Old 06-20-08, 06:35 PM   #1
Mall-Cruiser
1loudLX's Avatar
TLCA# they took my money and never sent me my number.
Title edited: Right Front Speed Sensor bad
my right front area has been squeaking at low speed for the past week. It doesnt make much noise when its cold, but after driving for a while it gets kinda loud.
Its not the brakes, already ruled that one out.
Just had my mother drive the truck down the street while I hung out the open door with my head under the truck, LOL! I wish I had video if it.
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Blacked out trim
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
1loudLX is offline   Reply With Quote
Old 06-21-08, 08:32 AM   #2
Trunk Monkey's Avatar
TLCA# 11251
Squeaking with movement of the suspension? Or just squeaking no matter what?
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Trunk Monkey is offline   Reply With Quote
Old 06-21-08, 09:43 AM   #3
Mall-Cruiser
1loudLX's Avatar
rolling squeak, not a suspension squeak
Oo==L==oO
Old 06-21-08, 10:27 AM   #4
TLCA# 11251
Could be brakes, hub, CV, etc.
Cory Fillmore
99 UZJ
Old 06-21-08, 11:03 AM   #5
offroadkid's Avatar
TLCA# 12427
I know that you said you already ruled-out the brakes, but here's what I found causing my noise. My annoying squeak from the L/F turned-out to be coming from where the brake pads came in contat with the calipers. The metal surfaces were shiny where they were contacting eachother. I took them out, put anti-sieze on the edges, and now it's gone. It was hard to diagnose as I could only hear it while driving. I put it up on the hoist at work and removed the wheel. With the truck in drive, I inspected the L/F brakes, but it would not make the noise. That is when I noticed the pads sliding just slightly back and forth on the caliper causing the noise.
Hope you find-out what it is soon, I know how annoying and frusterating it is.
Joshua
1998 UZJ100 Imp. Jade Mica/Gray 295 Nitto TG's
“Some dream in color, I dream in 4 wheel drive."
My Wife's AVM story
www.findchristiewilson.com
offroadkid is offline   Reply With Quote
Old 06-21-08, 06:44 PM   #6
Could be the tires.
I had a problem with my old car.
It was a squeek between the tire and rim.
Minor problem, left it alone.
Went away when I got new tires.
Try rotating with rear to check.
newbee mechanic is offline   Reply With Quote
Old 06-22-08, 01:29 AM   #7
An easy solution could be - remove the center cap on the wheels and see if it stops. Good Luck!
My Yotato's:
2000 Lexus LX470
1991 Toyota Land Cruiser
1991 Toyota 4Runner - considering selling it.
Got Klipsch?
Yotato is offline   Reply With Quote
Old 06-23-08, 12:40 AM   #8
Mall-Cruiser
1loudLX's Avatar
here is a clip where you can clearly hear the noise that has been bothering me. Any ideas?
YouTube - squeakkkkk
Oo==L==oO
Old 06-23-08, 08:35 AM   #9
TLCA# 11251
Right at the beginning and right as you're going out the gate? Seems like both times you'd be on the brakes slightly, turning the corner and waiting for the gate. Pads may just be dragging on the rotors.
Cory Fillmore
99 UZJ
Old 06-23-08, 10:05 AM   #10
ShottsUZJ100's Avatar
Tiny pebble stuck in the caliper area?
If so, a few hard stops often breaks the pebble up and all is well.
ShottsUZJ100 is offline   Reply With Quote
Old 06-23-08, 10:10 AM   #11
TLCA# 11251
If you've got something stuck between the pad and rotor I wouldn't suggest hard stops, I'd suggest cleaning it. Mashing on the brakes can cause whatever it is to gouge the rotor surface.
Cory Fillmore
99 UZJ
Old 06-23-08, 12:08 PM   #12
Mall-Cruiser
1loudLX's Avatar
took the right front wheel off today and used brake cleaner to clean everything up. Didnt see anything dragging and even moved the dust shield away more. Problem of course went away till i left the shop...squeaked the whole way down my street after i rolled thru the gate.
Oo==L==oO
Old 06-24-08, 08:06 PM   #13
Mall-Cruiser
1loudLX's Avatar
ABS, VSC and TRAC lights came on earlier...went to the dealership. There were a bunch of codes, one for the speed sensor and then the rest are all related things(including ABS actuator). bought a speed senor and had them clear the codes.
On my way home the TRAC freaked out when i started going from a light turning, so I assume its a faulty SS even though the code didnt come back up. I'm going to replace the sensor later this week but for now I'll just drive the other car, dont need the trac kicking in on a high speed turn or something.
Oo==L==oO
Old 06-26-08, 08:55 PM   #14
Mall-Cruiser
1loudLX's Avatar
got the sensor replaced this afternoon, that was fun----not. Ended up taking the rotor off so we could punch out the old sensor that was stuck in there. Repacked the bearing while it was off and cleaned up some stuff. Seems like the squeak went away, and no more xmas-tree dashboard.
Oo==L==oO
Old 06-29-08, 11:59 PM   #15
I had an annoying squeak that turned out to be a missing screw on the front grill. I replaced it and I'm back to normal. Good luck!
tomcranks is offline   Reply With Quote
Old 06-30-08, 06:47 PM   #16
Mors Ab Alto
twstrchasr's Avatar
TLCA# 13505
I had a noise that, for the longest time seemed to be coming from the upper dash area...Finally hunted it down and it was coming from the glove box door, of all places. Used some of those little round felt pad sticker thingys (like you would use on a chair leg so it wouldnt scratch the floor, etc...) and all has been well..Only need to put new felt pads in every 6 months-->1 yr. No biggie !!
Hope that helps someone !!
1989 FJ62-Freeborn Red-140,000 miles
2001 UZJ100-Champagne Pearl-68,000 miles
2003 MBz CL55 AMG
1991 Range Rover
twstrchasr is offline   Reply With Quote
Old 06-30-08, 09:05 PM   #17
Mall-Cruiser
1loudLX's Avatar
this thread is specifically about a right front squeak coming from the right front wheel area, the "lets post random squeaks we have heard in our truck" thread. Squeak hasnt come back since thursday night so I think im good. Now just to fix a rattle I hear, which is coming from the kittens.
Oo==L==oO
Personal Loans | Credit Cards | Savings | Power Tools | Credit Card Consolidation
