06-22-08, 07:09 AM
#1
could it be the starter already???
My 98 100 clicks once when i turn the key, all power comes on but it doesnt start. It will eventually start after turning the key a few times....WTF
I changed the starter 2 years ago and the battery is about 2 years old as well, maybe 3.
For the love of God if i have to change that starter again i will cry
any thoughts?? Where should i start (no pun intended)
Brian
06-22-08, 10:49 AM
#2
what??? nobody??
06-22-08, 11:26 AM
#3
Symptoms definitely sound like starter contacts, which would be really surprising so soon (and suck). Check your battery terminals, you can have the batt checked for free somewhere.
06-22-08, 12:02 PM
#4
Sounds like starter. But before you go to that repair be sure to check your battery terminals as TM stated above: Remove them, clean the terminals (coke or emery cloth).
Was it a Toyota new OEM starter you replaced 2-years ago?
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
06-22-08, 10:54 PM
#5
Same symptoms as when my starter contacts crapped out.
'98 100-Series- ARB front, Slee rear, OME lift, Bilsteins, 285s, AOB rack, ARB locked front, Warn 9.5, 140K miles
'07 Taco Double Cab 4x4
06-23-08, 08:06 AM
#6
yep, bought it from Toyota....
If i have to pull that starter again i will kill someone. I'll clean the battery terminals today..
06-23-08, 08:39 AM
#7
And since its easier than replacing the starter I'd have the battery load tested before pulling the intake.
06-23-08, 09:05 AM
#8
I think i would rather sell the truck than replace the starter again......
06-23-08, 12:42 PM
#9
You can't be serious. That is not that bad of a job. Bring it over, I'll do your starter and you can clean up the front axle on my project truck.
06-23-08, 02:12 PM
#10
the problem isnt the job of changing it out the problem is listening to my wife bitching that i am working on the truck...
