LinkBack (18) Thread Tools Display Modes
Old 08-26-08, 12:32 PM   15 links from elsewhere to this Post. Click to view. #1 (permalink)
mmm.....beer.
socalsuv's Avatar
Door Lock Actuator Replacement
I had the normal symptoms of a door lock actuator gone bad (many threads on this) so I went about investigating this issue over the weekend. I was hoping I could find something that could be remedied by a little bit of cleaning / maintenance, but that wasn't the case.
Removal of the door trim wasn't bad, but getting the door lock assembly out was a bit of a pain (kept getting my arm hair stuck in the tar-like adhesive for the plastic sheeting). Once I got the lock assembly out, I detached the actuator (held on by 3 screws). The actuator itself is not a solenoid as some other threads state. I popped off the cover.....it is actually a small DC motor.
Actuator:
Actuator exploded:
I plugged in the actuator (without the cover and not attached to the lock assembly) to the electrical connector and operated the door lock switch. I could see the motor spinning strongly the first few presses of the switch, but then it would slowly die down. I tried cleaning all the contacts / moving parts, but nothing improved. Since I realized I had to replace the motor, I decided to take it apart and investigate. I immediately saw that the graphite brushes were almost completely disintegrated....not sure if this was the only problem.
So, in an ideal world I could just replace this little $8 hobby motor. The really unfortunate thing is that not even the actuator itself is sold by itself. I tried every avenue for parts searching and can only find the actuator sold with the entire lock assembly (lock mechanism, cables, actuator). This is really annoying since the actuator is a separate component and bolts (screws) on to the assembly. I didn't want to go the junk yard route since who knows how long the used actuator would last.
So I did find the lock assembly cheapest on CruiserParts.net for $169. I called my Lexus dealership to get a price on the assembly just for my own edification. They sell the assembly for $330 and would probably charge $500 total for them to do the job.
A few cents worth of graphite in the brushes of a motor results in a potential $500 repair.
If anyone ever finds a way of just buying the actuator and not the whole assembly, I would love to hear how you did it.
socalsuv is offline   Reply With Quote
Old 08-26-08, 12:37 PM   #2 (permalink)
uzj100's Avatar
You are the man! Thank you for the research. The question is where can we source that little motor. Are there any kind of markings on the little motor that would help in the search?
Thanks again,
uzj100
00 - UZJ100 - Step Sliders, Diff Drop, 865s, FRB's, BAK - 285/75 R 16
03 - UZJ120L
uzj100 is offline   Reply With Quote
Old 08-26-08, 12:45 PM   #3 (permalink)
mmm.....beer.
socalsuv's Avatar
Thanks again,
uzj100
No markings on the motor, but I think the problem is that the motor is a very specific shape with a very specific connector (two prong....see photo).
Old 08-26-08, 12:57 PM   #4 (permalink)
uzj100's Avatar
Bad Door Lock Actuator - Lexus Owners Club (USA & Canada)
http://cgi.ebay.com/5-NEW-Mabuchi-Mi...d=p3286.c0.m14
Check out the ebay link. THis is the one used to fix lexus door locks.
Does the gear on the front of the motor unscrew?
03 - UZJ120L
Old 08-26-08, 01:43 PM   #5 (permalink)
mmm.....beer.
socalsuv's Avatar
I think I may have found the motor.
JOHNSON ELECTRIC Product Catalog
Dimensionally, the motor seems to be the same (or very close.....+/- .2mm). Its application is listed as "door lock".
Other than how to purchase the motor, the only remaining issue is the copper colored collar on the motor shaft that engages the worm gear (see photo).
I'm hoping the collar is just press fit on to the shaft splines. I will try to remove it and see what happens.
Old 08-26-08, 01:46 PM   #6 (permalink)
mmm.....beer.
socalsuv's Avatar
Wow.....YOU are the man. That looks like the exact motor, with the copper colored collar. The dimensions match exactly. 5 motors for $4.98!!!! I'm going to buy these and see what happens.
