Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 06-03-08, 06:10 PM   #1
Remove active suspension on LX ?
Hi all,
I am in the process to buy a LandCruiser 100. And I really like the additional comfort of the LX but not the suspension.
How difficult it is to remove the active suspension on a LX ?
Thank you,
Raphael
Raphael is offline   Reply With Quote
Old 06-03-08, 08:49 PM   #2
jeffdavis1053's Avatar
Well I just removed the AHC "shocks", and replaced with OME HD kit. I don't think that was much harder to do than what it takes to do the same thing to a 'Cruiser.
Now if you're taking about ripping out all the other AHC components , it might be a pain in the ass, but I didn't do that to mine, and have a 0 problems so far.
2000 LX - TJM T-3, Big Hellas, Slee Rear Bumper, AHC removed, OME HD, Slee Diff Drop, 35s, and more to come...
1974 FJ-40 - Sprung-over, 36" TSLs, Locked F/R RIP
jeffdavis1053 is offline   Reply With Quote
Old 06-04-08, 12:03 AM   #3
Jim_Chow's Avatar
What did you cap off the lines with? BTW, looking at toyota-parts.com, if one wants to convert the LX suspension to stock OEM, all you need to change are the front t-bars, rear coils, rear stabilizer bar, rear bumpers (I think they mean the rubber bumpstops for the rear coils?) and rear stabilizer bar bushings. The other suspension parts are all the same when comparing the '03-'05 LC (no AHC) with the '06-07 LC. Toyota-parts.com quotes around $265 for each t-bar, $110 for the rear stabilizer, $64 for the bumpers, $8 for stab bar bushings, $110-120 for each rear coil. The OEM shocks must suck since they are only $30 each. I'd go w/ Bilsteins (around $75 ea). It's around $900 plus price of the shocks. Otherwise, if you want OEM height/ride, I don't know how else to get it 'cause all the other suspensions are 2" lifts. IMHO, $1200 for a OEM non-AHC suspension w/ Bilsteins is a decent deal considering the least expensive replacement accumulator globes from B&B suspension are around $1300/set, and OEM is around $2K-2.5K.
'03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's.
'86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars.
'01 Prelude SH: stock
'00 Honda CRV: stock
Jim_Chow is offline   Reply With Quote
Old 06-04-08, 10:04 AM   #4
Even cheaper, considering how it is likely you can find the T-bars, springs, etc from someone who upgraded to OME 2" lift anyway.
1999 Toyota Landcruiser - 285/75/16 BFG AT, Slee SliderSteps™
slimbuddha is online now   Reply With Quote
Old 06-04-08, 07:53 PM   #5
Welded 'em
Old 06-09-08, 08:24 AM   #6
Thank you all for your replies. Very helpful. Raphael
Old 06-09-08, 06:03 PM   #7
TLCA# 17299
hey jim there was a guy a little ways back saying that switching out the ahc system affects the stabilty of the lx's i did not believe this to be true any info on that??
r3run33 is offline   Reply With Quote
Old 06-09-08, 06:56 PM   #8
Jim_Chow's Avatar
I think I remember that post. IIRC, it was saying that the swaybars and maybe other suspension components are sized assuming the AHC is working. It's not just replace the shocks/rear coils and front t-bars and you're good to go.
I did a check on Toyota Parts Accessory Dealer Toyota Auto Parts Accessories and found that the front sway bar is the same for both non-AHC and AHC LC's, but the rear swaybar is different on the non-AHC LC. So in the front, the t-bars are beefier on the non-AHC LC. In the rear, the sway bar and coils are beefier. But by replacing the sway bar in the rear, you need to replace the little rubber bushings and I think a nut here and there are only single use. The rubber bump stops for the rear coils are different on the LC vs. the LX (I'm guessing a different length?). The other stuff (front sway bar, lateral rod, upper/lower control arms in front/rear) all has the same P/N's for the non-AHC and AHC LC's. Then there are the shocks. After you replace all that, the suspension should be identical to that on a stock LC although I'd recommend one use aftermarket shocks, either Bilstein or OME.
Has anyone w/ a stock suspension replaced only the shocks w/ OME? Does anyone make some kind of caps to seal off the AHC lines at the shocks?
Old 06-10-08, 12:04 PM   #9
TLCA# 17299
thanks jim i really did not think that guy was correct thanks for the info on all the part numbers
Old 06-10-08, 06:42 PM   #10
hoser's Avatar
Thanks for the info Jim. Can somebody with an LC measure the diameter of the rear sway bar with a micrometer? I'll do the same when I get my LX back.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
