Old 05-04-08, 05:17 AM   #1
15A Guage fuse blows when putting in reverse
Hi everyone.
When i put my truck in reverse, it blows the 15A guage fuse immediately.
I have tried unplugging all switches from the transmission, but can't seem to find the reverse switch.
Anyone have some ideas or a picture of where the reverse switch on the transmission is please?
Louis
2000 105 GX manual
Full replacement front and rear ARB bumpers
10000LB Warn winch
2" lift
285/75 R 16 tires
louisspies is offline   Reply With Quote
Old 05-04-08, 08:39 AM   #2
Not sure exactly what switch you are talking about, but an easier place to start troubleshooting and possibly a likely culprit would be the reverse lights ckrty (including trailer wiring if you have it). I have the factory manuals and will try to look for any switches and relays you might be able to check.
1999 LC-
Factory rear locker (mods soon)
1999 Taco-
2.5" lift, 285/75/16 MTR's, 99 4runner rims, ARB front bull bars, Warn 8k, CB, Safari Snorkel, rear lunchbox locker, campershell, homemade (atv ramp) safari rack, deckplate mod
morerunner is offline   Reply With Quote
Old 05-04-08, 09:39 AM   #3
You want to do what...?
e9999's Avatar
Welcome to the site!
can you clarify what specific fuse you're talking about?
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD and souped up DR650
Old 05-04-08, 10:23 AM   #4
Hi e9999.
It is the 15A fuse in the footwell marked Guage. When the fuse blows(as soon as i put it in reverse), all the guages on the instrument panel dies too.
The fuse blows every single time i select reverse.
Louis
2000 105 GX manual
10000LB Warn winch
2" lift
285/75 R 16 tires
Old 05-04-08, 10:27 AM   #5
Thanks morerunner. Waiting in anticipation. This thing has got me stumped for 2 weeks now.
2000 105 GX manual
10000LB Warn winch
2" lift
285/75 R 16 tires
Old 05-04-08, 11:17 AM   #6
offroadkid's Avatar
TLCA# 12427
Is this rig new to you? The reason I ask is that when looking at the EWD, it swows a 10A fuse in the gauge spot, and that makes me wonder if someone put a higher amperage fuse in to keep it from blowing?
It looks like the reverse lights, park/neutral switch, and gauges are some of components on that circuit:
10A GAUGE2
Back-Up Light
Center Differential Lock
Combination Meter
Cruise Control
Door Lock Control
Electronically Controlled Transmission and A/T Indicator
Engine Control
Multiplex Communication System
Navigation System and TOYOTA Parking Assist
(Rear View Monitor)
Trailer Towing
VSC
Wireless Door Lock Control
Maybe the Park/Neutral switch is shorted, and blowing the fuse?
In the picture, it shows the switch on the side of the trans.
I could be totally wrong, but that is what I found on a quick search.
Joshua
1998 UZJ100 Imp. Jade Mica/Gray 295 Nitto TG's
“Some dream in color, I dream in 4 wheel drive."
My Wife's AVM story
www.findchristiewilson.com
offroadkid is offline   Reply With Quote
Old 05-04-08, 11:44 AM   #7
offroadkid's Avatar
TLCA# 12427
It looks like it's a gray 9 pin connector.
Do you have reverse lights when in R? I think if you disconnect it, bypass the park/neutral switch, leave it in P, put a new fuse in, and jump pins 2&3, your reverse lights should come on.
Plug it back in and see if the fuse blows.
Again, I think this is how to diag. it, not positive.
Joshua
My Wife's AVM story
Old 05-04-08, 11:46 AM   #8
Hi Joshua.
The vehicle is not new to me, i had it from brand new.
It sounds like you have the manual for the VX variant, with the auto transmission and the V8 engine, as my truck does not have any of the electronic stuff you mentioned.
I have the manual 4.5 6 cylinder model.
How many wires are there going into the switch you are talking about?
2000 105 GX manual
10000LB Warn winch
2" lift
285/75 R 16 tires
Old 05-04-08, 11:49 AM   #9
offroadkid's Avatar
TLCA# 12427
Oh, didn't think about that!! I guess I should have read your sig first!!
The conn. I'm looking at has 9, but I doubt yours will. Sorry, I thought we were going to find out the problem, but I don't have info for your Cruiser!!
Joshua
My Wife's AVM story
Old 05-04-08, 11:57 AM   #10
e9999's Avatar
Originally Posted by louisspies View Post
Hi Joshua.
we don't have that model available in the US unfortunately. Can you get a EWD for it?
Old 05-04-08, 12:32 PM   #11
On the 80 series, the gauge fuse handles a lot of stuff, including the back up lites. If u have a short in one of the bulbs (rare) this will cause ur problem. Use an ohm meter to check each bulb.
FZJ80 FUSE CHART GUIDE
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 05-04-08, 12:44 PM   #12
Unfortunately not. Only EWD i can find online is for the US spec one.
Thanks for trying to help though :(
2000 105 GX manual
10000LB Warn winch
2" lift
285/75 R 16 tires
Old 05-04-08, 03:21 PM   #13
Louis,
Sorry, I had just got off a shift and had to sleep a while. I didn't read your sig either and I actually only have the manuals for the U.S. specs as well. Have any accessories been added (anything aftermarket)? This is a good place to look. If there is, try removing them from circuit. I would also start checking your ground connections and cleaning them too. Especially ones you can find on the back/under the vehicle coming from wiring looms for the lights. While your under there, it wouldn't hurt to clean your connectors for your lights. I think there is at least a few. I agree with dfmorse about the light bulbs but I did have a ground the other day that was on the rear light circuit that was bad. It was blowing my 100A fusable link and causing multiple other issues.
1999 LC-
1999 Taco-
Old 05-04-08, 07:10 PM   #14
I believe I have circuit diagrams from the UK with reverse light with manual transmission, it may not be exact but worth a look. PM me your email address and I will send them.
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Secured Loans | Debt Help | News | Cheap Car Insurance | Novela romantica
