08-19-08, 10:41 PM
#1
Trim packers and shock top nuts
hey guys, i just installed an OME 866 HEAVY KIT over a month ago and i was wondering if possible to add 15 mm trim packers on each side of the rear springs to add more lift? if it's possible, where should i place the trim packers, top or bottom? i know the shock top nut is supposed 51 ft lb, .. since i don't have a torque wrench how can i tell if the shock top nut is tight enough?
thanks for the help...
98 UZJ100...120,000 MILES, OME 866 HEAVY KIT, SLEE DIFF DROP AND STEP SLIDER
BFG 285'S, MOBIL 1 SYNTHETIC...
08-19-08, 10:47 PM
#2
If you are going to add trim packers you add them to the top of the coil.
Hmmm...estimating ft lbs...got me there.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
08-19-08, 11:18 PM
#3
so i can place both 10 mm and 5 mm together on top, right? how about the black rubber piece that goes on top of the coil spring, do i get rid off it?
08-20-08, 01:25 AM
#4
I left the black coil trim on the coil and then just added the packers atop that...
Please keep in mind the experts prefer no packers. But I haven't had issues in running them on my rig over the past 3+ years of relatively hard off-road wheeling.
08-20-08, 12:12 PM
#5
I've run trim packs for years as well. No issues though not as good as an all-spring setup. Keep the black rubber pad atop the trim packs.
08-20-08, 08:01 PM
#6
You can get 30mm ones from ebay
190243933848
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
