Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 08-05-08, 10:26 AM   #1
LSUfj's Avatar
CV's. What needs to be replaced?
I have a clicking sound that I havent narrowed down yet. It sounds very much like a rock in the tire, but its been there for a few months now. I recently did the front brakes, bearing repack, and installed an OME lift and diff drop. Boots looked fine at that point. On to my question...
If my noise turned out to be a "bad" CV, what does this mean? What parts actually go bad? Ive read about a CV kit, is this just new boots, clamps, grease? Doesnt seem like much could go wrong with the joints....
School me.
Thanks!
75 FJ40, 33x10.5s, restoration in progress
01 UZJ100 OME 866, helton HX, custom storage drawers, BFG 285/16s
LSUfj is offline   Reply With Quote
Old 08-05-08, 10:32 AM   #2
Trunk Monkey's Avatar
TLCA# 11251
The joints are just like the birfs in your 40, just sealed. Most of the time if there's an issue with a CV it's that the boot has torn, it's lost most of the grease, and the heat causes damage.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 08-05-08, 10:39 AM   #3
Dain Bramaged Member
rusty_tlc's Avatar
TLCA# 15069
School me.
Thanks!
You have ball bearings inside a cage rotating every time the rig moves, plenty can go wrong there if they run dry or dirt gets inside.
The CV kit is a PM only, as you state it includes the boots clamps and grease.
Dan Johnson
Originally Posted by DSRTRDR View Post
maybe your life took a vacation without you and that's why you are going crazy........
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 08-05-08, 10:39 AM   #4
LSUfj's Avatar
So, do you replace the joints only? I searched and found an "axle" replacement, but was unclear as to what was included with the "axle". The shaft clearly was not broken. Sorry for my lack knowledge. Do most people get by with new boots, grease and clamps?
Old 08-05-08, 10:41 AM   #5
rusty_tlc's Avatar
TLCA# 15069
AFAIK the axels are sold as assemblies, everything between the diff and the drive hub.
The CV axel is like two birfields with a center section. The birfield sections are covered with a rubber boot to keep the grease in and dirt out. If your CV joints are worn to the point that they are making noise replacing the boots probably won't be a long term fix. As I posted above the boot kit is a PM you do before the joints run dry.
Dan Johnson
Rust never sleeps.
Old 08-05-08, 10:45 AM   #6
TLCA# 11251
Yep. If the joint is indeed bad, you just replace the whole thing. Someone mentioned the NAPA joint, like $150 and lifetime warranty. If the boots are torn or leaking and youv'e caught it early, then you can just reseal/reboot them.
Cory Fillmore
99 UZJ
Old 08-05-08, 10:46 AM   #7
spressomon's Avatar
Correct. You can, naturally, get them from Toyota but NAPA also sells a complete CV axle assembly for $100-$110 per side (brand new, lifetime guarantee, better CV boot clamps than OEM) but I do not have direct experience with the NAPA unit (yet).
For a lifted rig and one that sees off-road use I would recommend changing the OEM Toyota boot clamps/bands to the style you are in control of the pretension (available at NAPA). I had to do this on my new OEM replacements within 20K...which kinda pissed me off really given how much the OEM CV axle assemblies cost (>$300 per)!
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
Old 08-05-08, 10:49 AM   #8
LSUfj's Avatar
That ought to cover it. Thanks guys! everything I needed to know in less than 20 mins!
Old 08-05-08, 10:58 AM   #9
rusty_tlc's Avatar
TLCA# 15069
Is there a gender to the axels? (ie DS - PS)
Dan Johnson
Rust never sleeps.
Old 08-05-08, 11:05 AM   #10
TLCA# 11251
Yep, they're right and left. Not sure on what the difference is since there's no long side/short side on the 100.
Cory Fillmore
99 UZJ
Old 08-05-08, 11:14 AM   #11
fish2live's Avatar
anyone have the part numbers of the NAPA clamps and tool for that clamps?? Mine are now leaking, but the boots aren't ripped and it's clear they are leaking from the small end - time to reclamp.
'03 Hundy - Color matched ARB Sahara & ARB Rear, Warn M12K, Hella FF4000 135w, REVO's, DVD Hack, Bilsteins, HIR, Hellroaring Dual Battery, ScanGuage II, DRL's off, Fogs work w/ High Beams
'92 80- sold to brother-in-law!!
'01 KTM EXC453 Dual sported, REKLUSE, Yoshi
www.pacificflyfishers.com
fish2live is offline   Reply With Quote
Old 08-05-08, 11:23 AM   #12
spressomon's Avatar
I wasn't aware they are dedicated left/right; I certainly can't tell them apart. Hundy guys typically carry one spare CV that will work on either side for trail side repair if necessary.
Old 08-05-08, 11:33 AM   #13
TLCA# 11251
Strike that, same part no.
Constant Velocity (CV) Driveshaft - Left Front - Remfd
NMD
954188 $61.89
Core $94.00
Constant Velocity (CV) Driveshaft - Left Front - New
NMD
944038
$110.00
Constant Velocity (CV) Driveshaft - Right Front - Remfd
NMD
954188 $61.89
Core $94.00
Constant Velocity (CV) Driveshaft - Right Front - New
NMD
944038
$110.00
Cory Fillmore
99 UZJ
Old 08-05-08, 11:44 AM   #14
rusty_tlc's Avatar
TLCA# 15069
NMD
954188 $61.89
Core $94.00
NMD
944038
$110.00
NMD
954188 $61.89
Core $94.00
NMD
944038
$110.00
That makes more sense.
Dan Johnson
Rust never sleeps.
Old 08-05-08, 03:23 PM   #15
Comfortably Numb
cruiser100's Avatar
TLCA# 17632
Has anyone seen the NAPA units versus OEM? Has anyone used them?
For a third of the price, I was wondering about the quality...
2005 UZJ100
OME T-Bars, OME 2" 'Heavy' Lift Kit, Slee Diff Drop, ARB Combo Bumper, Warn XD9000, Slee Rear Bumper w/Tire Carrier, Slee Sliders
I know the voices aren't real, but sometimes they have good ideas...
cruiser100 is offline   Reply With Quote
Old 08-07-08, 05:51 PM   #16
ginericLC's Avatar
TLCA# 7328
Just go into the store and ask for CV clamps. They will have a case of them in the back and sell them by the piece. Measure before you go in so you can get the correct size. I brought home the wrong size the first time. I don't recall what the right size was now. One bad thing, these clamps are made in China. But as I found out all of the after market clamps are made in China. I have a Toyota OEM reboot kit for both boots for both axles brand new I'd sell if someone wants it. I decided to just replace the small clamps and so far I've been OK.
Eric V. TLCA 7328
99 UZJ100 "Barnicle Edition" under construction
FJ68 PROJECT aka LEGO(60 body, 80 Chassis/Running Gear)
74 FJ15 (that is about all that is left of it)
Lots of Parts FS http://forum.ih8mud.com/sale-parts/2...ml#post3693029
ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
ginericLC is offline   Reply With Quote
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
