Check to see where the play is. You can adjust the cable play out at the rear axle. Otherwise the pads are adjustable like any drum brake via the access window on the inside of the drum area.
Replacing the drum pads for the parking brake are like any other...not too bad really.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
