisers's Avatar
I also have that problem on my 99. It only happens when I start it after a few hours of not being used....and after 30 seconds to 60 seconds it stops. I will check out what you suggest, but why does it not happen on warm starts?
-Matt
1999 UZJ100, 3O5s, Stock Rear Locker, Warn Fog Lights, Yakima Roof Rack
80and100cruisers is offline   Reply With Quote
Old 12-03-04, 06:21 PM   #5
Although it definitely sounded like the noise was coming from the front of the engine, I now think it is the catalytic heat shields. I tried someone's suggestion and just started tapping on things with a plastic mallet. When I tapped on the exhaust behind the cat, it rattled the shields and made a noise very much like I was hearing.
I'll try the big hose clamp suggestion, but also wondered whether it would be good to insert some type of heat-resistant gasket material between the plates where they are vibrating together(?)
Old 12-03-04, 08:25 PM   #6
DMX84's Avatar
That sounds like a good idea to me. Let us know how it works out!
I have the same problem, It really sucks when you are pulling away form a restaurant and it starts that crap!
DMX
I may be vile and pernicious But you can't look away
I make you think I'm delicious With the stuff that I say
I am the best you can get Have you guessed me yet?
I am the slime oozin' out From your TV set"
I'm The Slime by Frank Zappa, 1973
98 Land Cruiser
01 Beta trials bike
71 GMC Shortwide truck
DMX84 is offline   Reply With Quote
Old 12-04-04, 11:48 PM   #7
greglomax's Avatar
Where do I find a big hose clamp that will fit over the converter? Any suggestions? I am so sick of this rattle. It makes a great vehicle sound like it's falling apart.
There are two types of people:
Those that own a Landcruiser, and those that wish they did.
1998 Black Mall Hauler.
greglomax is offline   Reply With Quote
Old 12-05-04, 07:18 PM   #8
Hose clamps
Greg,
I found some large hose clamps at Loews. The one that goes up to about 4 1/2" or 5" was just right. I also put some high temperature liquid gasket material in between the heat shields where they overlap (and rattle!). I put the hose clamp on after putting in the gasket stuff. I'm letting it all set up tonight, and hopefully I'll have a quiet (or at least quieter) ride tomorrow morning.
It all does seem a little crazy to have to make such a "cheap" (in all respects) fix on such a well built and expensive truck.
Bruce
Old 12-06-04, 01:56 PM   #9
greglomax's Avatar
Does the clamp go all the way around the converter or just around the pipe going into the converter. If around the converter, I was expecting to have to buy something that would fit almost around a basketball. Am I just confused?
Old 12-06-04, 06:37 PM   #10
And the results are...
Not a peep, rattle, ring, or noise at all this morning. Smooth as a sewing machine! Can't believe I've finally silenced the beast.
I used the hose clamp and the liquid gasket material like caulking between the overlapping plates. Since I did both, I'm not sure if either method by itself would have worked. My guess is that the gasket material alone probably would have worked.
Greg, the catalytic converters are not as big around as they first seem. The first hose clamps I got were way too big. The 4" model was just right. On my car, the noise was coming from the plates/shields that overlapped at the bottom of the cat , i.e. closest to the ground, and at the front of the cat, i.e. closest to the engine. The hose clamp went around this area which tapers up from the exhaust pipe. So, it's not quite as big around as the main body of the cat. The cat itself seems to be in two parts, with the second part being slightly larger diameter. If you have a rattle in there, it would probably take a 6" or so hose clamp.
I was pretty lucky, so far, that I could find the exact source of the rattle by tapping the mallet on the exhaust pipe. I imagine in others the noise might be harder to locate, or to reach. But I'll take this victory for now and hope it stays quiet!
Bruce
Old 12-07-04, 02:40 PM   #11
Told you so
Christo Slee
www.sleeoffroad.com
Old 12-07-04, 03:26 PM   #12
tabraha's Avatar
TLCA# 15700
I think this is prime FAQ material. There are a fair amount of folks with the mystery rattle, myself included, that could appreciate a cheap effective fix.
Tad
Tad A.
99 LX470 - Slee Sliders & 34" Swampers | 04 Taco DubCab 4x4 TRD | 82 Porsche 911
Upstate Cruisers T-Shirts and Gear Here
tabraha is offline   Reply With Quote
Old 12-07-04, 04:04 PM   #13
NMuzj100's Avatar
Pictures would definately make this FAQ worthy.
NMuzj100 is offline   Reply With Quote
Old 12-07-04, 09:18 PM   #14
I'll try to take a pic and post it in the next few days.
Old 12-12-04, 08:18 PM   #15
greglomax's Avatar
Talking
2 - 7" hose clamps from Lowes ---- $4.00
15 minutes of my time putting them on ---- N/C
Not having my LC sound like it is falling apart when I begin to drive ---- Priceless
What an easy fix.
I have never looked so forward to going to the drive-thru at Wendy's just to not hear the rattle anymore.
