Brake Job...Front or Both?
Hey Gang,
It is time to replace the pads on the front of my '01 as the "clicker" bar just started making racket. Anyway, after reading many articles I think I am going to go with the OEM pads, but I am wondering about the rear brakes. Should I go ahead and replace the pads on all 4 wheels at the same time, or should I wait untill the rears wear down? From what I can tell, the rears still have a bit of life in them, but since I bought the vehicle used, I can't know for sure when the fronts or rears were last replaced. Thanks, -R __________________ "I only have one rule! Never bet money you don't have, on a dog race, with an x-girlfriend, who happens to be a stripper..." |
I got my 01 used too and when one of my front rotors needed replacing, I went ahead and ordered a set of front and back including pads, all OEM from cruiserdan. I got everything replaced just so I would know where I stood with the brakes now, than I did when I bought it.
__________________ '01 UZJ100 Black '02 Camaro Z28, Black, 25K miles, *FOR SALE* |
Mall-Cruiser
rears are a piece of cake, do it if you want...otherwise just wait till they are needed.
__________________ 2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Blacked out trim 2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips Oo==L==oO Need 100 3rd row seats? http://forum.ih8mud.com/sale-parts/2...ml#post3604000 Need some Michelin LTX M/S 275/70/16's? http://forum.ih8mud.com/sale-tires-w...-shipping.html |
Rears tend to wear out faster on the 100, so it is likely they have been replaced already. You will likely go through 2 replacements of the rears for each front one.
__________________ 01 LX470, Golden Pearl (white)/ ivory 01 LC, jade green/ ivory (sold - mistake) 03 4Runner, Ltd, V8, 4WD (sold) |
I just did a writeup on it, check it out: 100 Series Brake Job and Front End Rebuild Details
__________________ Baja Overland www.bajaoverland.com 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org |
That's interesting, every vehicle I've owned, including an 80, the fronts wear faster due to the physics of braking and the weight of the engine on the front end.
__________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
I got 20k more miles out of my fronts compared to my rears. Rears were on the squeelers whereas the fronts had some meat left.
I replaced my rears around 35-40K miles on both my LC and LX. About 70K plus on the front. Only vehicle I have owned that wears rears first. I suspect it has to do with the weight balance of the 100, the relative size of the pads, and possibly the action of VSC/TRAC.
Yep, my rears went first too.
__________________ Eric V. TLCA 7328 99 UZJ100 "Barnacle Edition" under construction FJ68 PROJECT (60 body, 80 Chassis and Running Gear) 74 FJ15 (that is about all that is left of it) WAGON PARTS FS http://forum.ih8mud.com/sale-parts/189134-wagon-stuff-80-100-60-55-few-40-items.html ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories" www.WildWildWestArt.com |
#10 |
I think this is for the '98-02. The '03+ introduced "electronic brake force distribution." I notice my front pads seem to wear faster than the rears. Does anyone else w/ a '03+ notice this?
__________________ '03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's. '86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars. '01 Prelude SH: stock '00 Honda CRV: stock |
#11 | |
![]() serioiusly though thanks for the heads up on the rears I'll have to check them soon then. i just picked up my '05 with 63k miles and put on 5k. 1K miles just last weekend wheeling in 120F heat at Anza-Borrego desert. i luv my LC100(Sarah)! -tony |
#12 |
My fronts are at 5mm and rears 6mm. At what mm do you guys replace so you don't mess up the rotors? Lexus dealership wants $275 per axle to do the job, which includes turning the rotors and conditioning the calipers and new pads. Anyone just slap on new pads all around and call it good? Brake fluid was replaced 10K miles ago. Figure I should have 5-10K left until fronts and rears are down to 3mm.
__________________ Mercedes SL550 LX470 |
#13 |
Just buy OEM Lexus or (probably cheaper) OEM Toyota pads and throw them on, don't turn the rotors unless they are very very uneven. I have just changed my rotors on my Ford Falcon at 230000km (145000 miles). I have fitted new pads throught it's life without turning the rotors, the reason I changed the rotors was they were worn below the specified thickness. However they were smooth. My thoughts
__________________ HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER |
#14 |
Mall-Cruiser
i did just pads a few thousand miles ago, didnt turn the rotors or anything. Next brake job is going to be ART rotors and some HD pads. FWIW, I got my pads from toyota, cheaper then lexus for SAME part #.
#15 | |
#16 | |
I am more conservative when it comes to brake pads (especially fronts) and tires. I don't like to let the pads get too thin as it results in less heat sink effect forcing more heat back to the rotor. Thicker pad material = better heat dispersion IMO. IMO the rotors are undersized for the size and weight of a 100 anyway. Add bumpers, winch, sliders, drawers, recovery gear, larger tires and it all increases the workload for the brakes. Probably stuff you already know and realize. And as 100TD stated...if it ain't broke don't fix it. In other words if the rotors are true and not worn below minimum thickness just install new pads and take your time bedding them in before doing any hard panic type stops. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#17 | |
IH8MUD No-Lifer
To dissipate more heat from a rotor, my guess is an alloy wheel would do a better job than a steel wheel. I have no idea if the difference would be significant. __________________ 98 LX470 85 BJ70 |
#18 | |
#19 |
Nothing scientific to support my decision but I replace at 1/3 remaining. But I am more conservative regarding this due to: 35", weight of my rig, living/driving in the mountains and the trailer I consistently tow. For the fronts, with my ART and Porterfield set up, it translates to around 55-60K! I'm good with that all things considered. FYI: The rears got replaced at around 30K. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#20 | |
#21 |
When you can't see the ligne in the middle of the pad, you must change them (around 3 or 4 mm I guess)
I changed the rears pad (out of limit , pretty close to machine the rotors) and the fronts look to be a the middle of their life
Wills | Adult ADD | Cheap Magazine Subscriptions | Mobile Phones | Refinance |
