Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 06-30-08, 02:46 PM   #1
Location: Pittsburgh, PA, www.carterkamienska.com, www.cmu.edu
'98 wiring enigma
Our '98 has been acting a bit ornery lately in the electrical department. Our Garmin GPS went dark on a recent trip and we realized the power outlet lost power. Subsequent investigation revealed all the acc. outlets to be out, and the lighting for the radio console, clock, audio LCD, temperature, and all the LEDs for the AC, mirror heaters and such are also out. These functions seem to work however. The radio does not work now.
We found a blown fuse (Radio fuse) and replacing it did nothing. All other fuses look to be intact but we've not metered them.
It should be mentioned that the Garmin cord was acting up and might have a short in it.
Also, the ignition key has occasionally not been engaging when we turn it. After a few tries it starts but there's an intermittency in the switch or something. Possibly related?
Any thoughts would be greatly appreciated.
LCtygrys is offline   Reply With Quote
Old 06-30-08, 03:12 PM   #2
Trunk Monkey's Avatar
TLCA# 11251
Your key issue sounds like starter contacts.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is online now   Reply With Quote
Old 06-30-08, 03:18 PM   #3
OK. Is it worth shooting some contact cleaner in the keyhole?
Old 06-30-08, 03:25 PM   #4
TLCA# 11251
No, search for or look in the FAQ for starter contacts. It's the contacts on the actual starter motor.
Cory Fillmore
99 UZJ
Old 06-30-08, 03:33 PM   #5
Got it. I'm off to to get a good FAQ.
thanks
Ben
Old 06-30-08, 07:36 PM   #6
Two seperate problems
Starter contacts as already mentioned
Check a couple of the bigger fuses in the fuse box in engine bay, 50amp and 80amp, they supply accessories and other circuits, sound like you have lost a few circuits so probably one of these.
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Old 07-06-08, 09:18 PM   #7
FYI
It turned out to be the fuse marked 'cigar', which also does the radio and all the LEDs for the center console. The power outlets started working after replacing the 50 amp fuse #44 but the old fuse tested fine. All's well for now. Thanks for all the input!
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
