Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 07-05-08, 03:43 PM   #1
SamoL's Avatar
I have two LH torsion bars!
Hi!
After installing a winch I had to upgrade the torsion bars. I've received two OME LH torsion bars in the package (the instructions in the FAQ say there should be a LH and a RH bar). As I don't have time for reordering as my summer trip is coming up, I've installed two LH bars. Should I be worried about this?
Regards
Samo
'98 HDJ100
'90 UAZ 469B
SamoL is offline   Reply With Quote
Old 07-05-08, 04:07 PM   #2
Boston Mangler's Avatar
TLCA# 9060
EDIT: Bad info deleted, carry on
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 07-05-08, 04:08 PM   #3
raydouble's Avatar
They are made to twist only one way.
The likeliness that you could break one has just increased exponentially, especially if you are loaded down.
edit: Don't drive it like that, they may not take it back if it has any wear/stress cracks in it.
raydouble is offline   Reply With Quote
Old 07-05-08, 04:35 PM   #4
some 6, no 4, and more 6
bkfj40's Avatar
TLCA# 7909
do you have any information to back up the info you just presented?
bk
KJ4HFL
76fj40 * 77fj55 * 85fj60 * 00uzj100 * 90Hilux Crew Cab (ex)Diesel * 81hj47 * 07Tundra 5.7DC
"I spend most of my money on beer, land cruisers, and women...the rest I just waste" - Curran
bkfj40 is offline   Reply With Quote
Old 07-05-08, 05:42 PM   #5
raydouble's Avatar
bk
Yep
Here is the 2004 Landcruiser FSM
Notice the arrows pointing to the way the spring turns.
Here is the 93 Toyota Pickup FSM
Notice it says "do not interchange" + the arrows showing turning direction.
Here is the sway-a-way installation instructions for a Pickup
There may be no proof that they will break but, the fact is they are made specifically for each side.
What evidence do you have to refute my info?
Old 07-05-08, 05:43 PM   #6
If this is brand new bar they should be fine. Its the used one that usually cause problem because you are counter twisting it.
Make sure to mark it correctly just in case you need to take it out again.
The spline should line up correctly. The key on OEM torsion bar looked like melted glue gun stick. I removed mine when I re-index my bar.
Augie is offline   Reply With Quote
Old 07-05-08, 06:42 PM   #7
TLCA# 9060
Yep
Thats good info!
If it were me, i would replace the "odd" bar, if for nothing else, piece of mind
Baja Overland
2006 XR650L
TLCA #9060
Old 07-06-08, 12:21 AM   #8
SamoL's Avatar
Thanx for the info guys. I guess I'll send a question to OME (or ARB?). I will let you know, what they say.
These torsion bars are new. If they are not twisted in the factory, then there should be no problem, but if they are...
Regards
Samo
'98 HDJ100
'90 UAZ 469B
Old 07-08-08, 12:11 AM   #9
SamoL's Avatar
So far I've received no answer from ARB Australia. I've contacted them using the web contact form. Anyone knows a person in ARB that could answer me a question?
The question is: can a brand new LH torsion bar be used on a right side of a vehicle?
Regards
Samo
'98 HDJ100
'90 UAZ 469B
Old 07-16-08, 11:29 PM   #10
raydouble's Avatar
Bump for answer
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
