Old 07-05-08, 02:33 PM   #1
TLCA# 25959335
cant shift out of park! help?
hey everybody,
so my 100 series came with a car phone which i removed yesterday. seemed pretty easy as i got the ground, and two fuse wires and then just unrouted the mic and antenna. i got in to go fillup today and depressed the brake but could not shift out of park without using the shift override button(the gear selector button would not push in far enough like it normally would) i took the console back apart to see if there was anything i had missed and i could not find anything. help me!?!?
samsher213 is offline   Reply With Quote
Old 07-05-08, 02:41 PM   #2
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
brake light fuse blown?
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Unity Spotlight/Black'd Trim
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
Need OEM Lexus LX470 Foglights? http://forum.ih8mud.com/sale-parts/2...s-98-02-a.html
Need some Michelin LTX M/S 275/70/16's? http://forum.ih8mud.com/sale-tires-w...-shipping.html
1loudLX is offline   Reply With Quote
Old 07-05-08, 03:40 PM   #3
SpokaneLX470's Avatar
2nd the brake fuse. My 4 runner did the same thing not to long ago. Hopefully a $.50 fix.
99 LX470
03 Corolla LE
Spokane, WA
Toyota 4 Life
SpokaneLX470 is offline   Reply With Quote
Old 07-05-08, 04:41 PM   #4
TLCA# 25959335
checked the brake light fuse, not that...
Old 07-05-08, 04:55 PM   #5
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Do your rear brake lights work? Check, even if the fuse looks OK.
Could you have jarred something loose from the interlock?
Andrew
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 07-05-08, 05:54 PM   #6
TLCA# 25959335
ok, so it is not the fuse. i put in a new fuse and the brake lights still dont work.
Old 07-05-08, 06:03 PM   #7
KI6MIE
TLCA# 11734
That's the problem! It's got to be in the trailer harness, only because that's always where the problem is! Good luck, get the lights working and the shifter interlock will work as well.
Andrew
Old 07-06-08, 09:19 AM   #8
TLCA# 25959335
ok... so how do i get the lights working? i am not very good with electrical things so any ideas would be greatly appreciated because this is my dd and i cannot drive without brake lights
thanks
sam
Old 07-06-08, 11:15 AM   #9
You want to do what...?
e9999's Avatar
gotta say that this brake light issue, although relatively well known in enthusiasts circles like this one, is just plain weird.
I mean, somebody tells you that your transmission won't go cuz your lights are out and they are bound to laugh in your face, no...? Weird....
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
Old 07-06-08, 11:51 PM   #10
Bob Loblaw
raydouble's Avatar
Brake light switch on pedal.....
Unplugged
Not adjusted properly
Broken
raydouble is offline   Reply With Quote
Old 07-07-08, 12:05 AM   #11
Bob Loblaw
raydouble's Avatar
Here go........
from a 2004 100 series FSM
What about the lights themselves?
They could both be burned out........ don't laugh, it's been done.
Old 07-11-08, 03:06 PM   #12
ogsuv's Avatar
I second the brake switch. a good place to zip tie wires to, could have pulled it enough to be out of whack
Scott Porterfield
99 LC, River Rock, 148k replaced my 95 Jade Green Metallic LC 209k
"Just because you have a library card doesn't make you Yota"
ogsuv is offline   Reply With Quote
Old 07-12-08, 06:36 AM   #13
ginericLC's Avatar
TLCA# 7328
If you think about it though, it is an excellent safety device. I mean it isn't some light on your dash telling you there is a problem that people ignore. You have to fix it or you can't drive.
Eric V. TLCA 7328
99 UZJ100 "T-REX Edition" under construction
FJ68 PROJECT aka LEGO(60 body, 80 Chassis/Running Gear)
74 FJ15 (that is about all that is left of it)
Lots of Parts FS http://forum.ih8mud.com/sale-parts/2...ml#post3693029
ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
ginericLC is offline   Reply With Quote
Old 07-12-08, 10:21 AM   #14
e9999's Avatar
interesting point. So you think it's intentional? Didn't think about that. Doubt that most truck buyers would support the idea, though. You're in the middle of the desert and you can't move cuz you lost a light bulb....?
