newbie question for a dual battery
Hello sorry for my stupudity on this one; but why go to a dual battery setup?? I want to carry an on board air compressor and maybe some xtra lights; would that be needed?? what are some other reasons pople carry a dual set up; is it just incase the 1st goes down? thanks
Just like a spare tire, a spare battery is good for my peace of mind.
Cheers, __________________ Snook 2000 UZJ100 Nip/Tuck front ARB & rear 4x4Labs bumper w/ towing hooks - 8k Warn - Slee Slider - Drop diff - Slee T bar - 315 MTR - Slee HD Rear Spring - ARB Air Lockers - Regear 4.88 - Snorkel w/ GPS - ARB Refri - 1" spacers F & R - 3k W inverter - water heater shower system - '67 Custom Tailgated M416 trailer w/ Italian OverCamp http://forum.ih8mud.com/100-series-c...100-snook.html Video by Snook: http://www.tlcwagons.org/Norcal_Wago...os/Videos.html |
When you get your refrigerator (and you will, if you haven't yet...), the dual batts will be heaven-sent.
I've only had to use mine in anger once, it was Rubithon 05 or 06, can't remember which, but after two days in the Springs with the fridge running full bore, and running all kinds of high-powered camplights at night, plus the truck's interior lights, plus the radio, etc., the battery was dead when I tried to start it up Sunday morning to leave. Just flipped a switch to bring the second one online, waited a few seconds, then cranked her right over, no muss, no fuss! __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) |
My setup maybe a little backwards, but I have a dual battery (Painless ) setup in which all of my major accessories are connected to the backup battery. I have my 60qt Engel Frig/Freeze (2.7amp draw) and my Warn Winch set up to my yellow top optima. Everything else is connected to main battery. I also keep the spare battery isolated when the ignition is off and combined when the engine is running, and charging the batteries. I know I will probably get laughed at for my setup, but it works for me.
__________________ 2000 LC, ARB Front bumper, with Warn 9500xi, and Rear bumper with Tire Rack, Slee Step Sliders, Slee 2 inch lift, 305/70R16, Engel 64QT frig/freezer, computer with Garmin GPS so far.... :ROTW:http://forum.ih8mud.com/100-series-c...ml#post2271091 1953 M100 Trailer, 3200lb axle, 33 tires, ARB RTT ![]() 1998 BMW 2.8 Z3 1994 Z28 IROC Camero ![]() 1976 MGB (restoration project 1) 1972 VW Beetle (restoration project 2)
Many people are just running the 1700 Odyssey versus the dual battery set up. If you are just going to run a few accessories, that should be fine.
If you want to power a winch and fridge too, perhaps a second battery. In other words, I don't think it is manditory. __________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
For me it's a few factors:
- running items over night (fridge) - running high draw items (winch) - being able to self-jump The draw of some lights or other accessories isn't enough reason to get two batteries. __________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
As mentioned, depending on your usage, you decide if you need/want one. If it is a DD and goes to the mall with breakdown service available at the push of a phone button, then probably not needed. If you want to adventure out a bit and could be in the situation where you get stuck with a flat battery by yourself, then a good option. The other thread about fitting a larger group 31 battery to replace your main battery http://forum.ih8mud.com/100-series-c...00-thread.html
would also be worth considering as an option. By itself, you don't have the backup battery, but you do have greater capacity so you can draw a bit of extra power from it without being too worried about it. A simple dual battery setup can be simple, but rarely is. It is very easy to add another battery with a surepower dual battery isolator in line (or other similar unit) but then to do the job properly you need to add a fuse block and run some new wiring to all your power outlets, fridge, DVD etc so they only run from the second battery. You may also like to put your stereo and interior lights on this battery, but it all take more time and effort. __________________ HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER |
Books | Compare | Debt Help | Buy PSP | e Harmony |