Old 08-26-08, 01:53 PM   #7 (permalink)
uzj100's Avatar
Now we need to figure out how to fix the windows and those motors!
Thank you for the great pictures and write up.
03 - UZJ120L
Old 08-26-08, 01:55 PM   #8 (permalink)
mmm.....beer.
socalsuv's Avatar
I just ordered the 5 door lock motors from eBay for $10 shipped. My door lock assembly order had not yet shipped from CruiserParts so I just cancelled it. If these motors work, I think we found a $10 solution for all 5 door locks failing on our cruisers. Thanks for the eBay link UZJ100!!! I will follow-up on this thread once they arrive and I try them out.
Old 08-26-08, 04:14 PM   #9 (permalink)
Supporting Vendor
ringpinion.biz's Avatar
Nice work!
Nice work on this one. Looking forward to the results.
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801 x113
carl@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Old 08-26-08, 05:43 PM   #10 (permalink)
Zenmaster
Travis351's Avatar
TLCA# 16092
Amazing! What did you use for search terms to find them so quickly? Great thread!
Travis
1999 UZJ100, TJM T-3, OME 866 Heavy kit, dual batteries, Engel fridge, pin 7, Custom Sliders, 4X4 Labs Rear Bumper, Onboard Water & Mombasa Penthouse.
www.RealEstateBook.com
Travis351 is offline   Reply With Quote
Old 08-26-08, 06:26 PM   #11 (permalink)
uzj100's Avatar
I just googled, "door lock mini dc motor" and the Club Lexus - Home started popping up all over and then on to Ebay.
I hope it works. My door lock is driving me crazy.
03 - UZJ120L
Old 08-26-08, 06:47 PM   #12 (permalink)
mmm.....beer.
socalsuv's Avatar
I already got a notice from the eBay seller that he put the motors in the mail today. I'll be on vacation for a long Labor Day weekend until Tuesday night. I'll try the motor out first thing Wednesday and post back the results.
Old 08-26-08, 08:45 PM   #13 (permalink)
pint's Avatar
TLCA# 17493
Let us know if this works as my drivers door is acting up occasionally. You da man!
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers, Misc scratches, etc...Sold...What is next???
M101 Trailer - Sold & sadly missed...
pint is offline   Reply With Quote
Old 09-03-08, 02:22 PM   #14 (permalink)
mmm.....beer.
socalsuv's Avatar
So I got the 5 new DC motors in the mail from eBay. They fit perfectly in to the actuator.
I applied some dielctric grease on the contacts of the actuator clamshell and then epoxied both halves of the clamshell back together in a few spots. There is a lot of torque in that little motor and if you don't secure the clamshell together, it will blow apart. You don't want to go overboard on the epoxy / adhesive either or else you won't be able to open it up again to replace the motor if/when it dies.
I then plugged in the actuator (disconnected from the assembly) to verify that it worked and worked strongly....it did.
Here is the "actuator" attached to the door lock assembly. This is the entire assembly that all dealers will want to replace.
SUCCESS!!! I now have a perfectly functioning door lock!
So as a recap.....the 5 motors cost me $4.98 plus shipping.
Old 09-03-08, 02:24 PM   #15 (permalink)
uzj100's Avatar
Sweet. How did you get the little gear off the original motor and on the new motor?
03 - UZJ120L
Old 09-03-08, 02:30 PM   #16 (permalink)
mmm.....beer.
socalsuv's Avatar
It just slides right off....almost too easily if you ask me. There is a flat spot on the shaft collar that drives the gear.
Old 09-03-08, 02:35 PM   #17 (permalink)
uzj100's Avatar
Thanks for all the leg work on this. I am ordering motors now.
uzj100
Ordered!
