Old 05-06-08, 03:49 PM   #1
Landpimp's Avatar
TLCA# 5506
Landpimp
Best route to run a 10g wire to the rear
Need to run a 10g wire or 2 from the engine compartment to the DS rear of the 100, whats the best route? (I know I bet if I seached I'd findit, but to lazy)
Inside, under or a combo of both?
where to run thru firewall?
Landpimp is offline   Reply With Quote
Old 05-06-08, 03:54 PM   #2
7 dirty words
rusty_tlc's Avatar
TLCA# 15069
rusty_tlc is on a distinguished road
Don't konw the whole answer but you can snake a couple of wires through the fire wall via the rubber boot just outboard and under the steering column. I just poked a hole and ran the wires then sealed around them with RTV.
Dan Johnson
"Does this stairway go all the way to the top of the tower?"
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 05-06-08, 03:57 PM   #3
Landpimp's Avatar
TLCA# 5506
Landpimp
hey.....thats a start and its in the front so a good place to start
Old 05-06-08, 05:50 PM   #4
spressomon's Avatar
spressomon is on a distinguished road
I ran my 10ga wires that supply my second rear fuse panel/circuit in the rear on the PS side. Through a similar large rubber 'grommet' as the DS...and then down along and under each door sill plate. I installed the second fuse box in the rear PS covered door: Perfect hiding place but yet it is still accessible.
Modded '99 for on-trail exploring: 315's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good music for ears, Waeco CF-50, PowerGate with 2nd battery, home brew tube type sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Fox 2"remotes at each corner, 12mm body lift... KE7NCM
spressomon is online now   Reply With Quote
Old 05-06-08, 07:30 PM   #5
Landpimp's Avatar
TLCA# 5506
Landpimp
sounds like how I ran it in my 80 series years ago, didnt know on the 100 if there was maybe a better/new way
Old 05-06-08, 07:39 PM   #6
LandCruiserPhil's Avatar
LandCruiserPhil is an unknown quantity at this point
I ran 2 - #10 wires for my trailer brake/package through the frame from inside the cab.
"Knowledge without experience is just information"
Copper State Cruisers #003
LandCruiserPhil is online now   Reply With Quote
Old 05-07-08, 09:49 AM   #7
7 dirty words
rusty_tlc's Avatar
TLCA# 15069
LP, I have to ask, whatcha doing?
Dan Johnson
Rust never sleeps.
Old 05-07-08, 09:52 AM   #8
spressomon's Avatar
FYI: Like LCP mentioned I also have a trailer circuit; however I ran that from the front aux fuse panel to the rear bumper along the frame rail.
Old 05-07-08, 10:50 AM   #9
IH8MUD No-Lifer
hoser's Avatar
hoser is an unknown quantity at this point
Another FYI, there is a plastic access cover in the rear, accessible through the DS outer tail light that leads out under the body, by the rear bumper.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 05-07-08, 03:44 PM   #10
Mall-Cruiser
1loudLX's Avatar
1loudLX is on a distinguished road
Good to know, maybe I'll finally finish my bumper light project.
2000 LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Stealth Package
Oo==L==oO
TeamLoud
1loudLX is offline   Reply With Quote
Old 05-07-08, 04:11 PM   #11
spressomon's Avatar
X2. I've had the darn light mounted back there for almost 3-years...not connected...pretty lame
Old 05-07-08, 04:39 PM   #12
7 dirty words
rusty_tlc's Avatar
TLCA# 15069
Dan Johnson
Rust never sleeps.
Old 05-07-08, 05:02 PM   #13
i4c4lo's Avatar
i4c4lo
On the passenger side in the hood area - where the Slee 2nd battery tray goes to - there is wire loom there in a rubber boot. If you look in that rubber seal/boot there is a niple that you can cut - this will allow you to feed the wires you need to get through the firewall.
On the passenger side foot well. There is a plastic cover - it was a plastic nut you can unscrew and above that is where the wiring you have inserted will come through. You can peel the carpet on that side (removing the plastic trim on the door sill that holds the carpet down and run the wires all the way to the back of the truck)
Just another place where you can run wires through firewall.
I4C4LO - KI6PQL
somewhere in CA
i4c4lo is offline   Reply With Quote
Old 05-07-08, 05:52 PM   #14
Tom B's Avatar
Tom B is on a distinguished road
What's all this talk about routing little 10g wires, is overkill dead?
I ran my wires just as ic4lo described. FYI, there is enough space in that cavity to route more wiring if you wanted to. For example, I ran 2 4g marine wires and a 10g wire in a loom to the PS rear under the door sills. In the rear, I installed a fuse block accessible through one of the cubbies, a power inverter hidden behind the trim, and 2 factory flip down 12v always-hot outlets to charge stuff and power the Engel. None of the seats need to be removed to do the routing, and it's useful to have something (fish wire or bulky 4g) to do the routing by the B-pillar. There is a factory loom that runs along there that you can zip tie to if you wish.
2000 UZJ Land Cruiser
Tom B is offline   Reply With Quote
Old 05-11-08, 10:12 AM   #15
Landpimp's Avatar
TLCA# 5506
Landpimp
better power for the fridge and want to add some drawers and I know I need to run aux power before i add drawers.
Old 05-12-08, 12:19 PM   #16
scottm's Avatar
scottm is on a distinguished road
Are you guys fusing these wires under the hood as well? Seems like a lot of wire to run without a fuse. I had a 50A marine breaker from West Marine on my 80, I think it was about $25.
'03 UZJ100: wife's ride; '97 FZJ80: Traded in; '97 FZJ80 40th: Totalled; Heep: company car, hey it's free including gas and maint; '06 Specialized Epic Comp Disk: Daily Driver
The biggest obstacles in life are between your ears! (or between your legs)
scottm is offline   Reply With Quote
Actress | Loans | Flights | Blog Forum | Car Insurance
