Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 10-03-08, 01:59 PM   #1
How do I lubricate the drivshaft? Do I need a special grease gun and special grease?
I was also interested in changing the axle oil as well as the transfer case oils. What brands of oil do you recommened non synthetic? Also do you know what brand Lexus/toyota uses for these oils. Alll help much appreciated. Thanks so much
01LXNY is offline   Reply With Quote
Old 10-03-08, 02:13 PM   #2
Trunk Monkey's Avatar
TLCA# 11251
You need a tip that will fit on to a zerk (the fitting on the DS). Be careful loading grease into the slip yoke zerk. Some people have over-filled that cavity and then the DS isn't able to compress. The actual axles don't (shouldn't) have oil in them, just the differentials. I recommend synthetic, but for regular oil get what ever is on sale. Not sure what brand they come with from the factory, most dealerships use a house/contract brand and it varies. My local one uses Pennzoil.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 10-05-08, 06:19 PM   #3
NMuzj100's Avatar
The driveshaft uses a very standard NGLI #2 grease (~$2 a tube at a discounter) and a standard grease gun with a flexible zerk head (the standard) is what you need. A moly-fortified EP gease is often recommended at the Slip Yoke to reduce thunk (my 98 FSM only says MP grease, meaning whatever you got) . The front u-joint is a real tight fit with most heads so you may need to search for something with a thin profile.
Any diff oil in 75w-90 will do. I haven't seen a fluid related failure on the board yet and I doubt we ever will if they get changed every now and then. Don't bother searching for a 80W-90.
Most dealerships are not servicing with a Toyota branded fluid but a major name bulk fluid that meets the spec'ed standard.
The driveshaft does not get overfilled. Under-serviced driveshafts get blocked seals and do not allow for proper flow of the grease around the seal
. Read my post #45 in the following thread for a good description of the situation.
http://forum.ih8mud.com/100-series-c...e-shaft-2.html
1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts
1999 Toyota Camry - So Boring
NMuzj100 is offline   Reply With Quote
Old 10-05-08, 07:40 PM   #4
a monkey on the edge
Liam's Avatar
TLCA# 00012
i just greased up the drive shafts on my 100 today....
Originally Posted by re_guderian View Post
It's "Attention-whore", not "ATTENTION: Whore". It makes it sound like you're addressing Noah with a bullhorn. NTTIAWWT...
Liam is offline   Reply With Quote
Old 10-07-08, 04:26 PM   #5
How many places on the shaft?
Also how do I know when I sqeezed enough grease?
Old 10-07-08, 06:18 PM   #6
NMuzj100's Avatar
Squeeze till new clean grease flows from the seals. The goal is to push dirty contaminated grease out and replace it with slippery new grease.
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/243838-how-do-i-lubricate-drivshaft-do-i-need-special-grease-gun-special-grease.html
Posted By For Type Date
Grease Gun | BoardReader This thread Refback 11-08-08 10:45 PM
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