Old 12-19-04, 09:13 AM   #16
Okay, here's a pic of my repair with the hose clamp and the red high-temp liquid gasket material that I put between the vibrating heat shields. The part that was rattling was just below the hose clamp where you can see the most gasket material. That's where the shields overlapped.
Old 12-20-04, 05:53 AM   #17
tabraha's Avatar
TLCA# 15700
Thanks for the pics. I bought 4 and 7" hose clamps on Saturday to get this taken care of.
Tad A.
Old 12-21-04, 08:50 PM   #18
Stone's Avatar
TLCA# 13772
I don't know if this would help, but there is a recall for your vehicle for an exhaust rattle noise:
http://www.alldata.com/TSB/60/996034AD.html
#28 on the list.
Stone's Land Cruiser & Flyfishing Pics
Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com
Stone is offline   Reply With Quote
Old 12-22-04, 08:37 AM   #19
madams557's Avatar
TLCA# 12065
Stone - Not questioning what you posted, but how does one go about proving to Toyota there is a recall? Is this site one recognized by the dealership?
Michael Adams
Fort Collins, CO
TLCA# 12065
Horsetooth 4X4
99 UZJ100, (285 BFG AT K/Os), 95 FZJ80 38th Anniversary Edt. (Bull Bar, OME, Slee Tire Carrier), 78 FJ45 Longbed (OME, ARB Bull Bar)
madams557 is offline   Reply With Quote
Old 12-22-04, 09:05 AM   #20
Jukelemon's Avatar
That is a TSB not a recall (unfortunately). Essentially means that a level of complaints have reached a point that would justify a TSB but NOT a recall.
The TSB will get you no where with a dealer.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 12-22-04, 09:38 AM   #21
greglomax's Avatar
This is a service bulletin, not necessarily a recall. It tells how the service technician should go about fixing the problem, I believe. I am going to call the Toyota Dealership to see if they are doing anything about it. If you call to see if this is covered on your vehicle, you will need your VIN #.
Old 12-22-04, 01:10 PM   #22
NMuzj100's Avatar
The TSB originates from Toyota and your Toyota dealer will be able to find it. Will they pay for it to be fixed is another ?
1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts
1999 Toyota Camry - So Boring
Old 12-22-04, 06:03 PM   #23
Stone's Avatar
TLCA# 13772
Ah, I see. I didn't know the difference, but I thought it might generate some interest anyway. Cheers.
Old 06-19-05, 05:16 AM   #24
rule303's Avatar
I too have the exhaust rattle on my 99. Looks like I'm heading to Lowes today!
rule303 is offline   Reply With Quote
Old 06-19-05, 06:52 PM   #25
EOS
I just did the 4.5 inch hose clamp trick today on my 99 LX470, took 5 minutes to install. AHC on high, crawled under and put on 2 of them.
Worked like a charm and its completely noise free.
EOS is offline   Reply With Quote
Old 04-01-08, 11:11 PM   #26
jonah tapert's Avatar
thanks for posting on faq
2002 100 .ome med lift ,slee diff drop, paint to match arb front ,side and rear w tire
2 batt. arb air ,toyo 285 at. k&n intake,warn m 8000 & black windows.
jonah tapert is offline   Reply With Quote
Old 08-02-08, 12:20 AM   #27
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
whats worse is i took two small clamps and put them together to stop the rattling of the driver side shield, worked great....three weeks later now my pass side is rattling! Im going to go get 6 big clamps and clamp the crap out of my shields
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Unity Spotlight/Black'd Trim
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
Need OEM Lexus LX470 Foglights? http://forum.ih8mud.com/sale-parts/2...s-98-02-a.html
Need some Michelin LTX M/S 275/70/16's? http://forum.ih8mud.com/sale-tires-w...-shipping.html
1loudLX is offline   Reply With Quote
Old 08-02-08, 01:00 PM   #28
TLCA# 25959335
i have a rattle that sounds like what you are describing yet after checking the heat shields i cannot figure out where it is coming from. i posted a thread a little while back with minimal results, can anybody help me?
samsher213 is offline   Reply With Quote
Old 08-02-08, 03:02 PM   #29
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
Sam, how did you check for the noise?
when i originally checked my heat shields by hitting various places and listening for vibrations i couldnt pinpoint it. So I waited till I had a second in the morning when the truck was cold and started the motor. At the slightly elevated idle speed during cold-start the shields rattled, and i just got under and squeezed them quiet, which I then just clamped it.
Oo==L==oO
Old 08-02-08, 07:39 PM   #30
nov74fj40's Avatar
here's what I did to check heat shield rattle
I got on my knees took a broomstick and placed it on the heat shield with one hand and hit the accellerator with the other...I could tell from the rattle and simultaneous vibration of the stick that it was the heat shield. I went with the advice on this thread and the clamps worked great...
nov74fj40 is offline   Reply With Quote