DD
souped up DR650
Old 07-12-08, 10:55 AM   #15
ginericLC's Avatar
TLCA# 7328
Oh yes it definitely intentional. On the older ones (my 91 has it) they included a button near the shifter which you could unlock the shifter after bulbs blew. I think the newer ones you can get at the release by prying off a button cover. I guess I've never looked at it in my 100. But just yesterday I had to press it in the 80. I'm running with no doors, windows, lights, seats, etc... in preparation for the 60 series body swap.
Eric V. TLCA 7328
Old 07-12-08, 11:00 AM   #16
e9999's Avatar
well, I think that "forced remedy" effect is worse than the original problem. I bet 95% of drivers would not know about/figure out the shift override and would effectively be stuck on the road if a bulb blew. Does not look like good PR for Toy to me.
DD
souped up DR650
Old 07-12-08, 05:47 PM   #17
ginericLC's Avatar
TLCA# 7328
Read the owner's manual!
Eric V. TLCA 7328
Old 07-12-08, 05:55 PM   #18
Trunk Monkey's Avatar
TLCA# 11251
95% of 100 drivers would call AAA and have the bulb changed at the dealership.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
100 Series Wheels FOR SALE-CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 07-13-08, 04:20 PM   #19
Viva el barro!
Dandon's Avatar
I find it an interesting feature, but a disproportionate one. I mean, losing a brake bulb has you stuck unless you push a hidden override button. But if you lose e.g. all your engine oil or cooler fluid (which will destroy the engine), or your brake fluid (which will surely lead to a severe accident), you can perfectly drive away with just a warning dash light.
Sorry, but I don't think it's logical.
Regards,
Dandon - Madrid, Spain
'99 UZJ100 Euro Spec. - BFG AT 285/75/16 -CB-170.000 Km (106 kmi) - Scratches galore
Dandon is offline   Reply With Quote
Old 07-13-08, 05:32 PM   #20
ginericLC's Avatar
TLCA# 7328
Think of the odds though. I've never lost engine oil or any oil containing hoses and I'm well into 300,000 miles on Cruisers. But I've burned out a lot of brake light bulbs and even more having to do with trailer wiring.
Eric V. TLCA 7328
Old 07-13-08, 05:51 PM   #21
Bob Loblaw
raydouble's Avatar
Maybe we can get an update?
Threads like this are useless if the OP never comes back to report on what happened.
Old 07-14-08, 09:55 PM   #22
You all are overstating this problem. A blown bulb will not lock up the tranny. It is a short in the circuit that locks it up. That's why trailer converters and harnesses often cause the problem. The other culprit is the loose connector as mentioned above. This is the way almost every vehicle is wired these days, not just Toys.
It would be good to hear the resolution though.
__________________________________________
'00 LC
'05 4Runner V8
"A mind is like a parachute - It only functions when open"
EdsCruisin is offline   Reply With Quote
Old 07-14-08, 11:45 PM   #23
My brake light fuse blew after hooking up a falty trailer harness to my LC. changed the fuse and it was good to go! did the symptom you described with the gear shift locked up. fuse box is on driver side floor left hand panel.
99 LC100 (165K MILES), FULL OME LIFT 866's, SLEE DIFF. DROP, SLEE STEP SLIDERS, SAHARA BAR, REAR ARB JERRY CAN/TIRE CARRIER, WARN 9.5XP, IPF's, 285 BFG AT'S.
mmaakk is offline   Reply With Quote
Old 07-15-08, 08:24 AM   #24
i backed into a tree and locked mine up intermittantly. Doors would lock and unlock on their own, also intermittantly. Turns out the bumper had pushed in against the brake light wiring harness and crimped them. I had a devil of a time discovering that. I then rewrapped each wire individually and then wrapped them all together again. Problem cured.
99 UZJ100, '04 TUNDRA DC 4X4, WIFE'S '08 Solara SLE convertible.
9toys is offline   Reply With Quote
Old 07-15-08, 11:16 AM   #25
Dan Dare!
rusty_tlc's Avatar
TLCA# 15069
Try this with any newer Toyota;
With your foot off the brake nad the car in park start the engine. Keeping your foot off the brake try to put it in gear.
Dan Johnson
Originally Posted by DSRTRDR View Post
maybe your life took a vacation without you and that's why you are going crazy........
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 07-15-08, 12:12 PM   #26
ToyotaDon's Avatar
HEAR, HEAR!! Let's be logical, folks.
As said above, all newer vehicles are designed this way. It is a safety feature, so the vehicle cannot be shifted into gear without someone "in control" of the vehicle.
Donal
ToyotaDon is offline   Reply With Quote
