Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 07-28-08, 02:23 PM   #1
grimmcruiser's Avatar
Labor Saving Shock Tool?
Ok, getting ready to replace the shocks. I know 1-3 are pretty standard, but good old number 4, RPS is supposed to be a bear. What is the cute little tool that turns this from a suicidal depression to a knuckle banger?
75 FJ 40 2" Lift, Electronic Ignition, Rancho Shocks, Extra Fuel Tank, Brush Guards and a Bill of Sale, should never have done that...
99 Land Cruiser, Stock for a little while...
grimmcruiser is offline   Reply With Quote
Old 07-28-08, 02:25 PM   #2
You'll need a ratcheting wrench, the size of which I've forgotten.
99 UZJ100, '04 TUNDRA DC 4X4, WIFE'S '08 Solara SLE convertible.
9toys is offline   Reply With Quote
Old 07-28-08, 03:29 PM   #3
LSUfj's Avatar
i think the stock shocks use a 17 mm might be 19, OMEs use a 22. Nothing too complicated. You can use a pipe wrench on the upper shock body (of the shocks you are tossing out). On the new ones, use the strongest hands you have. Its really not that bad. I found it to be one of the easier parts of my OME lift install, but mine spent its adolecense in California.
75 FJ40, 33x10.5s, restoration in progress
01 UZJ100 OME 866, helton HX, custom storage drawers, BFG 285/16s
LSUfj is offline   Reply With Quote
Old 07-28-08, 06:26 PM   #4
SINCITY100's Avatar
I cant remember what the standard OME shock uses, but if you`re running the "L" shocks in the rear, I believe its a 19mm nut on top. And yes, a ratchet- type (19mm?) wrench would be your best bet for that PITA top nut .
2000 UZJ100 OME 2" HD lift + "L" shocks, 305/70/16 Toyo MT`s , Slee diff drop, ARB front Bull-bar,Slee rear w/carrier, Custom exhaust, AO roof rack and drawer system, Various custom dents and scratches....
SINCITY100 is offline   Reply With Quote
Old 07-28-08, 09:48 PM   #5
mcalvarez73's Avatar
17mm for oem and 22mm for OLD MAN EMU...
mcalvarez73 is offline   Reply With Quote
Old 07-28-08, 11:20 PM   #6
NMuzj100's Avatar
Somebody said a strap type oil filter tool was just the thing to grip the shock tube.
1998 UZJ100 115K 285/75 Revos, D-light mod, DIY - Starter Contacts
1999 Toyota Camry - So Boring
NMuzj100 is offline   Reply With Quote
Old 07-29-08, 03:20 AM   #7
Shoot me down, but IIRC when I changed my rear shocks from stock to OME 101's(?) the stock shock was 22 I think, and the nut on the replacement OME was a thin walled nyloc of 17/19 I think.
I have a VISEGRIP chain wrench which I used on the top of the shock to hold it and swing it back and forwards just using a a ring/open ender spanner on the nut without taking it off the nut every time.
EDIT: so we all think different sizes........will have to check!
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Old 07-29-08, 08:17 AM   #8
LSUfj's Avatar
I am in agreement. Important thing is that you have both of these sizes in a ratcheting wrench.
Old 07-29-08, 10:00 AM   #9
I am going with Bilsteins. Do they use the factory size?
Old 07-29-08, 10:02 AM   #10
Trunk Monkey's Avatar
TLCA# 11251
Gear wrench makes it easy, but it's not an absolute. We did mine with a normal box end, took a little longer, but worked fine. Big channel-locks to grab the shock were the ticket.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 07-29-08, 07:40 PM   #11
Need smores!
Campfire's Avatar
TLCA# 16416
Yes, I just put on a set of Bilsteins and the it was the same size POS knuckle busting nut up on top.
They ride nice, but I found out after the fact that they are 3/4" shorter than stock.
And did I mention that top nut is a bitch.
Jeff
1999 UZJ100, 285's, TJM front, Warn HS9500, four pinion front diff, rear locker, 7 Pin Mod, Airlift rear bags, OME 865 springs, Slee Offroard rear bumper, too much stuff.
2004 Lexus RX330 for the wife
1997 Subaru Outback
1994 Toyota X-Cab 4X4
1951 Willys CJ3A
Campfire is offline   Reply With Quote
Old 07-30-08, 07:13 PM   #12
Great, Just so happens that my Bilstein HD's came in this evening.
Is there any specific SCIENCE into replacing these HD's from the OEM's. Just the Open ended wrench?
Start removing from the TOP first? then the bottom.
Does the Truck HAVE to be on Jackstands or just level as is?
HELP!
Richie
- In an Embassy somewhere, and loving it -
'03 - LC100 - Blue Mica
'06 - Royal Enfield Bullet 350 w/ sidecar.
and many other toys that are at my service.....
lasalsa is offline   Reply With Quote
Old 07-30-08, 07:34 PM   #13
TLCA# 11251
I guess since you're not replacing the spring you don't have to put it up on stands, but I would for safety. The bottom bolt can be difficult and a few people have snapped the stud off, so spray it with WD or similar if it's not moving. Other than that I removed the bottom bolt first so we could get a better grip on the shock body to hold it and rotate it while working the top bolt.
Cory Fillmore
99 UZJ
Old 08-01-08, 05:06 PM   #14
On Australian LC's the OEM (original) nuts are definitely 22mm (measured), with the replacement OME (Old Man Emu) a thin walled nyloc of approximately 19mm (I haven't got back under to measure)
Old 08-08-08, 09:24 PM
mcalvarez73
This message has been deleted by mcalvarez73.
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
