Another Use For "Slees Dual Battery Tray" W/Pics
Ok, i am getting further along in my dual battery install and the aux battery (Odyseey 2150) i will be running will not fit in the Slee tray.
The tray makes good use of some wasted space under the hood, so i figured i should use it for something. At first, i thougtht of making a fluids holder to hold 3-4 quarts of various fluid, but when doing the wiring for my dual bats, i came up with another idea and it should make for a very clean install! Below are some pics of the Blue Seas 6 Circuit fuse block and their "SEA" fuse block that will be fitted with a 150 amp fuse to protect the rear portion of the install that will be in the cargo area of the truck. Its obviously in the early stages, but here ya go: ![]() ![]() ![]() __________________ Baja Overland www.bajaoverland.com 1999 Land Cruiser 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org Last edited by Boston Mangler; 05-18-08 at 11:31 AM. |
Mall-Cruiser
IIRC, I believe that fuse block is rated for a max of 100A, but the max voltage is also 32v so I donno. I'm fusing mine at 100A.
Looks clean, seems like you should mount a compressor there too. __________________ 2000 LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Stealth Package Oo==L==oO TeamLoud |
#3 | |
Thanks Nah, i dont belive in them! CO2 all the way! ![]() __________________ Baja Overland www.bajaoverland.com 1999 Land Cruiser 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org |
But if you make room for one now, it will make the air locker install a lot easier a bit further down the track!
__________________ HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER |
#5 | |
I HIGHLY doubt i will ever go with ARBs though __________________ Baja Overland www.bajaoverland.com 1999 Land Cruiser 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org |
I HIGHLY doubt i will ever go with ARBs though[/quote]
What other choice is there for the front of a 100? Speaking of ARBs. I have my new one sitting in the entry way. It is the new one piece design. RD131 __________________ Eric V. TLCA 7328 99 UZJ100 "Barnacle Edition" under construction FJ68 PROJECT (60 body, 80 Chassis and Running Gear) 74 FJ15 (that is about all that is left of it) WAGON PARTS FS http://forum.ih8mud.com/showthread.php?t=189134 ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories" www.WildWildWestArt.com Last edited by ginericLC; 05-18-08 at 09:19 AM. |
#7 | |
Note the revision date on the installation manual. __________________ HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER |
Looks good, very clean install!!!
SAS!
![]() Yes, i am doing it, no i am no sure when, yes, i am already collecting parts! ![]() Ok, back on topic now! __________________ Baja Overland www.bajaoverland.com 1999 Land Cruiser 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org |
#10 | |
SAS! I've debated that a lot. There is no way that I could figure out to retain the ABS. I'm anxiously awaiting the All Pro SAS for the FJ Cruiser to see what they do for sensors, etc... They plan to retain the ABS and ATRAC. What they do for the FJ might have some transfer to the 100 series. My Slee battery holder is sitting empty as I want a bigger than Optima sized battery. I did a fuse block sort of like what you are doing but I did it inside the glove box so I'd have easy access to it for my accessories as I add them. One big wire running through the firewall is easier than 6 little ones. __________________ Eric V. TLCA 7328 99 UZJ100 "Barnacle Edition" under construction FJ68 PROJECT (60 body, 80 Chassis and Running Gear) 74 FJ15 (that is about all that is left of it) WAGON PARTS FS http://forum.ih8mud.com/showthread.php?t=189134 ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories" www.WildWildWestArt.com |
#11 | |
#12 |
www.justdifferentials.com
Actually the rd132 is for the FRONT of 80 or 105, and for the REAR of minitruck, 4runner Fj cruiser etc.
__________________ JTS Diff Parts & Accessories ih8mud sponsor 866-349-6801 info@justdifferentials.com www.justdifferentials.com 99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more. |
#13 |
Yes front is correct, my mistake.
Online Loans | Mortgages | Credit Card | Utron Blog | Home Loan |
