Dealer = What's a Torque Wrench
Man oh man, last time I had our LX in the dealer for AHC services, I asked them to do an oil change (it was due for one and very cold out, so I figured what the heck). Well, today I changed the oil on the LX. It took a 3 foot breaker bar to get the drain plug loose! How they didn't strip it is beyond me. That damn thing was in there tight!
Oh, and the filter, I had to destroy it to get it off. I tapped it around a full turn with a chisel and it was still too tight to turn by hand. Needless to say, I had a few choice words for them while laying on my back in the driveway. What kind of monkeys are they hiring to do this work? Ay kid with a high school shop class under his belt would know better. __________________ 2000 LX 470 Stock Wife's ride for a few years, then the fun begins. |
Howdy! Did out the reciept and go back down to the service manager and raise Hell. Probably won't do you any good, but it MAY help the next victim. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
Whoa, you broke out the chisel for the oil filter? That's a pretty serious death grip. You think a strap wrench would've helped any? That's what I normally use on my cars. But yeah, that's ridiculous of the dealer. I wonder what they would've used to break them both loose if you had them do the work again.
__________________ '01 UZJ100 Black '02 Camaro Z28, Black, 25K miles, *FOR SALE* |
#4 | |
huh?
I was out of town on business so the wife took it to the dealer back in Feb. Two weeks ago when I tried to change the filter, I couldn't get it off to save my life. (didn't try a chisel) Had to leave it on, refill with new oil, drive to dealer. They had to break it apart to get it off. I got four free oil changes out of it.
__________________ J-Bo 1974 FJ40--"Jerry Jeff"--FOR SALE 1989 FJ62--"Ms. Cuban"--Stock, DD 2000 UZJ100--"Elsie"-- DD, Slee Sliders, BFG 285'sI dyde shyte thre grete toordes. Upstate Cruisers |
You want to do what...?
I got myself a filter pliers affair from HF. Large curved pliers with sharp teeth. Only $6 or so. That thing will crush any filter and for sure remove it. (May result in oil leaks if tear into filter.)
Harbor Freight Tools - Quality Tools at the Lowest Prices There are also some visegrip type. Have not used those. The rubber straps don't work so well with oily stuff. Of course, now, I'm experimenting with hand tightening the filters. Down to 1/2 turn from 3/4" on the 80 and all is well... __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
Village Idiot
I have been hand tightening and loosening mine for around 50k without issue.
__________________ Travis 1999 UZJ100, TJM T-3, OME 866 Heavy kit, Custom Sliders, Onboard Water & Mombasa Penthouse. www.RealEstateBook.com "Anyone will say anything under the influence of madness." Jesco White |
I warned a quicky place not to overtighten (BMW) in Fl. He comes up from the pit and tells me he will give me $8 off if I dont need a receipt. I drive back to Colorado and find he had collapsed the plug by overtightening then put some sort of sealer in there to keep the oil in. Miracle it made it 3000 miles. Beware
__________________ Mudlover, 04 Landcruiser, Extremely Stock Crested Butte Colorado USA |
I have a 06 Lexus GS300, the new cars have this release valve to let the oil out first via a drain cock. I did the oil change on it myself for the first time and it was fused. I had to just unscrew the filter cartrige canister and oil spilled all over. The oil filter access lid was missing too.
#10 |
10-4 on the missing fill plate. I had the dealer change the oil when we first got the LX. A few weeks later I realized the drain cover was missing on the under engine shield. When I called them about it, they said, "Oh yeah, most mechanics leave those off as they are not needed." Well, who asked me!? When I explained that we live on a farm and drive through hay fields often, with all of the hay ends getting stuck up in there, they said well something like, "Wll most of our customers aren't farmers." NICE!
#11 | |
Viva el barro!
Perhaps some "mechanics" understand that 3/4 turn means 3 or 4 turns... ![]() I use this type of filter wrench to loosen it. It's cheap and works well.
__________________ Regards, Dandon - Madrid, Spain '99 UZJ100 Euro Spec. - BFG AT 285/75/16 -CB-170.000 Km (106 kmi) - Scratches galore |
#12 | |
I hope you didn't mean to say that you only tighten yours to contact, cuz that might not be enough from what I understand. Normally, IIANM, you'd screw it in until you achieve contact with the seal surface then do 3/4 (three quarters) turns more. I have found that do the 3/4 I need to finish off with a strap. Can't do it by hand. So now I do contact plus about 1/2 turn which I can do comfortably by hand. Main difference is that when I did the 3/4 I could not unscrew the filter by hand later on and had to struggle even with a strap, whereas with the 1/2 it comes off very easily. (I doubt you could do an extra 3 turns.) (Don't forget to oil the Oring.) __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
#13 | |
Viva el barro!
The extra 3 turns was obviously a joke
#14 |
I put a little oil on the new filter gasket, and screw on..... hand tight. Then wipe down with a rag and grip with both hands and give it some additional snugness. Done.
__________________ 2004 UZJ100 "El Rinoceronte" - Gotta pay to play...
#15 | |
__________________ 1999 Toyota Landcruiser - 285/75/16 BFG AT, Slee SliderSteps™ |
#16 |
IH8MUD No-Lifer
As always, if you want it done right, you gotta do it yourself.
__________________ 98 LX470 85 BJ70 |
#17 |
huh?
True enough...
#18 |
I picked up one of those form fitting cups that fits like a socket on the end of the filter. With a 3/8" rachet, it will loosen or tighten the filter very easily, with no mess. I typically oil the threads and o-ring then tighten by hand and finish off the 3/4 turn with the socket wrench. Works like a charm!
__________________ __________________________________________ '00 LC '05 4Runner V8 "A mind is like a parachute - It only functions when open" |
#19 | |
#20 |
"New meth" mechanics is more like it. A curious result considering the image the brand protrays. Certainly the corporate office would show an interest in resolving the issue.
__________________ Abe NItro aka Ben Troia 99 LC with OME Suspension (N133, N101, 860s), Goodyear Wrangler Silent Armor 285s Slee diff drop and step sliders Odyssey Battery with custom poly spacers Auburn CA |
#21 |
guess i'm getting old and lazy, i only own them when they are under warranty and i only have the dealer service them. this way any thing that goes wrong is the dealers problem and or covered by warranty.
__________________ Mercedes SL550 LX470 |
#22 |
I have one of those too, but it will crush a filter. Only good for removal.
#23 |
A very messy but useful way to remove a very stuck filter when position of filter makes it difficult top grasp with oil filter wrench is to hammer a long and strong screwdriver through the filter. Gives you good leverage and you can least break the grip of the thread. Used ot more than once on a now thankfully deceased Landrover
