Rear off center axle housing
Hey guys.
Just wondering if anyone can explain why would the Toyota Land Cruiser 100 series have the rear axle a little off center. What would be the purpose and point of this? Thanks page |
Village Idiot
Check out this thread. http://forum.ih8mud.com/100-series-c...sale-slee.html
I think its position varies with lift and load. __________________ Travis 1999 UZJ100, TJM T-3, OME 866 Heavy kit, Custom Sliders, Onboard Water & Mombasa Penthouse. www.RealEstateBook.com "Anyone will say anything under the influence of madness." Jesco White |
#3 | |
Lines up better with the T-case output. Ideally, both front and rear will be offset the same, as in an 80 Series, so you can pick a line over a boulder and not have to adjust direction when it goes under each axle. Also, it gives just a bit more clearance under the middle of the truck, though that is debatable. Somewhat moot on the 100 due to the IFS. __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) |
#4 | |
You're thinking of the axle shifting due to Panhard rod position as height increases. I think the original poster actually meant the offset diff housing. Though I could be wrong... __________________ Derek Lee `63 Mercedes-Benz UNIMOG (404.115) `64 Mercedes-Benz UNIMOG (404.114) `81 Mercedes-Benz 300GD (460.333) `90 Mercedes-Benz 500SL (R129) `02 Saab 9-5 Aero `04 Toyota Land Cruiser (UZJ100) |
As stated it's just the most direct line from the output on the t-case. It sucks tho since that means two different axle shafts.
__________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
#6 | |
What would be the benefit of the lining up with a most direct line? Is the centred rears not in a direct line? Thanks PAge. |
...pig searching...
Almost all Land Cruisers have had the offset diff housings. The FJ25 had a centered rear housing, but up until the 200 series, they were offset.
__________________ Looking for an FJ55. |
Driveshaft no likey compund angles.
I think the real reason for the offset diff is due to the design of the transfer case. In vehicles with centered rear diffs, the rear output shaft exits the transfer case inline with the output shaft of the transmission (centered). In Land Cruisers (thru the 100) the rear output shaft is offset to the side (in line with the front output shaft of the transfer). This requires an offset diff since d-shafts don't work well with compound angles.
__________________ 1993 FZJ80, 180k, 3 diff locks, OME, ARB, Warn, Lightforce, Hankook MT, Part-time 4wd, Technitop. Never owned anything but a Land Cruiser. |
#10 |
Maybe the centered rear axle on the 200 has to do w/ the torsion diff t-case? Don't know what the big hype about the torsion diff is. We managed to get a nearly new (rental) V6 4runner stuck in deep tiretracks through soft dirt in 4WD when the diff lock was off by intentionally stopping the vehicle when the front tires went into the depression (someone else was driving). In this case, the torsion diff was useless (terrain was sandy board-flat florida). Locking the center diff got us out, so the torsion diff when unlocked didn't help at all.
__________________ '03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's. '86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars. '01 Prelude SH: stock '00 Honda CRV: stock |
Wohnungsgenossenschaften Berlin | vBulletin | Internet Advertising | Loans | Cheap Car Insurance |
