#31 |
Subscribe today!
Roger that, both of ya, and even to ATS
I just got riled over him saying the review was some kind of sellout trade of a product for a feature story. If they would have failed on the Rubicon, everyone, especially me, would have known about it, and written it. It's all good.We now return you to your regularly scheduled programming. ![]() __________________ David Zartman Publisher 4WD Toyota Owner Magazine http://www.4wdtoyotaowner.com 1995 FZJ80, 1970 FJ40, 1999 Tacoma, 1979 FJ40, 1986 4Runner, 1973 FJ40, 2000 4Runner, 1984 hardcore buggy, 2007 FJ Cruiser Baja racer |
#32 |
The V-Chip is blocking the signal!
__________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#33 | |
what the hell happened?
They made the Con, great, so have normal arms, no one is disputing that, I simply gave you the opportunity to explain how objective your opinion on the arms were, and I quote, "Perhaps if he were to come back to us on his buy price, and wether promoting them in any way was a part of the purchase price, so people could tell how much to value his opinion. Should that not happen, we can only wait for someone with a truly impartial view, to post findings." No one was accused of anything, but simply offered an opportunity to explain. __________________ Darren McRae 95 80 series 1FZ-FE with bits to come http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html |
#34 |
And just a quick note
http://forum.ih8mud.com/chit-chat-se...ml#post3334338 have changed ID and am no longer using ats4x4 user name, and have changed my ID to this one. also need to get 10 posts done to get full access. __________________ Darren McRae 95 FZJ80 supercharged, 37's, 4.56's, 4" long travel lift, SLEE short bus bar and rear bumper, called ROOBY. "Die trying, not watching!" Note ID change http://forum.ih8mud.com/chit-chat-se...ml#post3334338 |
#35 |
OK, the arms are in. There are REALLY HEAVY DUTY. I am glad I waited. VERY GLAD. The pics don't do justice. These arms are HUGE....almost slider huge. I waited until the last minute to take pics so they aren't that great. Once they are on (later today) I'll take better ones.
I luv the newly added skid plates on the second gen models. Should help to protect the weld making them even stronger! ![]() The rear of the bar touts a skid as well. ![]() Bent arms offer added clearance compared to straight ones. ![]() TEST: Pretend this is a ledge or rock you need to climb. Resting on the arm will stop progress unless you hit it and risk bending. ![]() You need about 6-more inches before the tire climbs the "ledge". Will the new arms afford the needed clearance to climb the "ledge"? Check back AFTER the arms are on. ![]() __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#36 |
Cant wait to see them installed! Im jealous!
Hurry with the installation pics!By the description (almost slider beefy?) they sound greattt! I want a pair! ahhhh __________________ 98, ome f/r, arb front, slee sliders, slee rear w/ swing, warn 9000, 2 hella aux lights, 295/75r16 bfg all- terrains, cb, homemade rear drawers, huskies front to rear 100 PARTS FOR SALE: http://forum.ih8mud.com/sale-parts/2...rts-100-a.html |
#37 |
Oh and how much idd they run you? Without the $40 80 series hardware?
thanks __________________ 98, ome f/r, arb front, slee sliders, slee rear w/ swing, warn 9000, 2 hella aux lights, 295/75r16 bfg all- terrains, cb, homemade rear drawers, huskies front to rear 100 PARTS FOR SALE: http://forum.ih8mud.com/sale-parts/2...rts-100-a.html |
#38 |
WHOA NELLIE! My mechanic just called. From center of bolt hole to bolt hole these arms are 7/8" LONGER than stock. 100 arms and 80 arms are the same length, just a different bushing. SOMEBODY made a boo-boo. These won't work on either truck. I'm picking the 100 up soon. Will contact WW Off-Road tomorrow.