03 - UZJ120L
Old 09-03-08, 03:21 PM   #18 (permalink)
knorrena's Avatar
Here is another way. Order the rear door lock actuator from an lx450 at cruiserparts.net. These cost $30 a pop. Inside is the little motor you need. I have replaced 2 door lock actuators this way, and keep a few of these actuators in my spare parts bin. In fact almost any toyota product uses these little motors - my wifes rx needed the rear actuator replaced and I ordered a new one (it had mechanical issues not elector-mechanical) and the left over one has that little motor in it as well.
Cheers,
Karl
1997 LX 450 202000kms, locked, 285 Revos, Supercharged.
2004 lx 470 61000kms stock
You cant kill yourself on a pogostick. (Harry Parker, world famous geostatistician)
knorrena is offline   Reply With Quote
Old 09-03-08, 04:05 PM   #19 (permalink)
mmm.....beer.
socalsuv's Avatar
Cheers,
Karl
Good to know, but don't think that its necessary to pay $30 for a motor when we've found them for under $1 a peice.
If the eBay seller runs out of these motors, they are made by Mabuchi. The Mabuchi part number is: fc-280pt-22125. You can google the part number and find them many places.
Old 09-03-08, 04:26 PM   #20 (permalink)
WOW! You guys are amazing!
Not a solenoid, huh? Must be a fast motor, or geared up to actuate the lock quickly.
Might have to buy me a few motors as spares...
And, to think that the Club Lexus forum found about this before IH8MUD!
EDIT: I noticed on the Ebay listing the motor is 14,500 rpm! Fast motor indeed!
BillWms01
'08 FJ Cruiser
'04 uzj100
'00 uzj100
'79 4x4 Mini Truck
'88 FJ62 (Sold)
BillWms01 is offline   Reply With Quote
Old 09-03-08, 04:36 PM   #21 (permalink)
mmm.....beer.
socalsuv's Avatar
Yep....when I first tested the new motor in the actuator, I didn't yet epoxy the actuator shut and didn't think to clamp it. I hit the door lock button and one half of the clamshell flew about 10 feet across my driveway.
Old 09-04-08, 07:12 AM   #22 (permalink)
uzj100's Avatar
Club Lexus has been using this fix for a while on many different models. The question is now, how do we fix the window motors? Mine windows are as slow as molasses in winter time. We need chevy speed on the windows.
03 - UZJ120L
Old 09-04-08, 07:45 AM   #23 (permalink)
pint's Avatar
TLCA# 17493
Thanks guys for finding the motors and the great writeup! I just ordered mine to fix my drivers door.
Old 09-04-08, 09:17 AM   #24 (permalink)
Trunk Monkey's Avatar
TLCA# 11251
Adding to the FAQ, great find.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 09-07-08, 06:33 PM   #25 (permalink)
Thanks so much for this post. I bought the new motors from Jeff on the ebay link & they arrived a few days later. With a freshly R&R'd actuator, I was finally able to program my spare remote:
IH8MUD™ Forums - View Single Post - Programming instructions for Remote Key Buttons
here's a link for removing the door panel:
newbee_mechanic/Door Panel - Photobucket - Video and Image Hosting
Some stuff like this bears reposting. Credit to originators -- Thanks!
donco
'00 LC-100, 120k miles
donco is offline   Reply With Quote
Old 09-08-08, 09:19 AM   #26 (permalink)
This is a fabulous thread and it is an excellent addition to the FAQ. Great photos and step-by-step instructions. Bravo!
-Michael
ArizonaCruiser
2001 UZJ100 Stock
ArizonaCruiser is offline   Reply With Quote
Old 09-23-08, 06:31 PM   #27 (permalink)
GILBERTO PEREZ's Avatar
Thumbs up Mabuchi
I JUST RECIVE MY 5 NEW MABUCHI MINI MOTORS. IM GOIN TO R&R THE RIGHT REAR DOOR LOCK MOTOR, TANK YOU FOR THE INF.
