Old 06-05-08, 09:25 AM   #1
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
What size shackles do I need?
1/2"? 5/8"? 3/4"? 7/8? 1"?
1981 FJ60 - Martha’s Vineyard - 210K, OME, BFG ATs, MAF header, hi-flo cat and Magnaflow, Surco Safari Rack, Rod Racks.
2002 UZJ100 - Brooklyn - 44K, OME 865, OME T-Bars, TJM T-15, TJM RB8, Slee Diff-Drop, Slee Tube Sliders, African Outback Roof Rack, Borla & SLP Exhaust, Warn, IPF, PIAA, Toyo Open Country ATs.
Gotham City Land Cruisers
Yankee Toys
Bay to Blue Ridge Cruisers
macneill is offline   Reply With Quote
Old 06-05-08, 09:41 AM   #2
Hot enough yet?
Campfire's Avatar
TLCA# 16416
I bought a 3/4" x 6.5 and then made some nylon bushings for my rear Slee bumper.
Is this for direct bolt in to the tabs?
(edit, read the markings on the shackle the wrong way)
Jeff
1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. Oh yeah, a bent frame too.
1999 UZJ100, 285 BFG Muds, and all getting all that stuff above except the bending part.
Campfire is offline   Reply With Quote
Old 06-05-08, 09:42 AM   #3
You want to do what...?
e9999's Avatar
the smallest one that'll fit that's rated for whatever force you need to exert and then some...
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
e9999 is online now   Reply With Quote
Old 06-05-08, 09:42 AM   #4
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
I'm going to hang these from my CalamariDog recovery brackets.
Yankee Toys
Old 06-05-08, 10:00 AM   #5
spressomon's Avatar
If Cdog used my original FRB design, which I am sure he did, then you need the 7/8" Bow/D Shackle. The "pin" for a 7/8" Bow/D shackle is 1" diameter. FYI: The smaller Bow/D Shackles are not wide enough to straddle these FRB's...so there is only one Bow/D Shackle size to consider.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
spressomon is online now   Reply With Quote
Old 06-05-08, 10:02 AM   #6
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
Thanks Spress. Question answered.
Yankee Toys
Old 06-05-08, 10:45 AM   #7
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
Wait, I had the ones that had a 1" diameter and they didnt fit properly. I dont have any of my shackles right now as my friend has them for PC but I believe the ones I have now that fit are 3/4 with a 7/8" Pin.
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Unity Spotlight/Black'd Trim
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
Need OEM Lexus LX470 Foglights? http://forum.ih8mud.com/sale-parts/2...s-98-02-a.html
Need some Michelin LTX M/S 275/70/16's? http://forum.ih8mud.com/sale-tires-w...-shipping.html
1loudLX is offline   Reply With Quote
Old 06-05-08, 10:50 AM   #8
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
Mac, see this thread, fish2live got the 7/8s with 1" and they didnt fit...same thing I did.
http://forum.ih8mud.com/100-series-c...delivered.html
Spress, which one is it?
or is it this?
fish2live,
Unless Cdog changed my original FRB design you need a "3/4" D/Bow Shackle. These have a 7/8" diameter pin...which fits nicely through the 1" hole in the FRB.
D-Ring Shackels: 1", 7/8", 3/4", 5/8", 1/2"
And if you're 100 is really stuck I recommend utilizing two FRBs, one on each frame mount location, and using a rated recovery strap connected to each FRB and then your winch line connection. You want to keep the angle between the FRB/frame leg and the connection at the winch line to 120 degrees or less to help prevent the left and right frame legs from trying to collapse towards each other...
Here's a crude pic...
Oo==L==oO
Old 06-05-08, 11:40 AM   #9
fish2live's Avatar
got mine here D-Ring Shackels: 1", 7/8", 3/4", 5/8", 1/2" and bought the 8.5Ton (7/8" with 1" Pin)
7/8" D-Ring
Specs
Size Diameter = 7/8 "
Working Load Limit = 8 ½ ton
Pin Diameter = 1"
Width between Eyes = 1 7/16"
the pin was TOO BIG
get this one and it will fit
3/4" D-Ring
Specs
Size Diameter = 3/4"
Working Load Limit = 6 1/2 ton
Pin Diameter = 7/8"
Width between Eyes = 1 1/4"
I KEPT mine and bored the FRB holes out a bit and then ground down the pin a bit. They fit now... those little mother 's
'03 100 75K- Color matched ARB Sahara & ARB Rear, Warn M12K, Hella FF4000 100w, REVO's, DVD Hack, Bilsteins, HIR, Hellroaring Dual Battery, DRL's off, Fogs work w/ High Beams
'92 80- sold to brother-in-law!!
'01 KTM EXC453 Dual sported, REKLUSE, Yoshi
www.pacificflyfishers.com
fish2live is offline   Reply With Quote
Old 06-05-08, 11:42 AM   #10
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
i sent mine back and got the 3/4 with 7/8 pin.
Oo==L==oO
Old 06-05-08, 11:54 AM   #11
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
Thanks. I already ordered with 4x4 Connection, but will have to change my order now.
The question is, do I paint them OSHA yellow...?
Yankee Toys
Old 06-05-08, 12:18 PM   #12
Before you do, check out the Grainger catalog. I found them there years back for the same price but with a higher load capacity(8 ton) and they were already powdercoated yellow... Or get them done in electroless nickel. BLING BLING!
94 D90
97 Disco
06 Land Cruiser
Kneel is offline   Reply With Quote
Old 06-05-08, 01:12 PM   #13
Trunk Monkey's Avatar
TLCA# 11251
Yeah, here I am reading the thread title and wondering "who thinks they have leaf springs?"
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Trunk Monkey is offline   Reply With Quote
Old 06-05-08, 02:00 PM   #14
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
you want yellow nipple rings? I didnt like my orange ones, im doing them in BLACK!
Oo==L==oO
Old 06-05-08, 02:02 PM   #15
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
Maybe, I'll have to see how they look.
On another note, I want rear nipple rings too.
I wonder if there is interest in another group buy?
Yankee Toys
Old 06-05-08, 02:11 PM   #16
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
i would think in a few months maybe we could get it done. Now that we have the proper sources for everything it should roll smoother then before. I would take two FRBs
Oo==L==oO
Old 06-05-08, 02:14 PM   #17
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
You wanna take that lead?
Yankee Toys
Old 06-05-08, 02:15 PM   #18
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
no you can, since you said you wanted em first!
Oo==L==oO
Old 06-05-08, 02:27 PM   #19
spressomon's Avatar
or is it this?
Sorry everybody...especially Mac!!!
The correct bow/D shackle is the 3/4" with a 7/8" diameter pin as the FRB hole size is 1" diameter.
Originally we designed the FRB for a 7/8" bow/D shackle with a 1" diameter pin for the then FRB 1-1/16" hole size...and then downsized the hole to 1" after we did the stress analysis; And I looked at the wrong drawing Mac!
Mac: I owe you a few beers!
