Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Notices
Old 05-25-08, 02:57 PM   #1
Wheel studs on the 100?
anyone have a source other than toyota for stud and lug bolts? they quoted me 24.00 per wheel at the dealer, and I have 4 out of 5 stripping on the RR wheel. and I figured I'd do both sides while i'm at it. I discovered this at a hotel hours away from home yesterday when attempting to change a flat tire. they will freely turn about 2 turns and then stop turning. I'll likely have to snap the studs to get the wheel off.
1999 Landcruiser 100- rear locker,REVOs, 2005 Toyota Navigation with XM,backup camera, 135K
mikeacs is offline   Reply With Quote
Old 05-27-08, 08:32 AM   #2
Boston Mangler's Avatar
TLCA# 9060
I had the same problem on my 80 AND my 100
I replaced the 80 series studs with aftermarket pieces and 2 stripped and 2 broke!
I replaced the 100 series studs with OEM and they fit great and held up perfect!
I strongly recommend OEM studs, its worth the $ to do it right/once IMHO
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 06-03-08, 11:44 PM   #3
I had one on each side of the rear break off and replaced with OEM, no more issues. Surprized it happened but I guess that is what happens when you have the dealer and others rotate your tires!
99 LC100 (165K MILES), FULL OME LIFT 866's, SLEE DIFF. DROP, SLEE STEP SLIDERS, SAHARA BAR, REAR ARB JERRY CAN/TIRE CARRIER, WARN 9.5XP, IPF's, 285 BFG AT'S.
mmaakk is offline   Reply With Quote
vBulletin® v3.8.0 ©2000 - 2009, Jelsoft Enterprises Ltd.