BAJA FZJ80
GILBERTO PEREZ is offline   Reply With Quote
Old 09-25-08, 03:13 PM   #28 (permalink)
Rookie
Fantastic ... a Q though!
Hi there,
Guys you are doing great job!
I have just registered to ask this question..
I am not sure if i'd be welcome to post it thought ... since it's related to Jeep Grand cherokee?
It's in this very subject you guys are talking about. I basically need to replace the mini motor inside the door lock actuator. I have searched the net for that part but no success!
I have found that the brand is a Mabuchi but i just can't get the specs, like the RMP and the others! otherwise i would have bought it from eBay.
So, just in case it's OK to post it, here goes my question, does it matter that i pick the exact specs for that motor or just having a 12V DC motor (same brand and size) with any rpm will do?
Thanks and sorry for intruding!
day dreamer
day_dreamer is offline   Reply With Quote
Old 10-22-08, 04:33 PM   #29 (permalink)
Originally Posted by day_dreamer View Post
Hi there,
day dreamer
At $5 plus postage you can hardly go wrong, I'm buying some at that price just in case mine fail and these possibly fit the later models!
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Old 12-28-08, 10:46 AM   #30 (permalink)
Zenmaster
Travis351's Avatar
TLCA# 16092
Alright...any real time details on how to "Pop off" the Actuator cover? Mine is pretty stuck. Prying with a screwdriver isn't working well.
Also...I broke part of the little yellow plastic thing that holds the metal rod from the assembly into the lock cylinder tab on the door. It might hold with one tit left, but any advice on a more secure solution for this would be welcomed while I have the door apart.
Travis
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/237827-door-lock-actuator-replacement.html
Posted By For Type Date
Thread Door Lock Actuator Replacement | IH8MUD.com Forum - The Truth is in the Rocks | Page 6 | BoardReader This thread Refback 11-09-09 01:40 AM
Power door lock actuators and proteges - Mazda Forums This thread Refback 11-03-09 10:33 PM
Power Door Lock Actuator On 98 Ls - Lexus Owners Club (USA & Canada) This thread Refback 11-03-09 08:18 PM
Power door lock actuators and proteges - Mazda Forums This thread Refback 09-04-09 09:16 AM
Power door lock actuators and proteges - Mazda Forums This thread Refback 09-04-09 12:23 AM
Door Lock Actuator Replacement on 100-Series Cruisers - Page 6 | BoardReader This thread Refback 07-16-09 05:49 PM
Mabuchi Motor FC 280PC 22125:eBay Motors (item 160341104546 end time Jul-09-09 16:41:43 PDT) This thread Refback 07-04-09 10:21 AM
ebay (item 160341104546) This thread Refback 06-10-09 03:18 PM
Untitled document This thread Refback 06-09-09 05:43 PM
Herfers Paradise This thread Refback 06-07-09 06:21 PM
Lexus Owners Club (USA & Canada) > Front Passenger Door Lock This thread Refback 05-29-09 12:55 PM
Door Lock Actuator Replacement on 100-Series Cruisers - Page 2 | BoardReader This thread Refback 05-13-09 08:19 PM
Front Passenger Door Lock - Lexus Owners Club (USA & Canada) This thread Refback 05-04-09 09:33 AM
Used Struts? - Club Lexus Forums This thread Refback 03-19-09 07:06 AM
Pic 2008 Nissan Pathfinder V8 Se Desert Stone, Piaggio Performance Upgrades, Pick A Part Auto Salvage Yards Southern California - Pandaendangered This thread Refback 03-07-09 03:32 AM
2000 LX 470 power locks OUT! - Club Lexus Forums This thread Refback 01-25-09 02:02 PM
jeep cherokee door actuator - forum post summary | BoardReader This thread Refback 01-19-09 06:25 AM
Toyota Landcruiser Owners Club (UK) :: View topic - Door lock actuators fix for 100 series, maybe many others This thread Refback 11-05-08 03:03 AM
