Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 08-05-08, 07:49 PM   #31
hoser's Avatar
Originally Posted by spressomon View Post
It's not so much the CV angle as it is the steering arms. That is the limiting factor how high you can lift an IFS hundy. There's isn't a way to lower the rack to reduce the severe angle...
Hmm, are the steering arm bolts tapered? Could one flip the steering arms? What would be the repercussions. Okay, nevermind, don't mess with it. Changing the angle of the steering arms in relation to the lower A-arms might not be wise.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 08-06-08, 10:58 AM   #32
ringpinion.biz's Avatar
100 ifs
My shocks do allow for the downtravel as well, and I have run it up higher, but prefer to keep it as low as possible and still clear the tires. Another thing is, with full time 4wd the suspension droops as throttle is applied, this is amplified with greater lift height, as the arms are at greater angle. It also narrows the track and creates some weird torque steer when pulling away from a stoplight.
Originally Posted by Assassin_Offroad View Post
As long as there is a minimum of 70mm down travel, the lift is fine with the styandard set up.
The shock length we use allows for the amount of down travel required.
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801
info@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Old 08-06-08, 11:54 AM   #33
Suspension
Yes they are tapered, but it sounds like you answered your own question. I think even more down travel than whay you are I run would be pretty unusable. The track would be narrowed greatly through the suspension cycle. for mor travel it would be best to lengthen uppers/ lowers etc. I dont see this happening though.
ih8mud sponsor
866-349-6801
Old 08-11-08, 06:39 PM   #34
Assassin_Offroad's Avatar
You mean the weight transfers, and the front lifts? not droops ?
With not quite right shock valving, and/or spring rate, this will happen with a lift, though with the wheel alignment correct, for the new height [not factory settings] the torque steer [even from the TD units we do power upgrades on to 200+ KW and 600NM] is minimal, still more than standard, but alot is controlled by the wheel alignment, and if the front tyres get up onto the outer tyre edge under acceleration, it will torque steer.
Darren McRae
95 FZJ80 supercharged, 37's, 4.56's, 4" long travel lift, SLEE short bus bar and rear bumper, called ROOBY. http://forum.ih8mud.com/80-series-te...r-build-7.html
"Die trying, not watching!"
Assassin_Offroad is offline   Reply With Quote
Old 08-12-08, 12:39 PM   #35
ShottsUZJ100's Avatar
How interesting. The 100's I've been in actually raise "up" when on the gas, especially the front. If I let the gas off the vehicle then lowers.
I've also never experienced any difference in torque steer between stock and all three lift heights I've had my own 100 at.
ShottsUZJ100 is online now   Reply With Quote
Old 08-12-08, 12:42 PM   #36
This is a still shot from the DVD Video "Legendary Land Cruisers". You will see in it that the front is actually raised in comparison to the rear. While the normal rake of my 100 is lower in the front, you can see at 70MPH the rake is more level by the look of the wheel wells to the tire tops.
NEW! My 100-series Step-by-Step 5-year buildup:
http://forum.ih8mud.com/showthread.php?t=150735
Four-Wheeling Website: http://shottscruisers.smugmug.com/
Old 08-12-08, 05:23 PM   #37
hoser's Avatar
Wider tires and reducing the wheel offset (going more negative) will also promote more torque steer. Wheel adapter/spacers is the equivalent of reducing wheel offset. Some feel the trade off is worth it, some don't.
98 LX470
85 BJ70
Old 08-12-08, 05:24 PM   #38
spressomon's Avatar
I always wondered what an LC looked like doing 70mph off-road
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
Old 08-12-08, 06:30 PM   #39
yes the front of the vehicle does raise, and the suspension droops, keeping the tires on the pavement. As the suspension droops or extends the track is narrowed, and all other areas of the suspension geometry are changed. Some tolerate this more than others, or would know how to tell.
ih8mud sponsor
866-349-6801
Old 08-13-08, 10:25 AM   #40
Ah! Ah! Gotcha. Didn't read that other post correctly.
Old 08-13-08, 10:52 AM   #41
Mall Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
I loved having a 3.78" wider track when I had my stock tires, handled on road like a beast.
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/iPod/Black LC 16"s/BFG AT 285s/Unity Spotlight/Black'd Trim/Hella 4000 Euro+Pencil Beams/IPF Fogs/ARB Combo Bar/Slee TubeSliders/Slee Front Skidplate/Slee Diff-Drop/12mm Bodylift/RhinoLined Rockers&Grille/Matte 1C2 Paint
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
1loudLX is offline   Reply With Quote
Old 08-13-08, 01:12 PM   #42
spressomon's Avatar
But no so good off-road particularly twisty double-track type trails.
Old 08-13-08, 01:27 PM   #43
I'd take the 4" in a heartbeat for added off-camber stability and body protection.
Old 08-13-08, 01:29 PM   #44
Mall Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
really? I still have all 8 wheels downstairs, You can get a serious deal on em
Oo==L==oO
Old 08-13-08, 01:44 PM   #45
Are they 16's?
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
