07-15-08, 02:00 PM
#1
Kick Panel Fuse Block?
Not sure if I'm going crazy or if the fuse block on the drivers side kick panel is missing a cover that tells me what each fuse goes to? I have dug around and can not find a diagram that points me to what fuse is to what?
Anyone have a picture of the actual fuse box diagram or a screen grab of the FSM that will help me out?
Zane
Zane Zwerenz
2000 UZJ100: 285/75/16 BFG's , OME Torsion Bars, OME 866, Slee Diff Drop Kit, ARB Sahara Bar, Slee Rear Bumper, Hella 4000's,Safari Snorkel, Custom Built Sliders, Custom Built Rear Tire Carrier, Modified Mombassa RTT
1997 FZJ80 (SOLD): Custom Built Sliders, Custom Built T-Case Skid Plate, Custom Built OEM Bumper Tire Carrier, Rear Storage Solution, Modified Mombassa RTT, 851/860 OME, 285/75/16 TOYO Open Country MT's,
www.tornadoalleycruisers.com
07-16-08, 09:59 AM
#2
So I take it no one knows how to determine what all of those little fuses are for next to the drivers side interior kick plate due to the lack of response!
Zane Zwerenz
07-16-08, 10:21 AM
#3
Meant to look in the FSM last night, got busy. There's got to be a diagram in the owner's manual.
EDIT - yep, owner's manual.
19. MIRR 10 A: Power rear view mirror
20. SRS 15 A: SRS airbag system, seat
belt pretensioners
21. CIGAR 15 A: Cigarette lighter, car audio
system, power antenna
22. IGN 10 A: Multiport fuel injection system/
sequential multiport fuel injection
system, anti- lock brake system, SRS
airbag system, seat belt pretensioners,
discharge warning light
23. DOME 10 A: Interior lights, personal
lights
24. AHC- IG 20 A: No circuit
25. DIFF 20 A: Rear differential lock system
26. GAUGE 15 A: Gauges and meters,
service reminder indicators and warning
buzzer (except discharge, open door
and SRS airbag warning lights), backup
lights, air conditioning system, electronically
controlled automatic transmission
system, wireless remote control
system, daytime running light system
27. WIPER 20 A: Windshield wipers and
washer, rear window wiper and washer
28. I/UP 7.5 A: Engine idle up system
29. FR FOG 15 A: Front fog lights
30. STOP 15 A: Stop lights, high mounted
stoplight
31. RR A.C 30 A: Air conditioning system
32. DEFOG 20 A: Rear window defogger
33. ECU- B 15 A: Power tilt and telescopic
steering system, daytime running light
system, theft deterrent system
34. TAIL 15 A: Tail lights, license plate
lights, parking lights, instrument panel
lights
35. AHC- B 15 A: No circuit
36. OBD 10 A: On- board diagnosis system
37. RR HTR 10 A: Air conditioning system
38. ECU- IG 15 A: Anti- lock brake system,
shift lock system, power seats, power
antenna, power tilt and telescopic
steering system
39. PWR OUTLET 15 A: Power outlets
Fuses (type B)
40. ABS NO.1 50 A: Anti- lock brake system
41. AHC 50 A: No circuit
42. ACC 50 A: All components in ”PWR
OUTLET” fuse
43. ABS NO.2 40 A: Anti- lock brake system
44. STARTER 30 A: Starting system
45. POWER 40 A: Power door lock control
system, power windows, electric moon
roof, power seat, power tilt and telescopic
steering system
07-16-08, 10:33 AM
#4
Cory,
THANK YOU!!!!
Zane
Zane Zwerenz
07-16-08, 10:58 AM
#5
Took me 5 minutes with Google. If you don't have an owner's manual you can download a PDF version of it pretty easily.
07-16-08, 11:59 AM
#6
Now I feel dumb..  That was too easy!
So for my next technical question. With not having Active Height Control on my rig I would assume that tapping into the following fuse locations would be a decent place to do so if needed.
Second question is does anyone know what the difference is between the two?
Zane
Zane Zwerenz
