Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 08-05-08, 08:01 PM   #1
Cook Free or Die
alvarorb's Avatar
TLCA# 12833
Diesel 100 Series alarm system HELP
Guys,
I have a friend from Spain who is going cross country on his Diesel 100 Series.
Right now he's stuck in Flagstaff, AZ. To make a long story short, his starter caught fire and had to tow the truck to a mechanic. He left the truck in Flagstaff and went to Vegas while the truck was being repaired.
The mechanic was able to rebuild the starter. However, the mechanic working on the rig can't get the truck started because the alarm system keeps beeping.
Tomorrow, they'll take another hack at it. But it seems that at the root of the problem is the alarm system.
Any ideas on how to disable the alarm system?
My friend speaks very little English and I'm here working as an interpreter between him and the mechanic. Any local Cruiserheads with intimate 100 Series alarm system knowledge in the area?
Regards
Alvaro
Alvaro Rodriguez
96 FZJ80 "La Cabra"
08 Tacoma Double Cab 4x4
TCLA #12833 / BRC # 41799
KI7FZJ
New web site with blog and pics
Norcal wagons website
INTI Roof Racks
Make a loan, Make a difference - Kiva.org
alvarorb is offline   Reply With Quote
Old 08-06-08, 12:38 AM   #2
OEM alarms differ in every part of the world, mine has a single button fob to push to open the doors, which disables the alarm. If you use the key to open the door, I can still start it but the hazards continue to flash as you drive down the road. Is it a turbo diesel or naturally aspirrated? To remove the alarm, it is a simple matter of unplugging the alarm module under the bonnet. 2 connectors to remove IIRC. That is the alarm function. The immobiliser which is built in is another story. If he can get IGN on, can the starter turn over?
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Old 08-06-08, 08:45 AM   #3
Cook Free or Die
alvarorb's Avatar
TLCA# 12833
The engine on this thing is a 1HD FTE.
The engine does turn, but it does not start up.
Regards
Alvaro
Alvaro Rodriguez
96 FZJ80 "La Cabra"
KI7FZJ
INTI Roof Racks
Old 08-06-08, 09:18 AM   #4
spressomon's Avatar
When this happened to a friend of mine's 2UZ (petrol 100) we were able to reprogram the key to ECU. However in some of the cases Toyota has replaced (no-charge for the parts one tiime only) the entire ECU.
100TD: Is the procedure for reprogramming/programming the key to the ECU the same for diesel/non-diesel 100's?
Alvaro: You might also have them try, assuming they haven't already of course, disconnecting the battery for 30-minutes to reset the ECU's. This will not be a substitute for the key reprogram/program sequence but its worth a try.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
