09-29-08, 10:27 AM
Creaking steering column / wheel
Hi,
I have a slight creak coming from the steering column / wheel. It seems to be worse when it is cold outside and much less noticeable when it's warm. It only creaks when I turn the wheel.
Has anyone else experienced this? Is there an easy fix? I have not taken it to the dealer yet.
Thanks.
2003 Land Cruiser 100 4.7 V8 Thunder Cloud
Mods: OME Lift with Slee Diff Drop, Bump It Off Road Sliders, Dual Optimas with 110V and 12V outlet in the cargo area, Tundra 18" Wheels, DVD Player Hack, Sirius Satellite Radio integrated in sunglass holder, Ultimate Air CO2 Tank - 33's are next
09-29-08, 10:34 AM
Mine does the same thing. I actually had forgotten about that since it seems like it's been a year since I last heard it... weird.
Looking for an FJ55.
09-29-08, 10:40 AM
Mine does it sometimes. Drives me freaking crazy! I took the plastic cover off, tried to spray some dry lube in there, no better! Any ideas would be great.
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers, Misc scratches, etc...
M101 Trailer - Sold & sadly missed...
09-29-08, 10:55 AM
My 62 did it and my 100 does it, albeit not as noticeably... I've always thought it was an LC feature whose purpose I was incapable of comprehending.
'01 LC - Champagne Pearl
'96 328is - Alpine White
Dearly departed - '88 FJ-62
09-29-08, 11:23 AM
It's likely the clock spring that allows turning contact between the electronics in the wheel and the column. My 80 did it when it was cold. Some people have reported the spraying it with lube worked, but you've got to be careful hosing down that area with lubricant (airbag). Friend of mine's got bad enough that he replaced the spring and harness, was about $250 on the 80.
09-29-08, 11:25 AM
sheep fear me
i found out the "squeak" does not come from the steering wheel. If you follow the steering column down you will find a black boot that covers the steering column as it goes through the firewall. I took grease and put it between the circular metal thingy and the cover.....squeak gone....
I hate your face...
GOD MODE ON..
i didnt go the Joe Besser route...although i could have.
Here is the list
Moe = 80 series
Larry = 100 series
Curly = 40 series/105 series
Shemp = 60 series/55 series
Curly Joe Derita = 200 series
Joe Besser = 62 series
Originally Posted by cruiser88
 whats a shower?
Originally Posted by Doc
In WV that's when your sister pee's on your head.
09-29-08, 11:45 AM
Cool, I'll give that a try.
09-29-08, 11:47 AM
sheep fear me
it was driving me nuts b/c i thought it was coming from the steering wheel.....i finally put my head under the steering wheel and turned it...low and behold it was coming from that black boot...
I hate your face...
GOD MODE ON..
Here is the list
Moe = 80 series
Larry = 100 series
 whats a shower?
09-29-08, 02:29 PM
I just tried this. You rock big time if it works!
09-29-08, 02:39 PM
#10 (permalink)
sheep fear me
hope it works....keep us posted...
I hate your face...
GOD MODE ON..
Here is the list
Moe = 80 series
Larry = 100 series
 whats a shower?
09-30-08, 09:33 AM
#11 (permalink)
I just crawled under the dash and tried to find something that resembles a bearing or bushing. I did find a few rubber boots that cover the steering column in various places including a big one that is velcroed to the carpet at the base. Just above that is a small, thick, rubber boot. I just ended up putting some grease on the small universal joint where the column turns toward the firewall. It was pretty warm this morning so I am not sure if it worked (creak is worst when cold).
Can you be more specific about the place where you applied the grease? What is the "metal thingy"?
09-30-08, 04:10 PM
#12 (permalink)
sheep fear me
i will take some pictures. But if i am going off memory there is a universal joint and then a black boot looking thing. I ended up putting the grease between them....as i recall. It's been a while, but it went away when i did that...
like i said, i will try and take pics..
I hate your face...
GOD MODE ON..
Here is the list
Moe = 80 series
Larry = 100 series
 whats a shower?
09-30-08, 09:20 PM
#13 (permalink)
Still squeaking!?  Maybe I need more or different lube?
10-01-08, 05:14 AM
#14 (permalink)
sheep fear me
it took a couple of times of putting grease down there before it fully went away. The last time i just gooped it on.....
your squeak may not be the same as mine was, put your head under the steering column and turn the wheel until you hear it....
btw, i used bearing grease....
I hate your face...
GOD MODE ON..
Here is the list
Moe = 80 series
Larry = 100 series
 whats a shower?
10-01-08, 07:58 AM
#15 (permalink)
Clock spring . . . . . . . . .
