Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 08-11-08, 07:21 PM   #1
repairing drivers door glass plastic holder to regulator
Hi, all
the holder that hold the glass has broken off,i have tried JB weld no luck and epoxy with no luck either.Does anyone have any idea? You have to buy the glass just to replace that holder $280.I was thinking of drilling the glass and holder with a diamond tip drill and using a bolt to hold them together. The circle one is the one that's broken.
Erven.
06 Cayenne
98 LC
98 RSP supra turbo
jahmaka is offline   Reply With Quote
Old 08-11-08, 08:30 PM   #2
Trunk Monkey's Avatar
TLCA# 11251
Try the glue that you can get at Autozone type places that is for gluing a rear view mirror on. However, I have heard from some people that they haven't had good luck with that and they've gone straight to an auto glass repair place. Apparently they get the industrial grade stuff.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 08-12-08, 12:10 AM   #3
Can you drill in tempered glass?
parnoren is offline   Reply With Quote
Old 08-12-08, 07:58 PM   #4
i am not sure either.
06 Cayenne
98 LC
98 RSP supra turbo
Old 08-12-08, 08:37 PM   #5
mobi-arc's Avatar
You don't want to do that....it's meant to break away without shattering the window. That said, I did see a write-up on the board where someone successfully repaired it.
'98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's
www.perfectswitch.com
mobi-arc is offline   Reply With Quote
Old 08-12-08, 08:53 PM   #6
NMuzj100's Avatar
Try this thread ...
http://forum.ih8mud.com/100-series-c...dow-loose.html
1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts
1999 Toyota Camry - So Boring
NMuzj100 is offline   Reply With Quote
Old 08-12-08, 09:38 PM   #7
Ok, thanks guys.I see there is a problem with that holder.I forgot to say i brought a new regulator,that's when i saw that the plastic holder broke, i installed it any way.
Well this is my second chance at trying to repair it, the first epoxy didn't work, so i went to work and got some airplane 5 min epoxy (you know the type we use to hold the wings on when there is a problem right at departure ). So let see if it works this time.
06 Cayenne
98 LC
98 RSP supra turbo
Old 08-21-08, 10:54 PM   #8
Well my repair didn't work.Found out my ins will replace the window plus retint it.
06 Cayenne
98 LC
98 RSP supra turbo
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