#39 | |
#40 | |
That might actually not be a problem. My old 80 arms were custom made to be (IIRC) 0.5" longer than stock, in order to properly locate the wheel in the well after lifting. As you know, as you lift the truck, the wheel effectively moves forward due to the angle of the arms (sort of like the axle also moves sideways due to the Panhard rod as you lift). So this may be designed purposely in order to put the tire back where it was pre-lift, in terms of wheelbase at least. Or it could be mistake, I guess... Let us know what WWOR says. edit: Also helps keep the diff flange properly lined up with the t-case output flange. __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) Last edited by dclee; 06-22-08 at 06:12 PM. |
#41 | |
Won't work on mine. I already rub the Slee bumper at full compression. Another inch would cause crap. I don't have any more room rearward for the tire. I'm vibration free. Changing the angle via longer lower arms without also changing upper arms to correct might bring in vibration. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#42 |
Yea, x2 please let us know what you find out. I've been waiting to order a set of these until you installed yours and could give some feedback.
__________________ '98 100-Series- ARB front, Slee rear, OME lift, Bilsteins, 285s, AOB rack, ARB locked front, Warn 9.5, 140K miles '07 Taco Double Cab 4x4 |
#43 | |
You may not have vibrations now, but I wouldn't be surprised if you're wearing your U-joints, and the vibes will develop in time. __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) |
#44 |
Better to replace U-joints every 150K than have a suspension setup that stops you in your tracks from rubbing every time you articulate.
#45 | |
John: I wonder why you have tire rub on your Slee bumper? I only rubbed on the inner fender wall at max articulation...not the bumper itself. What would be so different between our two rigs to cause your rubbing? __________________ Modded '99 for on-trail exploring: 315's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good music for ears, Waeco CF-50, PowerGate with 2nd battery, home brew tube type sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Fox 2"remotes at each corner, 12mm body lift... KE7NCM |
#46 | |
It's rubbing right here though not quote enough to halt progress. Another half inch would kill me, let alone another 7/8". ![]() __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#47 | |
It's still strange...same frame/body, same size tires, same rear bumper, same lift, same shocks (you have the 74L which are longer...but you have upside +2" bump stops I don't have...), stock upper and lower control arms (then). I am comparing when I had the OME set-up installed... __________________ Modded '99 for on-trail exploring: 315's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good music for ears, Waeco CF-50, PowerGate with 2nd battery, home brew tube type sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Fox 2"remotes at each corner, 12mm body lift... KE7NCM |
#48 |
Get profile shots of the side wings of the bumpers and how are they're sticking into each of yours' wheel wells. Could just be difference in manufacture of bumpers.
__________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
#49 |
I know in "measurement terms" the bumpstops should reduce 2" of up-travel. Reality is (from all our observations) that once the stop hits the axle, the axle then seems to rotate even more on that bumpstop. It takes on a teeter-totter effect and that tire just turns in angle-wise big time while the axle doens't move up any more. I think it's because of the added droop on the other side. It's hard to explain but the setup works and adds a lot.
The axle is also VERY crooked when flexed in that pic. The stuffed wheel is far rearward and the drooped far forward. I guarantee you that IF I had a shorter shock on the drooped side and the long ones on the stuffed side, I'd not rub. Of course you can't use that setup. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#50 | |
#51 |
Just spoke to Tim from WWOR. He's already got modified arms completed and going to paint tomorrow and we hadn't even spoke yet! Talk about service! He made the decision based on my posts!
I should have them within a week. I'll re-post when complete. Tim's going to be able to make either length....stock or stock plus ~7/8th. This way he'll have stock-length arms so to work with any lift kit without increasing rubbing. Then the longer arms that correct for pinion angle and will work for other appllications where rubbing is not an issue (ie...lift height vs bumper type vs shock length vs tire size, etc). __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#52 | |
The other option for adjusting the pinion angle back down would be to utilize shorter/adjustable upper rear control arms. Then you can stay with the stock length lower control arms. __________________ Modded '99 for on-trail exploring: 315's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good music for ears, Waeco CF-50, PowerGate with 2nd battery, home brew tube type sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Fox 2"remotes at each corner, 12mm body lift... KE7NCM |
#53 |
Exactly, which is why he's going to make stock-length arms as well. By adjusting pinion angle via adjustable upper arms you don't add in the rubbing factor longer lowers can cause.
